  4. Auto skip many waypoints by itself while I was on route. [5.2.0 - 474]
44 Posts 11 Posters 3.1k Views 4 Watching
  • Brian McG Brian McG
    @paul69 the idea of it being the maps is only a guess not a fact
    you would need to do some testing before & after updating the maps to prove it
    paul69 Offline
    paul69 Offline
    #35
    hi @brian-mcg
    if I had the time to ride those routes again, I absolutely would especially given the weather here at the moment, but we live 200 miles apart and work gets in the way😂
    Personally I believe it was probably the maps, I agree, as as you wrote, it would need to be properly evidenced, (but TBF I am not really that bothered, this was just a chat to highlight the issue for others)
    As I wrote previously, every single one of the functional settings were exactly the same, these were checked and double checked. There is no other explanation except perhaps IOS and android work differently with regard to navigation,
    K1600 GTL
    Oukitel RT3
    iPhone 13 Pro, carpuride 702b
    • LennyO Offline
      LennyO Offline
      wrote last edited by LennyO
      #36
      So, as of now it seems we have no explanation of the core issue or any solution...
      Is somebody working on resolving it or I have missed something?
      Thanks, all!
      paul69 1 Reply Last reply
      • LennyO LennyO
        Thanks, all!
        paul69 Offline
        paul69 Offline
        @LennyO
        so it would seem, but if you are aware of it then you can pre-plan.
        think the lesson for me is, (when riding in group)
        1. ensure all have same map version
        2. ensure all settings the same
        3. compare the routes before riding off
        4. might consider all to use offline nav. (I do anyway)
        K1600 GTL
        Oukitel RT3
        Brian McG 1 Reply Last reply
        • paul69 paul69
          @LennyO
          Brian McG Offline
          Brian McG Offline
          @paul69 regards your point 3)
          a simple check I do is to check the total mileage for the trip is exactly as expected
          to do this I include the total mileage in the trip name somewhere near the start of the file name
          when I open the file, the planned mileage should equal the file name mileage
          when I start the navigation & the route is recalculated, if all is well the mileage should still be same / correct
          its not infallible as you could get a route change that adds mileage in one area, then a second route change that takes a shortcut & reduces mileage, so you end up with the 2 changes cancelling each other out
          however the odds on that are low & a mileage check should alert you to any signifiant deviations
          an advantage of thi8s mileage check is it works across devices, no matter what navigation device you are using
          if the mileages for the route do not match, at least reasonably closely, you know that the calculated route you are looking at is going to deviate somewhere along the path from the planned route
            paul69 Offline
            paul69 Offline
            hi @Brian-McG
            I used to use that tip when I had an XT after transferring routes from MRA to the XT2.
            but it's a good reminder 👍
            K1600 GTL
            Oukitel RT3
            • M. Schrijver Offline
              wrote last edited by M. Schrijver
              #40
              Today i rode the route again. Just to see if the same problem happens again. And it did. Same place same result.
              I lost cell coverage and approx 500 meters later, point 42 was skipped to point 56.
              See the result in the screenshot below
                Marinus van Deudekom Offline
                @M.-Schrijver send me a link to that route and if you want me to I'll have a look at it
                  The same as on the first page:
                  https://www.myrouteapp.com/nl/social/route/14017569?mode=share
                    #43
                    Approx. at point 1 i lost my cell coverage.
                    At point 2 I heard and saw the auto skipping to point 56
                    This was in the town center of Uelsen
                    • Ronnie Moore Online
                      Ronnie Moore Online
                      Ronnie Moore
                      Jumping waypoints has been an issue for me for a while. I've had the issue with it skipping waypoints over several versions since the rewrite.
                      I have skipping waypoints and rerouting turned off.
                      I've noticed it when I'm doing a loop and an early waypoint and a later waypoint are nearby ~20 miles. It will jump to that point and not give any warning until it starts trying route me to the later point. I hadn't noticed the status of cell coverage but most areas I ride have poor coverage.
                      I made a forum post a while back and didn't get much response so thought it might be specific to my setup.
                      https://forum.myrouteapp.com/topic/10753/app-skips-waypoints-even-thought-skipping-waypoints-is-turned-off?_=1788917858054
                      Ronnie Moore
                      Ronnie Moore
                      stuart marritt
                      stuart marritt
                      Reid Squier
                      Reid Squier
                      • Welke instelling
                      • Bug: snelweg vermijden opheffen na wegvallen verbinding? + vraagje gpx file
                      • Planned routes not available during lack of Internet connection
                      • nieuwe Belgische gebruiker
