  4. MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app.
9 Posts 5 Posters 88 Views 3 Watching
    Hey dear MRA team,
    If a route has been planned in the route laboratory and some own POIs have been selected in the own POI library, these will also be displayed on the map later in the route.
    However, if you deliberately turn them off in the MRA app under POI groups, this does not really apply, if you leave the route in the app and open it again, the POI from the planning of the route lab will apparently come back to the map.
    I think this is still a small error in the synchronization between WebPlaner and the app or ?
    It is apparently not synchronized cleanly .... so my impression, today when creating a route.
    VG
    • Marinus van Deudekom
      The purpose of those POI's is to have them visible in your route. It would be strange is they wouldn't
        @marinus-van-deudekom
        But you also want to be able to turn them off in a defined way as you need it and that is apparently not being taken over cleanly at the moment.
          @Hubert-Thoring of you dont need that POI simply delete it
            It are separate settings.
            By design.
            Won't sync.
              @Hubert-Thoring, no it is not synced indeed. It's best to remove the profile setting on all categories of POI in the web planner. You can still use the local checkmark for visibility in the planner. Then you can select and deselect all POI categories for visibility from the app itself.
              Hubert Thoring Dave J 0 2 Replies Last reply
                By design.
                Won't sync.
                Thanks for the info, I think it will be able to come later with the WebPlaner Update 2.0.
                Thank you 🙏
                  Thanks, good to know, this is then a possible temporary solution.
                  VG 👋
                    Exactly what I have done @Con-Hennekens. Not sure that i really want the POI view synced across devices/platforms. Quite like the way it is.
                    Ducati Multistrada V4 Rally
                    iPhone 15 Pro
                    CHIGEE AIO-6 LTE
                    • Routenplaner on iPad
                    • New Zealand Routes
                      Bull Tahr
                      Bull Tahr
                      J2FK
                      J2FK
                    • MyRouteApp (WebPlanner) development Roadmap
                      Philipp Kühn
                      Philipp Kühn
                      6.2k
