  4. Favorites always visible on map
17 Posts 5 Posters 1.5k Views 3 Watching
  • Pim van Dongen
    Pim van Dongen
    Pim van Dongen
    but i want to have them always visible when making routes on my pc
    • Pim van Dongen Pim van Dongen
      well my favorites change by day because I keep on chasing old castles, viewpoints, campsites and crazy roads on google maps where I save them on...
      In that case, I’d make them ‘Points of Interest’ rather than ‘favourites’
      • Pim van Dongen
        Pim van Dongen
        Pim van Dongen
        But then they are also not always on every map and in each new route I start. Some places / campsites I often come back so it's easy to have them always visible omn the map.
          @Pim-van-Dongen
          If you select the profile icon for your POI list they will be visible in all of your routes and on your navigation app.
          • Pim van Dongen
            Pim van Dongen
            Pim van Dongen
            Then they are stil in 1 route and not in all my route files
            Nick Carthew 2 Replies Last reply
              @Pim-van-Dongen Selecting the profile icon makes that category of POIs from your POI library visible in ALL routes including when using the navigation app.
              Make your favourites into POIs and then upload them to your POI library to achieve this.
                @Pim-van-Dongen Open a new route and give it the name favourites. Now select your first favourite, now open the POI section and select the manage tab. Click Add and then click on the map where your favourite location is to add a POI at that location.
                Do this for all of your favourites, when you have finished click Save as and choose .csv (POI) as the option. This saves your POIs to your computer. Now go to the Library tab of the POI section and select Add, this opens an upload box where you can then choose the .csv (POI) file from your computer.
                • Pim van Dongen
                  Pim van Dongen
                  Pim van Dongen
                  so I have to make a specific route (without a rout but with all the waypoints) download that file as a csv and upload that one again... each time for al routes... each time I start a new route... that's not a good workflow... I just want my favourites just to be visible, also on older routes I re-use and not having to upload a csv file each time I add a new poi
                    No, that is not what I said. I said open a new route and add POIs at your favourite locations.
                    Again, this is not what I said, the process of adding POIs at your favourite locations and then saving the .csv file is so that you can upload the file to your POI library. This is a one off operation, once the .csv file is uploaded to your POI library you can then select it for individual routes or by ticking the profile icon your new POI (favourites) will be visible in all routes.
                    I can't be any clearer than that!
                    • Pim van Dongen
                      Pim van Dongen
                      Pim van Dongen
                      So but when I add a new fav location (which almost weekly happens) I again have to download a csv file and upload that file again to the poi library... what happens with the location which are allready there will they be doubled?
                      Isn't there an easy way so you can online edit that POI library
                        @Pim-van-Dongen Unfortunately, at this moment in time this is your only option. If you save the route that you created a titled Favourites you can add new POIs to it and update your library file. If there was an easier way to do it I would have explained it to you. Favourites in MRA are like bookmarks, a quick way to find a favourite location. Hopefully, we will be able to organise and put favourites into folders soon but that is not possible now.
                        • Pim van Dongen
                          Pim van Dongen
                          Pim van Dongen
                          I also heard (viavia...) that MRA is working on its POI manager... so I just wait...
                          Pim van Dongen
                          Pim van Dongen
                          • Hide warnings on the map
                          • Bollard trouble
                            Erdna
                            Erdna
                          • Library: Folders at the Top of the Menu
