transfer from phone to zoom xt
Im having trouble try to send a route from my samsung phone to my Garmin zoom xt nav.
I save the route as 1.0 then when prompted to export I export it then it comes up with a share tab, it did not have this option a week ago, when I press the share tab it open Garmin drive to a different screen I have not seen before. -
I save the route as 1.0 then when prompted to export I export it then it comes up with a share tab, it did not have this option a week ago, when I press the share tab it open Garmin drive to a different screen I have not seen before.@mark-hooton read it on my website, yeah it is in dutch but there is a translation button https://routes.lexwill.cyou/gps-routes-maken/#Garmin-Drive-app
Garmin have broken the Drive app for Android phone users. Register your complaint to get them to fix it. Some people have side loaded older versions of the app and turned automatic updates off. I don't think I should access an old version from a potentially iffy site. Garmin should fix it asap.
If you use the connector to transfer your routes to the Zumo, the routes are transferred correctly. Garmin is really moving towards using tracks; however, you can still add your waypoints to the track within Explore.garmin.
Currently, the connector only works on a Windows PC; hopefully, it will work on Apple PCs again with the new website. -
You really shouldn't use version 1.0; that is for Zumos from the last century. (like the Zumo 220)
For the current generation of XTs (XT/XT2/XT3), it is best to use GPX version 1.1 or 1.2, although it should be noted that 1.2 is an MRA version.
thanks for you help I have bought a carpuride for the time being as I off to the picos October.
@mark-hooton I would spend as much time as possible learning the nuances between the navigation app and Carpuride and your Garmin. Better to discover on familiar ground than whilst touring.
