<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app.]]></title><description><![CDATA[<p dir="auto">Hey dear MRA team,</p>
<p dir="auto">If a route has been planned in the route laboratory and some own POIs have been selected in the own POI library, these will also be displayed on the map later in the route.</p>
<p dir="auto">However, if you deliberately turn them off in the MRA app under POI groups, this does not really apply, if you leave the route in the app and open it again, the POI from the planning of the route lab will apparently come back to the map.</p>
<p dir="auto">I think this is still a small error in the synchronization between WebPlaner and the app or ?</p>
<p dir="auto">It is apparently not synchronized cleanly .... so my impression, today when creating a route.</p>
<p dir="auto">VG</p>
]]></description><link>https://forum.myrouteapp.com/topic/11339/mra-5.2.1-480-pois-that-were-set-in-the-route-lab-remain-in-the-route-and-cannot-be-switched-off-in-the-app.</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 14:36:00 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11339.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Jul 2026 16:56:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app. on Thu, 16 Jul 2026 11:41:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hubert-thoring" aria-label="Profile: Hubert-Thoring">@<bdi>Hubert-Thoring</bdi></a>, no it is not synced indeed. It's best to remove the profile setting on all categories of POI in the web planner. You can still use the local checkmark for visibility in the planner. Then you can select and deselect all POI categories for visibility from the app itself.</p>
]]></description><link>https://forum.myrouteapp.com/post/81006</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/81006</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Thu, 16 Jul 2026 11:41:44 GMT</pubDate></item><item><title><![CDATA[Reply to MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app. on Thu, 16 Jul 2026 07:34:14 GMT]]></title><description><![CDATA[<p dir="auto">It are separate settings.<br />
By design.<br />
Won't sync.</p>
]]></description><link>https://forum.myrouteapp.com/post/80980</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80980</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Thu, 16 Jul 2026 07:34:14 GMT</pubDate></item><item><title><![CDATA[Reply to MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app. on Thu, 16 Jul 2026 06:37:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hubert-thoring" aria-label="Profile: Hubert-Thoring">@<bdi>Hubert-Thoring</bdi></a> of you dont need that POI simply delete it</p>
]]></description><link>https://forum.myrouteapp.com/post/80975</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80975</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Thu, 16 Jul 2026 06:37:37 GMT</pubDate></item><item><title><![CDATA[Reply to MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app. on Thu, 16 Jul 2026 05:45:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marinus-van-deudekom" aria-label="Profile: marinus-van-deudekom">@<bdi>marinus-van-deudekom</bdi></a><br />
But you also want to be able to turn them off in a defined way as you need it and that is apparently not being taken over cleanly at the moment.</p>
]]></description><link>https://forum.myrouteapp.com/post/80972</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80972</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Thu, 16 Jul 2026 05:45:03 GMT</pubDate></item><item><title><![CDATA[Reply to MRA 5.2.1 (480] POIs that were set in the route lab remain in the route and cannot be switched off in the app. on Wed, 15 Jul 2026 18:05:15 GMT]]></title><description><![CDATA[<p dir="auto">The purpose of those POI's is to have them visible in your route. It would be strange is they wouldn't</p>
]]></description><link>https://forum.myrouteapp.com/post/80956</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80956</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Wed, 15 Jul 2026 18:05:15 GMT</pubDate></item></channel></rss>
