  4. MRA V5.2, Navigation alters the route
16 Posts 4 Posters 110 Views 2 Watching
  • RideToPortugal.comundefined Offline
    RideToPortugal.com
    Good afternoon gents, thanks for the pointers! Here you are the route.
    https://www.myrouteapp.com/en/social/route/13648934?mode=share
      @ridetoportugal.com : The route has to cope with some construction sites ... these are real disturbances in the direction of travel ...
        In the route lab on HERE map and traffic turn on then you can see it when you zoom closer ...IMG_9603.jpeg
          Remove the rake so you can see something
            The road from WP 21 is causing problems in one direction or all? ..
              I type approx. WP 21 to approx. WP 28 construction sites and direction of travel are only possible in the other direction, so the MRA tries to approach the WP from behind...
                RideToPortugal.com
                Thanks everyone, i know for a fact that there arent any road works, i have done it today again!!!
                to bypass this, in "Route Planner" i have chosen, "OpenStreetMap" and uses as a track... its sorted!
                  Then, as so often, blocks are not unsubscribed in HERE, that will take another two days 😉
                  • RideToPortugal.comundefined RideToPortugal.com
                    Good idea and solution to do this if you know the streets better than the HERE maps base specifies.
                    • Route algorithm "OSM"
                    • Navigate as "track"
                      RideToPortugal.com
                      Cherers everyone for being so helpful! Have a good day.
                      RideToPortugal.com
                        Lenny Oundefined
                        Lenny O
                      • wrong routing
                        John S Parryundefined
                      • Veekeersinfo en omleiden
                        Bouke Entundefined
                      • Updated beta! 5.2.1 (486)
                      • Request login credentials
                        Aiello antoninoundefined
                      • Move blocks of routepoints
                        Yannick_van_Vugtundefined
                        Yannick_van_Vugt
