  4. MRA 6.0.0 (526) - Offline Calculation Problem
9 Posts 2 Posters 62 Views 2 Watching
  • Dave J 0
    I am finding that when I need to start a navigation with the app temporarily offline, then I always receive a message to say that the route cannot be calculated. The required maps are downloaded and I have re-downloaded these to make sure that there were no problems with the previous download; however, the problem still persists.
    Similarly, if I stop navigation in an area with poor/no signal then I am unable to resume the navigation session. I am generally resuming navigation from CarPlay and just receive the ‘calculating’ message on CarPlay but the phone says cannot calculate. The same problem happens if I start a new navigation session in poor signal areas; the app correctly goes into offline mode but will not calculate a route to start on CarPlay (or on the phone). That said, the route will then calculate as soon as I have signal and go back ‘online’.
    I had similar problems with the previous version but this is a consistent problem for me.
    Ducati Multistrada V4 Rally
    iPhone 18 Pro
    CHIGEE AIO-6 LTE
    • Dave J 0 Dave J 0
      @Dave-J-0, when you enable offline navigation, does it then calculate correctly? If not, double check your offline maps, you seem to have lost some map areas.
      Dave J 0 1 Reply Last reply
        wrote last edited by Dave J 0
        @MotoCon that is what I thought but I have downloaded the appropriate maps 3 times now (Wales and England). Still the same problem.
        Even if I select Offline Navigation, I still get this: IMG_0067.jpeg
        Additional Note: Just did another map remove and update - same issue.
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        • Dave J 0 Dave J 0
          @Dave-J-0, Humour me and download the complete region of the UK and check back.
            @MotoCon Unfortunately, still the same.
            iPhone 18 Pro
            CHIGEE AIO-6 LTE
            • Dave J 0 Dave J 0
              @Dave-J-0, Okay, I assume your own location is also within the downloaded maps? If so we eliminated a map problem. Is this a couch exercise? If yes, go outside to a street and try again. Being too far from a street can have this effect too. If still no go, Corjan would have to check.
                @MotoCon Unfortunately, this (and previously) was standing outside my house and about 4m from my road which is in the downloaded map area. As well as the previous could not calculate message, I also sometimes get the following which seems to never stop until I force close the app:
                It just will not calculate in offline or temporary offline modes. The point being navigated to was a destination I went to online this morning.
                iPhone 18 Pro
                CHIGEE AIO-6 LTE
                • MotoCon
                  I cannot reproduce, on my end offline navigation works effortless, and I have not seen any questions like this one before.
                  Since this is a beta I think @corjan-meijerink is interested in your logs.
                  I would file a support request, so he can get in contact.
                    @MotoCon I have the logs ready to go. There have been a few individuals who have mentioned similar but the map reload has normally solved the problem. Thank you for your input. 😊
                    iPhone 18 Pro
                    CHIGEE AIO-6 LTE
                    • MRA 6.0.0 (526) - Offline Calculation Problem
                    • MRA Studio export speed
                    • Routeberekening zonder invloed van actuele verkeerssituaties en wegafsluitingen
                    • Route with one Waypoint cannot be saved
                    • route bug
                    • Map colours and side roads
                    • Hiya from UK
                      Russ Nattrass 1
                      Russ Nattrass 1
                    • geeft routepunt niet weer
