  2. Export assistance
  3. [Export] Garmin
  4. transfer from phone to zoom xt
24 Posts 12 Posters 679 Views 3 Watching
    @Marinus-van-Deudekom Well, that's not exactly complicated...
    I'm simply describing the standard method for transferring GPX files to a Garmin device.
    I realize there are different ways to do it, and I know how they work.
    @Peter-Zehentreiter There's alway more ways to get where you wanna go
      @Peter-Zehentreiter in my opinion unnecessary complicated. Just connect the XT to your computer. Wait until the device and sd are recognised then use the connector in MRA to export the route using the 1.2 format. Works like a charm
      Mike wiruth
      Mike wiruth
      Mike wiruth
      @Marinus-van-Deudekom What do you mean by "use the connector"? What connector are you talking about?
      Thanks,
      Mike W
      2013 Honda Goldwing
      Bushtec Trailer
      Garmin Zumo XT
      Nebraska
        @Marinus-van-Deudekom sent you a PN 😉
        BMW R 1250 GS
        DMD-NOR7E 7"
        SPC Universal mount
        Motorola Edge 40 "offline"
        Sena SLR 3
        Sena 50 R
        • John S Parry
          There are a few posts referencing SD card here. I'm not sure if some of the advice given is to use it to store routes on your XT, or not.
          My advice is to use the SD card you place in the XT slot. Simply create a Garmin/GPX folder on the card and copy your GPX file directly into it. The XT will recognize it existence, import/recalculate it, and store it for execution. The advantage is that if your route ever gets corrupted, you can quickly re-import it from the SD card and be on your way. If you import into Garmin internal storage and corruption happens, you have to go back to MRA and perform the transfer process from scratch. Admittedly, this a rare occurrence, but the one time it happened to me was at the worst possible instance. As always, plan for the worst, but hope for the best.
          In any case, a direct wired file copy (manually performed by you) from your PC/Mac to your Garmin is always the safest method. Anytime you use a transfer intermediary (Drive app, Tread app, MRA Connector), there is a possibility that the process can break. For reasons totally out of your control.
          Mike wiruth
          Mike wiruth
          J2FK
          J2FK
          mark hooton
          mark hooton
          Arno van Lochem - Senior RX
          Kobutex Motorreizen
          Kobutex Motorreizen
          • Recent trip made hard !
            Kirsten De Weerd
            Kirsten De Weerd
          • Frozen marker.
          • Kan keuze voor voertuigbeperking worden ' onthouden' ?
          • best format to download
            Guzt
            Guzt
          • Blauwe lijn en witte lijn in de navigatie ?
            2.4k
