  2. Export assistance
  3. [Export] Garmin
  4. GPX1.2 & Garmin Tread
6 Posts 4 Posters 266 Views 1 Watching
  • Carl Lee Offline
    Carl Lee Offline
    Carl Lee
    wrote last edited by Carl Lee
    The latest Tread update 3.01.27 for iOS now does not calculate GPX1.2 again. The previous version did.
    Has anyone else noticed this and discovered a workaround? I have logged a ticket both through Tread mapping issues and Garmin customer support. To say I am disappointed is an understatement.
    I realise this is probably more of a Garmin issue, but it involves an MRA specific file.
    Thank you.
    • Carl Lee Carl Lee
      Thank you.
      John S Parry Offline
      Thank you.
      The only file transfer that works 100% of the time is manually copying the GPX file to your Garmin device. Tread has and always will be a potential problem. It's not what you want to hear, but the reality of the situation.
      • Carl Lee Offline
        Carl Lee Offline
        Carl Lee
        @john-s-parry yes, you’re right and I do copy files on to my SD card. 1.2 files still work that way without being corrupted by Tread. I’ve checked and even though what syncs to Tread looks wrong, the route in the XT2 calculates and remains true.
        It’s another string to the bow that has snapped. Again!
        • MTC-Zeilberg Offline
          MTC-Zeilberg
          Works fine here, no problems
          • Carl Lee Offline
            Carl Lee Offline
            Carl Lee
            @mtc-zeilberg are GPX1.2 files still being calculated by Tread for you? If so, are both your apps fully up to date?
            I've logged a ticket here and with Garmin who made me jump through several hoops before they would investigate.
            • Danny 1d Offline
              Danny 1d Offline
              Danny 1d
              Hier hetzelfde probleem 3 weken terug werkte plots alles perfect GPX1.2 openen in Tread zonder dat deze de route veranderde overzetten naar de XT2 route openen en rijden ook inclusief harde punten. Nu na update zowel XT2 en Tread app werkt het niet meer de route (GPX1.2) veranderd nog steeds niet in de Tread app maar de XT2 kan het bestand niet meer berekenen en start bij berekening telkens terug op.
              Danny 1d
              Danny 1d
              Carl Lee
              Carl Lee
              MTC-Zeilberg
              MTC-Zeilberg
              • Rondrit maken lukt niet
              • Vormingspunten richtingsindicator
                Jan Jans Gold 0 0
                Jan Jans Gold 0 0
              • status quo: progress regarding map spinning resolvement
                peha
                peha
              • Geen zoekresultaten bestemmingen android auto
              • Update 5.2.2 - Quick fix
              • Omweg door afgesloten weg
              • Graag sneller alternatieve route bij wegafsluiting
