  4. Expand
Expand
33 Posts 7 Posters 4.5k Views 2 Watching
  • Martin Woodford
    Martin Woodford
    Martin Woodford
    Hi @marinus-van-deudekom
    Thanks for your comments. The screenshot you show is from the expanded route. This is my original 14 point, 377.32 mile route. In a moment I'll expand it in MRA and screenshot it again (MRA makes the changes in realtime and I don't know how to save versions of the original and expanded route)
    • Martin Woodford
      Martin Woodford
      Martin Woodford
      This is the expanded version. Please note the location of the new waypoint 8 and it's description.
      • Martin Woodford
        Martin Woodford
        Martin Woodford
        I will now reset the original in MRA
        • Martin Woodford Martin Woodford
          I don't see how "expanding a route in witch a tunnel or Ferry plays a roll, you"ll get strange results. So no mistake by MRA" can be the case. Why should a tunnel or ferry mean the results are strange ? I'm in Norway at the moment, there are hundreds of tunnels and ferries should I expect strange results everytime one is on my route ?
          @Martin-Woodford the web site planner is pretty long in the tooth, you can holler at the moon for what it is worth but nothing is going to be updated with the current version
          there are plans for a complete revamp of the web site planner, what the time line is I have no clue
          MRA is only a small team & they do not have the resources to fix all the old issues like this & also produce a new revamped planner
          till the new site update, I am sorry but you will just have to learn to keep an eye on the mileage
          • Martin Woodford
            Martin Woodford
            Martin Woodford
            Did you find a problem with my original 14 point route ?
            If you expand it to 15 points do you get the same problem with the new waypoint 8 ?
            Thanks
              Thanks
              @Martin-Woodford Yes I did because points 6, 7 and 8 were not in a logical order. In my screenshot you'll see the dark black line
              • Don Stauffer
                Don Stauffer
                Don Stauffer
                In my case, the original route was fine, and I double checked it using the ''simulation" feature. The problem occurred only after expanding. There was, however, a ferry involved in the route. Apparently the 'expand' feature does not like water!
                • Martin Woodford
                  Martin Woodford
                  Martin Woodford
                  Hi @don-stauffer
                  My original was fine as well (see posts #21 and #22 above).
                  In the absence of anything from MRA it looks like the very useful and helpful tips from @brian-mcg are the way to go.
                  • Marinus van Deudekom
                    Unless you have us the wrong route to start with you seem to be unable to notice your own mistake
                    • Martin Woodford
                      Martin Woodford
                      Martin Woodford
                      I tried, but clearly failed, to explain the situation in posts #21 and #22 above. As I said in post #23 the route is now set to my original 14 waypoints (including start and end), 377.32 miles.
                      For your own satisfaction maybe you'd like to try opening it and using expand increase the number of waypoints to 15. See what happens.
                      • MotoCon
                        The expand function is not much more than placing new route points at calculated intervals. There is no AI or human logic incorporated. Logic you will need to apply yourself afterwards. I doubt that that will ever change. Therefore I always place my own route points. The expand function adds too many anyway. As far as I am concerned, it does not return on the new web planner at all.
                        Brian McG 1 Reply Last reply
                          In another thread you asked why I would worry about the baby being thrown out with the bath water with the new web planner
                          The omission of the expand function would be the sort of thing that for me would be not an upgrade/update but a downgrade, the baby going out 😂
                          The expand function is not perfect but it does have it's uses & people do use it
                          An smarter cleverer expand function is what the new planner should have if the new planner is to be an improvement
                          • Stevedo 6 0
                            I also find the Expand feature to be extremely frustrating at times. Here's an example where I created a 293.63km route with 8 waypoints. I currently export my routes to my Garmin 595 so want to Expand the route to include some extra shaping points. I Expand the route to 15 points total and the new route goes from 293.63km to 553.54km!!!! Note that my original points are all in the correct order.
                            I sure hope that this feature can both be retained and improved in the new planner as when it works it can be very useful.
                            Don Stauffer
                            Don Stauffer
                            Martin Woodford
                            Martin Woodford
                              Rene van Maanen
                              Rene van Maanen
                            • One crash today
                              Mosimann
                              Mosimann
