  4. Drive restriction for vehicle
22 Posts 6 Posters 173 Views 3 Watching
  • Robineke
    Robineke
    Robineke
    I have planned my route through the web version.
    I have inserted my vehicle profile which is 4500kg.
    Why is the Web version and navigation leading me through the restricted area which does not allow vehicles heavier then 3500kg? Can someone help me?
    It is the road between Mirablle-aux-Baronnies and Nyon.
    (https://www.myrouteapp.com/route/open/14388267)
    • Robineke Robineke
      @Robineke Let’s first establish which sign should apply in order to interpret the rules implemented in the planner. There are different signs for different types of vehicles.
      If a road is marked with the sign shown below, no vehicle heavier than the weight indicated on the sign is allowed to use that road. In addition, there are separate signs for motorhomes and trucks with a specified weight limit.
      And then that data also needs to be included in HERE’s map data, as HERE is the map provider for the planner. If I enter the weight of your motorhome as the weight for a truck, I actually get a different route at the points you mention.
      Robineke 1 Reply Last reply
      • Travellexxie
        I guess something is wrong with the camperprofile. Normally you would see a shield on the map with the limitations (that is my experience with my camperholiday in Spain). Switch to the "truckprofile" and you see what I mean. @corjan-meijerink could you have a look at it? I think something is broken.
        • Travellexxie Travellexxie
          @Travellexxie When you select the logistics map, you can indeed see that the route the motorhome is being directed over (blue line) is subject to a restriction for vehicles over 3,500 kg. So I agree with your finding.
          • Travellexxie
            Another tip: set the weight of your camper 1kg under the maximum weight: not 4500 but 4499. The limitations are "from" a certain weight and not "up to" a certain weight.
              Robineke
              Robineke
              Robineke
              @Rob-Verhoeff indeed it is the sign as you indicated. I am aware of truck limits over 3,5t which are not applicable for campers. This is the sign for all vehicles.
              When I come close to the route limitation it indicates."restricted route" but then it is far too late.
                Robineke
                Robineke
                Robineke
                @Travellexxie I am missing your point. The restriction if for vehicle 3,5t. This means no entry for 3,5 ton and higher.
                What will differ when I change 4500 into 4499?
                Rob Verhoeff Travellexxie 2 Replies Last reply
                • Robineke Robineke
                  @Robineke I think camper-mode has broken in one way or the other as @travellexxie mentioned...
                  • Robineke Robineke
                    @Robineke I don't think it is suitable for you (are there 4.500 limitations?idk), but here is an example: if your campers weight is max 4.500 and the limitation is 4.500, it will give you no access to these roads. You are only allowed for roads >4.500. That 1kg raise your limitation to the next step. Therefore, in your account, fill in 1kg less.
                      Robineke
                      Robineke
                      Robineke
                      @Travellexxie I got your point, I think. My camper weight is 4500kg but the road is limited to 3500kg.
                      It means that my weight is far higher then allowed so MRA should take that in account.
                      And that is not what it does only at the latest moment of entry, when I see the sign, it mentions "restricted road".
                      Unfortunately it does not provide another road and still guids me over the road which is limited to max 3500kg.
                      • Robineke Robineke
                        @Robineke like I wrote before, something must be broken. In that case you could better use the other profile.
                          I've fixed an issue regarding this routing.
                          That works immediately on the website.
                          For the app itself it will be included in the big v6 update.
                            @Corjan-Meijerink it seems fixed, but can you also bring de signs back? I see them in the truck profile, not in the camperprofile
                            Robineke Corjan Meijerink 2 Replies Last reply
                              Robineke
                              Robineke
                              Robineke
                              @Travellexxie In my routelab I see the traffic sign limitation in truck AND in camper mode.
                              Fro me this is excellent. Thanks to all for their input and (coming) update.
                                @Travellexxie Nothing changed regarding that
                                • Travellexxie
                                  That's funny, I don't. And the most funny part is (I raised my camper to 4500kg), that in the truck mode, the route still goes over the <3500 road. In Camper mode it is OK, but the sings aren't there.
                                  Camper mode
                                  Truck mode
                                    Camper mode
                                    Truck mode
                                    @Travellexxie, For truck mode automatically the logistics layer gets activated, for camper mode it does not, because many campers don't need that. Just enable the logistics layer 😉
                                      @Con-Hennekens they were there before and they should be there, how should I else know over what roads I am allowed to travel 🤷
                                        @Travellexxie Maybe you were already using the HERE Logistics overlay map, the overlay map is remembered from your last route.
                                          @Nick-Carthew no I didn't, I have used the camperprofile plenty of times during my 3 months travel through Spain and Portugal, The "weight-indicator" was there when I started this profile.
                                          Robineke
                                          Robineke
                                          • Vergrendel scherm zet alles op z'n kop
                                            3.5k
                                          • Route Breakdown
                                          • MRA 6.0.0 - 515 Carplay folder twice
                                          • How to delete favourites?
                                            3.1k
                                          • Hallo, wéér een nieuwe gebruiker !
