  4. Move blocks of routepoints
17 Posts 7 Posters 475 Views 3 Watching
  • Yannick_van_Vugtundefined Offline
    Yannick_van_Vugt
    wrote last edited by Yannick_van_Vugt
    When creating a route that stays in a singular area, or creating off-road tracks, and you want to re-arrange things, it can get pretty messy pretty quickly when you need to move each point at a time. It would be awesome if you could re-arrange a complete block of multiple points in a single go.
    Either via a multi-select and drag or a little like how the split function works, select start and end-point and select where you want to push the selected block to.
    For example, this block are basically all 'skipped' points, this works to create a track on unpaved roads that are ignored by the algorithms, but now I want those 24 points in another 'section' of my complete track/route.
    📷: YannickvanVugt | 🏍️: DutchTransalp
    Marinus van Deudekomundefined Brian McGundefined 2 Replies Last reply
    • Yannick_van_Vugtundefined Yannick_van_Vugt
      @Yannick_van_Vugt what you're asking is pretty much impossible given the position of all those shaping points in your example
      Yannick_van_Vugtundefined 1 Reply Last reply
        Yannick_van_Vugt
        @Marinus-van-Deudekom It's the recommended way to create tracks on unpaved roads. Not my idea. 🙂
        Leike Lodiersundefined 1 Reply Last reply
          @Yannick_van_Vugt that's true.😁 😁 But it creates a problem when you want to replace you're route to a other road. I think to help you're self, don't place to many way point to follow the offroad way. Choose the most critical point on the way so when you see a crossing or split of the way place one there . You don't need to follow the whole way with waypoint.
          • Leike Lodiersundefined Leike Lodiers
            Yannick_van_Vugt
            @Leike-Lodiers It is nice to have and there is no reason not to. Except for the fact that if you want to move a whole block of routepoints.
            Same could be said if you have a lot of little towns and you want to change that order by a block of points. It is not really an unnecessary feature, I called it "move" in my primary post, but it would also be great if a multi-select could be done to delete a big part of the route.
              white.mouseundefined Offline
              Yes, that last suggestion does seem like a good option to me. Selecting multiple points to delete them all at once. At the moment, if I want to change part of the route, I have to delete each point in that section individually. It would be easier if I could delete those route points all at once. And it would be even better if you could then see the selected section with the route points on the map as well!
              • David Joblingundefined Offline
                David Jobling
                I'd like to see a way to work on a group of waypoints too. Some of my routes are figure 8 or cloverleaf and I like to reverse (or remove) sections of the route to keep it interesting. If we could select a group of waypoints in the list, then delete / reverse / move them, I'd be very happy 🙂
                • David Joblingundefined David Jobling
                  Yannick_van_Vugt
                  You get my exact idea. 😌👌🏻
                  Feels like a basic feature that should’ve always been there.
                  • Jörgenundefined Offline
                    I don't quite understand the point of moving multiple waypoints. That would cause all the geographic coordinates to shift at the same time, which would result in an uncontrolled track.
                    Just a copy/paste sample
                    Copying multiple waypoints to use them in a new route makes more sense.
                      I think group delete will be fine.
                      Moving will indeed be not possible.
                        I agree, copy and delete.
                        • Jörgenundefined Jörgen
                          Yannick_van_Vugt
                          It’s not about moving them physically, it’s about moving them in order in the list of routepoints. Have you guys even read the thread properly? Change them from 59-84 to let’s say 20-45 in a single go.
                            @Yannick_van_Vugt Yes I have but want you want is not possible at all
                              David Jobling
                              It shouldn't be too difficult? We can do it now, one-by-one (but it is slow and can be confusing, and MRA recalculates for each waypoint), I'd just like to work on several adjacent points at the same time.
                                Brian McGundefined Offline
                                  Yannick_van_Vugt
                                  @Marinus-van-Deudekom Currently it isn't, that's why I brought it on as a suggestion. Right?
                                  Other see the value of my request, I understand you don't, but if it ain't valuable to you, or you don't use the tool in a certain way, doesn't mean it's not for someone else.
                                  @Brian-McG Yes, possible, but that shouldn't be needed and is devious work. It also floods the database and back-end with splits and merges, that will later be deleted. This feature is will prevent that as well.
                                    Yannick_van_Vugt
                                    David Jobling
                                      Mzokkundefined
                                      3.0k
                                    • Quad lock (or other) Phone mount ?
                                      LennyOundefined
                                    • Move blocks of routepoints
                                      Yannick_van_Vugt
                                    • Download itn,gpx etc on android app - Folder location
                                    • Seasonal closures affect not only seasonal road closures (mountain passes and the like) but also closures due to roadworks. This is why the route takes you through the closure even during planning, even though Here is actually aware of it.
                                      LennyOundefined
                                    • v5.2 (473) Feedback
                                      C.A. Kielenundefined
                                      C.A. Kielen
                                    • MRA V5.2.1 (486) Photo in the track recording is rotated; photo orientation is ambiguous.
