Move blocks of routepoints
When creating a route that stays in a singular area, or creating off-road tracks, and you want to re-arrange things, it can get pretty messy pretty quickly when you need to move each point at a time. It would be awesome if you could re-arrange a complete block of multiple points in a single go.
Either via a multi-select and drag or a little like how the split function works, select start and end-point and select where you want to push the selected block to.
For example, this block are basically all 'skipped' points, this works to create a track on unpaved roads that are ignored by the algorithms, but now I want those 24 points in another 'section' of my complete track/route.
@Yannick_van_Vugt what you're asking is pretty much impossible given the position of all those shaping points in your example
@Marinus-van-Deudekom It's the recommended way to create tracks on unpaved roads. Not my idea.
@Yannick_van_Vugt that's true.
But it creates a problem when you want to replace you're route to a other road. I think to help you're self, don't place to many way point to follow the offroad way. Choose the most critical point on the way so when you see a crossing or split of the way place one there . You don't need to follow the whole way with waypoint. -
But it creates a problem when you want to replace you're route to a other road. I think to help you're self, don't place to many way point to follow the offroad way. Choose the most critical point on the way so when you see a crossing or split of the way place one there . You don't need to follow the whole way with waypoint.@Leike-Lodiers It is nice to have and there is no reason not to. Except for the fact that if you want to move a whole block of routepoints.
Same could be said if you have a lot of little towns and you want to change that order by a block of points. It is not really an unnecessary feature, I called it "move" in my primary post, but it would also be great if a multi-select could be done to delete a big part of the route.
Yes, that last suggestion does seem like a good option to me. Selecting multiple points to delete them all at once. At the moment, if I want to change part of the route, I have to delete each point in that section individually. It would be easier if I could delete those route points all at once. And it would be even better if you could then see the selected section with the route points on the map as well!
