  4. Auto skip many waypoints by itself while I was on route. [5.2.0 - 474]
46 Posts 12 Posters 7.3k Views 4 Watching
  • RetiredWingMan
    Went out for a 400km ride today. Everything worked great. Did a detour manually due to construction. MRA attempted to reroute me 4 times and then skipped a waypoint and I was back on route. Maybe next time I'll try the new feature for devouring around construction.
    • paul69 paul69
      hi @stuart-marritt said:
      The next issue we need to figure out is why sometimes 2 people in the group end up with a different route than the one that was planned!
      sorry this has nothing to do with the OP, just thought I'd comment on the above.
      funnily enough, I had this issue during the last weekend. me and a ridding buddy spent two days in lakes, I planned the routes on my computer, and as usual I always use the compare tool to make sure there are no nasty surprises.
      My friend accessed the routes through the friends tab, both our devices are set up the same way in settings, although mine does not have internet as no SIM card, so obviously offline navigation. Android on rugged tablet.
      He uses his phone iPhone 16 using NN also with offline navigation enabled.
      when we compared the routes on our devices, both of the routes had changed on his, not a huge amount, but enough to make it like the red arrows at some junctions. some of the waypoints for him were skipped and others tried to get him to go back, did not happen on mine.
      I could not understand the reason for this, I checked all settings and everything was exactly the same.
      I think it might be something to do with internet access even tho offline nav is enabled, this is the only difference in our set up, save for android and IOS.
      it did not spoil the rides as we were aware of the parts where NN would try to send him a different way.
      @paul69 did you both have the same version of offline maps loaded?
      if the underlying map data is different then the routing calculation between points could calculate differently
      what happens if you set both devices to ride the paths as a track?
      paul69 1 Reply Last reply
      • Brian McG Brian McG
        hi @Brian-McG
        thanks for the map tip, TBH that was the one thing I did not check, but the roads we were on are well established and have never changed in many years.
        We were riding routes as routes.
        I had thought of changing it to "as tracks" although as I wrote it did not cause any riding issues, as we were aware of the discrepancies.
        It was more about pointing out the issue, as the one which had changed had Internet access, but offline nav enabled.
        it may be a useful point for anyone else if they come across this issue when riding in groups, which I guess would be better for everyone to use tracks.
        One point on that, when I select this option, I always get the "go online for better track navigation" or words to that effect, can't remember off hand. My NN is on a tablet with no SIM card, therefore never any internet access.
        K1600 GTL
        iPhone 13 Pro, carpuride 702b
        LennyO Brian McG 2 Replies Last reply
        • paul69 paul69
          hi @Brian-McG
          @paul69 By definition, calculated route when offline, may not be exactly the same as you planned.
          And the fact that the only people who had it different are the ones using the offline navigation kind of proves it.
          Also, did they have "Navigate routes as tracks" selected?
          Thx!
            There is a simple solution to these issues!
            Turn off auto skip waypoints!
            A better solution. Use no points at all.
            stuart marritt
            stuart marritt
            stuart marritt
            Well its not!
            You plan a route to go where you want to go and not let the navigation decide
            • paul69 paul69
              hi @Brian-McG
              @paul69 the roads may well be established but if one of the sets of map data contains data about a road being impassable i.e. closed for construction or if the map data weights a road with a different average speed then the calculation of route could possibly result in a different being calculated
              • LennyO LennyO
                Thx!
                hi @LennyO
                not entirely sure what you mean here. Why would it calculate an already planned route. The routes are planned on the MRA website and automatically sync to the devices when NN opened, my routes do not change when I use NN, (lets not discuss seasonal closures etc)
                the one with internet access had the route changed on their device, not mine (without Internet), for me the route remained as we had planned on the laptop, we both had offline navigation enabled in settings
                did not have routes as tracks.
                K1600 GTL
                LennyO 1 Reply Last reply
                  suppose that's a fair point, one to remember for the future when arranging rides with others.
                  TBF this can be the only explanation as nothing else would explain it.
                  Take note all who read this, forget about the online, offline, internet or no internet, debacle, check your maps, obviously before you leave home on your trips with your mates 😂
                  K1600 GTL
                  • paul69
                    hi @brian-mcg
                    just thought I'd give you a quick update. I checked with my riding buddy and yes you are correct, his version was quite a few updates behind. It did not occur to me to even check if he had done this.
                    I thought I was quite an experienced user of MRA, but it shows there is always something to learn.
                    Complete School boy error but not too proud to admit it 😂
                    I imagine this will be a good reminder for people to check the map versions.
                    K1600 GTL
                    Brian McG 1 Reply Last reply
                    • paul69 paul69
                      hi @LennyO
                      #33
                      @paul69 said:
                      hi @LennyO
                      @paul69 I say that because you or your friends may have options selected in the Functional preferences that adjust the route based on the real time road work or traffic conditions.
                      That also answers the second half of my previous post.
                      • paul69 paul69
                        hi @brian-mcg
                        @paul69 the idea of it being the maps is only a guess not a fact
                        you would need to do some testing before & after updating the maps to prove it
                          #35
                          hi @brian-mcg
                          if I had the time to ride those routes again, I absolutely would especially given the weather here at the moment, but we live 200 miles apart and work gets in the way😂
                          Personally I believe it was probably the maps, I agree, as as you wrote, it would need to be properly evidenced, (but TBF I am not really that bothered, this was just a chat to highlight the issue for others)
                          As I wrote previously, every single one of the functional settings were exactly the same, these were checked and double checked. There is no other explanation except perhaps IOS and android work differently with regard to navigation,
                          K1600 GTL
                          • LennyO
                            #36
                            So, as of now it seems we have no explanation of the core issue or any solution...
                            Is somebody working on resolving it or I have missed something?
                            Thanks, all!
                            • LennyO LennyO
                              Thanks, all!
                              @LennyO
                              so it would seem, but if you are aware of it then you can pre-plan.
                              think the lesson for me is, (when riding in group)
                              1. ensure all have same map version
                              2. ensure all settings the same
                              3. compare the routes before riding off
                              4. might consider all to use offline nav. (I do anyway)
                              K1600 GTL
                              • paul69 paul69
                                @LennyO
                                @paul69 regards your point 3)
                                a simple check I do is to check the total mileage for the trip is exactly as expected
                                to do this I include the total mileage in the trip name somewhere near the start of the file name
                                when I open the file, the planned mileage should equal the file name mileage
                                when I start the navigation & the route is recalculated, if all is well the mileage should still be same / correct
                                its not infallible as you could get a route change that adds mileage in one area, then a second route change that takes a shortcut & reduces mileage, so you end up with the 2 changes cancelling each other out
                                however the odds on that are low & a mileage check should alert you to any signifiant deviations
                                an advantage of thi8s mileage check is it works across devices, no matter what navigation device you are using
                                if the mileages for the route do not match, at least reasonably closely, you know that the calculated route you are looking at is going to deviate somewhere along the path from the planned route
                                  hi @Brian-McG
                                  I used to use that tip when I had an XT after transferring routes from MRA to the XT2.
                                  but it's a good reminder 👍
                                  K1600 GTL
                                    #40
                                    Today i rode the route again. Just to see if the same problem happens again. And it did. Same place same result.
                                    I lost cell coverage and approx 500 meters later, point 42 was skipped to point 56.
                                    See the result in the screenshot below
                                      @M.-Schrijver send me a link to that route and if you want me to I'll have a look at it
                                        The same as on the first page:
                                        https://www.myrouteapp.com/nl/social/route/14017569?mode=share
                                          #43
                                          Approx. at point 1 i lost my cell coverage.
                                          At point 2 I heard and saw the auto skipping to point 56
                                          This was in the town center of Uelsen
                                          ErikMatthezing 1 Reply Last reply
                                          ErikMatthezing
                                          ErikMatthezing
                                          Ronnie Moore
                                          Ronnie Moore
                                          stuart marritt
                                          stuart marritt
                                          Reid Squier
                                          Reid Squier
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
                                          • Download club route folders
