  4. Reading out the name of the waypoint and associated notes
43 Posts 10 Posters 7.5k Views 6 Watching
  • Brian McG Brian McG
    @Lenny-O maybe try this
    instead of adding Notes to a waypoint that has an address with number in it that you don’t want to hear
    delete the address & add your Note text to the waypoint name field
    just put a full stop or some other single character in the Notes field, this point will then definitely be read out even if your text has a number in it
    more often than not other points you create will have automatically have number in the name, like the post/area code, & these will not be read out because they contain a number
    adding a number to the name of point will silence the announcement, if there is nothing in the notes field
    This is the method I use so I can selectively get the points I want to be read out & also not hear the ones I don’t care about
    adding a number to the name of point will silence the announcement, if there is nothing in the notes field.
    This where something goes wrong. At least for me.
    For "Waypoint Notifications" you can choose between: Off, Via and All.
    I have "All" selected because i want to hear the Notes and on purpose selected names connected to a Shaping point because i don't use Viapoints.
    But in my case with this setting i hear 98% of what is mentioned in the name field of a waypoint.
    Like: "You reached waypoint 9" or "You reached Voorstraat 9 8021 BB Zwolle" or whatever MRA routeplanner by itself put in that namefield.
      I’m not persuaded by either argument, my concern is another setting to choose from which adds yet another level of complexity. The manual for the app is going to end up as thick as War and Peace!
      #22
      @Nick-Carthew Nick, this particular one is super small and easy.
      And if we worry about the size of the manual, then all development has to stop... no? 🤔
      To be honest, I don't think we have a single user who read the whole manual.
      It most likely is a reference for people to "learn as they go" or have issues kind of thing.
      And as you already read all of the above comments, you must see all the various acrobatics and extra work that people have to perform in order to achieve a simple, logical, needed convenience of hearing only the important and relevant information as they navigate... and resolving this is very easy from the programming standpoint, making the App so much more useful.
      But hey, what do I know 🙂
        For me it is fine that Via points cannot be skipped automatic. I don't like that feature but i'm not obligated to use Viapoint when planning.
        @con-hennekens You say, when the name field of a waypoint meet some terms, it is not being announced. I can tell you there is something wrong with those terms or how those terms are implemented.
        When i make a route. All my default (blue) waypoints have their default name given by the MRA Planner. 98% of them are being announced in de navigation. It can be an address but also just a waypoint number.
        @M.-Schrijver, yes they are announced, if you have that enabled, but what I meant is that the name of a waypoint is not being spoken if it contains numerical characters (indicating an address) AND the note field is empty. They do get announced indeed, but only with: "Route point xx has been reached" (or similar wording).
        Peter Zehentreiter LennyO 2 Replies Last reply
          Since I manually move each waypoint on every route to align it exactly with the line, the waypoint's address is accompanied by numbers during this maneuver.
          I can confirm what Con said... the only message given is “Waypoint xx reached.”
            Hi, Con!
            Not arguing, just please help me out here. What is the significance of this announcement in general?
            I would expect a user to know approximately where they are, and if one needs to know the next waypoint - it is right there, in the upper right corner of the screen. 😜
            I, personally, would much prefer the meaningful info that I set up to hear, instead of unwanted info forced upon me that constantly interruptions my conversation with the group or music I am listening to.
            Thanks, buddy!
            • LennyO LennyO
              Hi, Con!
              Thanks, buddy!
              Exactly that is what you get of you alter the name or fill the notes field 😉
              Also I find it reassuring to hear that I reached a waypoint every now and then. If it gets annoying, you probably use too many waypoints? If you do not want to hear the announcements, you can disable it for shaping points, but you will need to turn route points with extra info into VIA points to hear them on the road. So there is plenty to choose from.
              • LennyO LennyO
                I think it should be quite easy to implement the distinction between the points having Notes and the ones that do not for read-outs. (I am a retired IT programmer).
                Another super annoying thing when it reads out ALL shaping points is that it first reads out the location of the waypoint, and I mean FULL ADDRESS, including the Country and the postal code..... before it actually reads the Notes.
                To prevent that you'd have to rename or blank out the address of EVERY shaping point, which is crazy 🙂
                So, in combination the great, needed and very usefull feature is not used by many because of not being "user-friendly" (as we call it in the IT world).
                In the settings, you can select, if a newly entered waypoint should have the full postal address or not. If not, you can leave it blanc, than it will not be audible...
                LennyO 1 Reply Last reply
                • Guzzist Guzzist
                  @Guzzist Thank you! What setting is that, please?
                  Peter Zehentreiter Leike Lodiers Guzzist 3 Replies Last reply
                  • LennyO LennyO
                    @Lenny-O I think he's referring to the editor settings in the toolkit on the website.
                    There's an option there......Ask for the route point name.
                    If you enable this option, when you place the waypoint, you can choose whether to keep the default name, assign a name of your choice, or delete everything right away.
                      @Peter-Zehentreiter With that option if you just highlite the address and Delete it, it goes into a stupor...
                      Seems like you have to actually hit the space bar at least once for it to take the empty address / name.
                      • LennyO LennyO
                        #31
                        • LennyO LennyO
                          @Lenny-O Just highlight the text provided, enter any number, and then click “Accept.”
                          That way, when you're navigating, you should only hear the prompt... “Waypoint xx reached.”
                          • Leike Lodiers Leike Lodiers
                            [[topic:post-is-deleted]]
                            • Leike Lodiers
                              #34
                              • LennyO LennyO
                                #35
                                If you enter a new waypoint in MRA-Routeplanner, it will be set without any comment:
                                If you click onto the waypoint icon, you will see the name of it:
                                but goto "Page menue", scroll down to "Editor settings", select "Ask for waypoint name":
                                then if you enter a new waypoint, there comes a popup, showing the postal address of this waypoint as suggestion. But you can simply delete it by hit the blanc space key. Then the waypoint will not have a name anymore:
                                • MotoCon
                                  Just to be clear: In this case:
                                  The name will not be spoken (if the note field is empty), since any numerical character in that field will indicate it as an (uninteresting) address. Only the "Waypoint xx reached" messagage will be audible. Therefore it is unnecessary to put a space in the name field instead.
                                    Absolutely correct!
                                    Yet, I still see zero value in this announcement. Do you see ANY value in it ?
                                    I am trying to come up with the scenario where it would be useful, but can not so far...
                                    • LennyO LennyO
                                      Absolutely correct!
                                      #38
                                      @Lenny-O no and yes. yes because the spoken instructions are then consistent with the UI. I would not like to see a solution which only omits the spoken message, as I would like to see the ETA info and the display on the map being omitted as well.
                                        @Herman-Veldhuizen Hi, Herman!
                                        I am sorry, but you lost me.... would you please clarify what you mean.
                                        I am referring specifically to zero value in my mind for the "Waypoint xx reached" announcement, not what you see on the screen.
                                        • LennyO LennyO
                                          @Lenny-O i would find it confusing if some shaping points would not be announced, while being visible.
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
