  4. Move blocks of routepoints
21 Posts 7 Posters 2.2k Views 2 Watching
  • David Jobling
    David Jobling
    David Jobling
    I'd like to see a way to work on a group of waypoints too. Some of my routes are figure 8 or cloverleaf and I like to reverse (or remove) sections of the route to keep it interesting. If we could select a group of waypoints in the list, then delete / reverse / move them, I'd be very happy 🙂
    Yannick_van_Vugt 1 Reply Last reply
    • David Jobling David Jobling
      Yannick_van_Vugt
      Yannick_van_Vugt
      Yannick_van_Vugt
      You get my exact idea. 😌👌🏻
      Feels like a basic feature that should’ve always been there.
      📷: YannickvanVugt | 🏍️: DutchTransalp
        I don't quite understand the point of moving multiple waypoints. That would cause all the geographic coordinates to shift at the same time, which would result in an uncontrolled track.
        Just a copy/paste sample
        Copying multiple waypoints to use them in a new route makes more sense.
          I think group delete will be fine.
          Moving will indeed be not possible.
            I agree, copy and delete.
              Yannick_van_Vugt
              Yannick_van_Vugt
              Yannick_van_Vugt
              It’s not about moving them physically, it’s about moving them in order in the list of routepoints. Have you guys even read the thread properly? Change them from 59-84 to let’s say 20-45 in a single go.
              • Yannick_van_Vugt Yannick_van_Vugt
                @Yannick_van_Vugt Yes I have but want you want is not possible at all
                • David Jobling
                  David Jobling
                  David Jobling
                  It shouldn't be too difficult? We can do it now, one-by-one (but it is slow and can be confusing, and MRA recalculates for each waypoint), I'd just like to work on several adjacent points at the same time.
                  • David Jobling
                    David Jobling
                    David Jobling
                    Simple example of the request (hoping the image uploads OK): I want to do waypoints 6-7-8-9 before 2-3-4-5. Secondly, I'd like to reverse 6-7-8-9 (only) without changing the rest of the route.
                    Reason: I do some routes twice a year, wonderful roads, I like to vary the sequence / direction to keep it interesting 🙂
                      When creating a route that stays in a singular area, or creating off-road tracks, and you want to re-arrange things, it can get pretty messy pretty quickly when you need to move each point at a time. It would be awesome if you could re-arrange a complete block of multiple points in a single go.
                      Either via a multi-select and drag or a little like how the split function works, select start and end-point and select where you want to push the selected block to.
                      For example, this block are basically all 'skipped' points, this works to create a track on unpaved roads that are ignored by the algorithms, but now I want those 24 points in another 'section' of my complete track/route.
                        Yannick_van_Vugt
                        Yannick_van_Vugt
                        Yannick_van_Vugt
                        @Marinus-van-Deudekom Currently it isn't, that's why I brought it on as a suggestion. Right?
                        Other see the value of my request, I understand you don't, but if it ain't valuable to you, or you don't use the tool in a certain way, doesn't mean it's not for someone else.
                        @Brian-McG Yes, possible, but that shouldn't be needed and is devious work. It also floods the database and back-end with splits and merges, that will later be deleted. This feature is will prevent that as well.
                        Brian McG Marinus van Deudekom 2 Replies Last reply
                            Its not that I dont want to use such a tool. I just think that its just impossible
                              @yannick_van_vugt , even in the translation, your suggestion isn't 100% clear; it's only after David's explanation that things become clear. (lost in translation) 😉
                              Now I understand the suggestion. You kept talking about moving multiple waypoints. I always thought you were referring to the map.
                              Saying “moving within the ‘Waypoint List’” would have helped me understand it right away.
                              If, perhaps, there’s a feature in the future to delete or copy multiple waypoints, it should also be possible to move multiple waypoints (within the waypoint list). I vote for this.
                                Yannick_van_Vugt
                                Yannick_van_Vugt
                                Yannick_van_Vugt
                                @Jörgen After reading my post again, I get what you mean. I mention re-arrange and 'section' of route, for me that felt clear when I wrote it. It was never about changing their physical location on the map, of course, when there is no street or path, it would be useless to place a marker there.
                                Yannick_van_Vugt
                                Yannick_van_Vugt
                                David Jobling
                                David Jobling
                                • Help please, new user
                                  Bull Tahr
                                  Bull Tahr
                                • My Routeapp Stays questions
                                • MRA 6.0.0 (515) Live Tracking - What exactly is shared?
