  4. Suggestion for mobile app (battery saver)
battery saverbatterymobile app
15 Posts 6 Posters 534 Views 3 Watching
  • KevN1k 0undefined KevN1k 0
    @Brian-McG i think you misunderstood how it works, way before you'll need to make any turns the screen will come back to the map. It doesn't stay black for the whole trip, only between turns that are longer than X between each. Get the app, try it and you'll see for yourself.
    Brian McGundefined Offline
    @KevN1k-0 I think you misunderstand šŸ˜‚
    the app can only change back to the map when it knows IF there is a turn coming
    very often the map data does not tell the app there is a turn on the route because the map data is bad or incorrect
    the only way you know there is an unreported turn is if you can see the map
    this happens a lot on very small rural roads, it is not such a problem on main roads as the map data is a lot better
    why this is important to me is I often lead groups & we have a policy for fun of the leader has to buy the coffees or beers for every u-turn, it can get expensive if many mistakes are made šŸ˜‚ šŸ˜‚ šŸ˜‚
    I don't think its a bad idea, it is just one that won't work for me
    KevN1k 0undefined 1 Reply Last reply
      KevN1k 0undefined Offline
      KevN1k 0
      @Brian-McG I plan routes, create group rides and lead group rides as well, been using Scenic for the past 3 years with well over 36,000 kilometres and have had zero problems.
      If you have this many incorrect map data then maybe you should look into a better provider?
      Very rarely have I ever encountered an ā€œunreportedā€ turn and when it did, it was user ā€œerrorā€, in example, I didn’t put enough waypoints or vias, the itinerary is fine once created but when you start the ride, the app sometimes change course, and that is the same with over a handful of apps I’ve tested over the years so now I put more waypoints/vias to make sure, aside from this, I’ve never encountered such unreported turns but I have to specify I don’t do off road and stick to back country roads most of the time, hasn’t been a problem here in eastern Canada but maps aren’t as accurate for every part of the world.
        @KevN1k-0 saidšŸ˜†
        & there you have it 😁
        I doubt Canada has anywhere near as extensive a rural road network as France
        Canada my have many miles of road but not as many options
        the unreported turn or missing direction is not that unusual in France
        sometimes it is because they have rearranged the priority of the roads sometimes it just bad map data
        šŸ˜‚ there are only a few map data providers in the world & I have tried several,
        Here happens to be one of the biggest for navigation systems & was the provider to Scenic till Here decided to shaft its customers with massive price hikes
        Can't find who Scenic is using now but they have migrated away from Here
        would be interesting to know who they are using now as this is something I wish MRA would also do
        I will give Scenic a look šŸ˜€
        • Dae 0undefined Offline
          Dae 0
          Scenic uses OSM
            @Con-Hennekens well jumping to MRA from Scenic, I can tell you i saw a very noticeable difference! It was a hot day and my phone notified me of stopping the charge because it was overheating. In all the years I've been using Scenic, that only happened to me once and the battery saver feature was set to "off", never occurred after that so to me it's pretty much a crucial feature.
            GT JWRundefined Offline
            @KevN1k-0 Overheating has been, and apparently still is, a common problem for at least 2-3 yrs already. It apparently is a 'HERE' problem, that has gotten attention, however, never fully seems to be resolved. Anytime it gets to ± 25degC, and using MRA Nav, the phone starts to overheat, the screen dims and the app becomes unusable - whether or not the phone is/was fully charged at the beginning or not.
            Many improvements have, and continue to be made - unfortunately, the overheating one seems extremely difficult to overcome.
            Good luck with your suggestion!
            • GT JWRundefined GT JWR
              KevN1k 0
              @GT-JWR thanks for the info, I did notice the screen dim on my last ride as it was hot and the MRA app became slow and laggy. Now that you mention it, I do remember trying MRA a couple years ago and I believe I ditched it due to this.
              Scenic had HERE for some time before moving to OSM but I never had any overheating issues with Scenic with the battery saver.
                @KevN1k-0 a riding buddy switched to Scenic a few years back (because of lingering issues with MRA) when they were using Scenic - he has not experienced extreme overheating when using the app then, or now with OSM.
                ...trying to keep the faith and ride it through.....🤷 šŸ¤ž
                • AWDC LAOundefined Offline
                  wrote last edited by AWDC LAO
                  You can solve the overheating problem by positioning your smartphone so that its back is exposed to the breeze, fitting a 1 mm thick aluminium plate and placing it between the case and the back of the phone.
                  Power it via a cable, not wirelessly. If necessary, make a special case with additional cooling fins fitted to dissipate the heat.
                  Another solution is to buy a good-quality second-hand refurbished smartphone, then stick a Quadlock in the centre of the back. Next, apply cooling fins with heat-conductive thermal paste above and below the Quadlock.
                  Oververhitting kan je oplossen door je slimme telefoon wat in de wind te zetten met zijn achterkant, een alu plaatje van 1 mm dikte voorzien , en deze tussen de hoes en de achterkant van de telefoon plaatsen.
                  Voeding via een kabeltje, niet draadloos. Desnoods maak je een speciale hoes waarbij je nog extra koelvinnen monteert om de warmte af te voeren.
                  Oplossinge is ook een goede 2de hands refurbished slimme telefoon aanschaffen, dan een quadlock plakken op de achterkant in het midden. Dan koelvinnen met warmte geleidende kleefpasta aanbrengen onder en boven de quadlock.italicised text
                  • AWDC LAOundefined AWDC LAO
                    KevN1k 0
                    @AWDC-LAO Why is almost everyone on here giving alternatives when I'm asking for a feature request? LoL
                    My phone is mounted with quadlock's wireless charging mount and vibration dampener, overheating issue is only with MRA, with Scenic I get no overheating and it actually charges - it can charge to full while MRA only keeps the charge and barely charges a couple % despite being on charger for 4+ hours.
                    I'm simply trying to help MRA by giving a suggestion to a problem, people here suggests alternatives to compensate for a problem instead of trying to help make MRA better. If every app had this problem then I understand we'd have to look at alternatives but this is not the case!
                      Con Hennekensundefined Online
                      @KevN1k-0, that's because people are tying to help you, with a problem that very few people suffer from. So, from their perspective, it can still be a good idea (like I also commented) but not for them. This is an open forum, not a closed suggestion box šŸ˜‰
                      KevN1k 0undefined
                      KevN1k 0
                      AWDC LAOundefined
                      GT JWRundefined
                      Dae 0undefined
                      Dae 0
                      • Track log functionality - compared with BaseCamp
                      • Waypoints and POIs disappear while moving/zooming the map in web planner
                        Tom Balmerundefined
                        Tom Balmer
                      • Wegwerkzaamheden
                      • Veerpont als routeovertreding gaat te ver
                      • Tablet screen lock
                      • Fout in route bibliotheek
                      • Routepunt overslaan
