  4. POI naming/text display
4 Posts 3 Posters 48 Views 3 Watching
  • Adrian Avram Offline
    Since the app received the update with the new POI functionality, I tried yesterday to create a route using some of my stored POIs. However, the problem is that while you can see a lot of POIs on the map, you cannot see their names or click on a specific POI to view its information.
    I think it would be great if the POI name could be displayed below the POI icon, or if you could tap on a POI to view its details. This would make route planning much easier when using the stored POI database (The same should be with saved favorite places).
    Thanks!
    Adrian
    • Hubert Thoring Offline
      For this you can better switch to the route lab, there it works very well, I also do that on the iPad or iPhone.
      The POI text can be displayed and the POI can also be inserted into the route.
      The click on the cross opens the menu, but the click always puts the POI at the end of the route. After that, you can easily move the WP / SP in the WP list to the right place.
      Tip:
      It is easier to set your own WP/SP at the POI, which also works well if you want to insert something somewhere in the route. Click on the route then comes the + and a SP, which then pull to the right place...
      Dazu kannst Du besser ins Routenlabor wechseln, dort geht das sehr gut, das mache ich auch am iPad oder iPhone.
      Da lässt sich der POI Text anzeigen und der POI auch in die Route einfügen.
      Der Klick auf das Kreuz öffnet das Menü, der Klick setzt den POI allerdings immer ans Ende der Route. Danach kann man den WP / SP in der WP Liste aber auch leicht an die richtige Stelle verschieben.
      Tipp:
      Einfacher ist es am POI einen eigenen WP/SP setzen, das geht auch gut wenn man irgendwo in der Route noch was einfügen möchte. Klick auf die Route dann kommt das + und ein SP, den dann an die richtige Stelle ziehen…
      iPad 9. Gen iOS 26.6/ iPhone 16e iOS 26.6/ Navi iPhone Xr iOS 18.7.9 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
      • Adrian Avram Adrian Avram
        Thanks!
        martin-phogel.de Offline
        martin-phogel.de
        @Adrian-Avram
        100% agree!
        And an option to add a POI to the route (as a POI) so we can use “Export gpx 1.1 (Track, POI)” right out of the App without having to switch to RouteLab.
          Tip:
          Tipp:
          It would be nice to have this function in the App Planner also !
          Adrian
          martin-phogel.de
          martin-phogel.de
          • POI naming/text display
          • Stemgeluid sterker bij afspelen muziek
          • Onbegrijpelijke afslagen
          • GPX1.2 & Garmin Tread
            MTC-Zeilberg
            MTC-Zeilberg
          • Folders that can store tracks and waypoints
            martin-phogel.de
            martin-phogel.de
