  4. Expand
Expand
33 Posts 7 Posters 4.5k Views 2 Watching
  • Martin Woodford Martin Woodford
    I've had two problems lately using the expand function.
    I created one long route which I then broke into smaller, day sized rides using the split function. I then expanded the number of waypoints in the split routes. On multiple occasions MRA added higher numbered waypoints between the lower numbered ones which had been part of my original planning. This had the effect of making the routes hundreds of kms longer than they were originally and me going back and forth on myself - luckily I saw the problem before I actually set out to ride the routes. On another occassion MRA added a waypoint on an overbridge above the route I planned, this time I didn't notice it before hand and I started out on a wild goose chase before I realised what had happened.
    @Martin-Woodford To prevent MRA from placing waypoints at the end of the waypoint list, you need to be careful where you place the new waypoint.
    Make sure you place the new waypoint close to an existing one and exactly on the line; this will ensure it is placed in the correct order and numbered correctly.
    You can then move this new waypoint to the desired location.
    To avoid taking detours due to incorrectly placed waypoints, it is advisable to check all waypoints after planning your route; it is also advisable to zoom in as far as possible to see whether the waypoint is placed on the road or next to it.
    Please also ensure that you never place waypoints too close to junctions or roundabouts.
    BMW R 1250 GS
    DMD-NOR7E 7"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
      Hi @Martin-Woodford the Expand function is useful to help constrain your route to the path you have planned & want to take, but it is also dangerous as you have discovered
      I tend to be fairly careful when using the expand function
      The method I use is to slowly increase the number of points e.g. if the route I want to has 40 points I would first increase it to 50 or 60 points & check that the overall distance between start & destination does not change
      If 50 or 60 works ok, I would undo this change vie the back function in the bottom right of the route map page & then repeat with say 80 & again check that the overall distance between start & destination does not change
      If the distance increases then you know the path for the route has changed & you will need to investigate where it has changed
      A good way to compare if a route has changed is to make a copy of the route & display the copy on the map via the "Routes" option under the 3 bar burger menu
      Whenever I use the "Expand" function I do thoroughly check that each of the points in the route are located in sensible locations i.e. not right on top of a junction.
      Poor placement of points whether by the "Expand" function or manually can lead to unexpected detours
      • Martin Woodford
        Martin Woodford
        Martin Woodford
        Hi @peter-zehentreiter
        Thanks for the reply. The problem happened with waypoints the MRA expand funtion placed, not with waypoints I manually added. Because I used the split function from a longer route the start and end points (both via points) of the shorter route were there, plus some number of other waypoints, all in the correct numbered sequence. When I used the expand function MRA added higher numbered waypoints between lower numbered ones.
        Brian McG 1 Reply Last reply
          @Martin-Woodford I understand exactly what you are seeing, splitting routes is standard practice for many MRA users & using the "Expand" function is the lazy way to add additionally points but it comes with risks
          I have also had the issue you describe on routes I create if I add a large number of "Expand" points, hence my suggestion to add fewer "Expand" points
          Sorry if my post above does not help
          • Martin Woodford
            Martin Woodford
            Martin Woodford
            Hi @brian-mcg
            Thanks, your post is really useful. The way you do it sounds like an excellent idea. As you mention, it was when I noticed the distance between start and finish had changed that I knew something was wrong.
            Cheers
            • Don Stauffer
              Don Stauffer
              Don Stauffer
              I just encountered this issue today, and it caused me some grief. I double checked my route, then used the Expand feature to create 20 shaping points to keep my Garmin on track. I loaded the track into my GPS, and did not notice the issue until after the lunch break, which I was tracking on my Garmin. After lunch, I discovered that it was 6 hours to my final destination, instead of 2 hours. Fortunately, I had saved the hotel address in my Zumo XT as a 'saved place' as a safeguard against this kind of problem. After my ride ended, I saw that indeed I had a higher numbered waypoint inserted in the list of lower numbered waypoints. In the future I will check the route AFTER expanding, but I wish that this kind of error could be eliminated by the software.
              • Don Stauffer Don Stauffer
                Hi @Don-Stauffer yes unfortunately the "Expand" function is not perfect, it is useful but you do need to check what it has done
                Not only do you need to check that the overall mileage for the route has not changed (normally an increase)
                but you should check the location of EVERY point it has added, 😖 tiresome I know
                If you blindly assume it has put the added points in the perfect location you will be sadly mistaken
                The "Expand" function often places points on or very near too junctions
                If an MRA route with a point located on or near to a junction is transferred to another navigation system, it is highly likely that the poorly placed points will lead the other navigation system to take a different path from that junction
                as you suggest it would be nice if these types of errors could be eliminated but with the present system if you don't check then the error is yours
                When transferring routes from MRA to any other navigation system it is always wise to check that the overall mileage of a route has not changed
                I include the MRA mileage in the route name so that when I open a route to navigate I can check that it has been calculated for navigation correctly
                I still do this even when I am using MRA Navigation just out of habit from many years of routes going wrong
                this is crude check, it is not infallible but at least it is a check
                • Martin Woodford
                  Martin Woodford
                  Martin Woodford
                  It would be nice if someone from MRA would comment on this. In particular what they're doing to fix it.
                    @Martin-Woodford looking at your original post you asked how it is possible that shaping points added to the route where placed in a wrong order.
                    That can only happen if your route contained some faults like your shaping points not put in the correct order. This happens when you double a piece of the route. That can ben seen by the darker black line in your route.
                    Please share the url from one of those routes so we can help you. Make sure it's set to public.
                    The expand function only puts extra points between points from the original
                      Sorry @marinus-van-deudekom this is not true, when using the expand function it can incorrectly place a point, possibly on top of a bridge / overpass or on the wrong side of a divider on the exit of a round about
                      These errors will lead to the route changing, sometimes quite significantly
                      • Martin Woodford
                        Martin Woodford
                        Martin Woodford
                        OK. So here's my original route, (377.32 miles) I hope it's public
                        https://www.myrouteapp.com/route/open/13569227
                        When I use expand to add just one more point (15, up from 14) it becomes 480.85 miles and point 8 has been added between poins 5 and 6, both of which are on the correct side of the road.
                        Brian McG Marinus van Deudekom 2 Replies Last reply
                          @Martin-Woodford try deleting the 2 points on the UK side of the channel then use the expand function
                          I think the ferry / tunnel maybe has something to do with the order / timing in this example getting really mixed up
                          after I did that then it was just the usual overpass errors
                          • Martin Woodford
                            Martin Woodford
                            Martin Woodford
                            Hi @brian-mcg
                            Thank you. Yes, that works. I very much appreciate the experience you've shared in this thread.
                            However - to the MRA team, the expand function is part of what we pay for. I don't expect to have to rely on the knowledge and goodwill of forum members to make something work properly.
                              @Martin-Woodford The first impression on opening your route
                              You can see that the point 6, 7 and 8 are not in a logical order resulting in a dark black line as I suspected
                              next problem is indeed like @brian-mcg suspected the starting point on the other end off the tunnel / ferry witch resulted in the route being verry long. Deleting the first 2 points will result in the route being expanded like you want. In my case I expanded to 20 points.
                                Hi @brian-mcg
                                @Martin-Woodford I have to put in a good word for the team. As you can see part of the failure was due to a mistake in your route. The other part is that you didn't know that expanding a route in witch a tunnel or Ferry plays a roll, you"ll get strange results. So no mistake by MRA.
                                Beeing a RouteXpert myself I must confess, witch rarely happens, that I didn't know the Ferry bit myself.
                                • Martin Woodford
                                  Martin Woodford
                                  Martin Woodford
                                  Absolutely not. This is my original 14 point route
                                  • Martin Woodford
                                    Martin Woodford
                                    Martin Woodford
                                    The new point number 8 can be identified as an MRA expand point because it's labelled "waypoint" the ones I manually placed have road numbers
                                    • Martin Woodford
                                      Martin Woodford
                                      Martin Woodford
                                      I don't see how "expanding a route in witch a tunnel or Ferry plays a roll, you"ll get strange results. So no mistake by MRA" can be the case. Why should a tunnel or ferry mean the results are strange ? I'm in Norway at the moment, there are hundreds of tunnels and ferries should I expect strange results everytime one is on my route ?
                                      • Marinus van Deudekom
                                        The problem occurs when you expansie the route.
                                        In your original route you can see that the order of the shapingpoints is not logical. See my screenshot.
                                        • Martin Woodford
                                          Martin Woodford
                                          Martin Woodford
                                          Hi @marinus-van-deudekom
                                          Thanks for your comments. The screenshot you show is from the expanded route. This is my original 14 point, 377.32 mile route. In a moment I'll expand it in MRA and screenshot it again (MRA makes the changes in realtime and I don't know how to save versions of the original and expanded route)
                                          Don Stauffer
                                          Don Stauffer
                                          Martin Woodford
                                          Martin Woodford
                                            Rene van Maanen
                                            Rene van Maanen
                                            Òscar
                                            Òscar
