  4. MRA V5.2, Navigation alters the route
16 Posts 4 Posters 111 Views 2 Watching
  • RideToPortugal.com
    RideToPortugal.com
    RideToPortugal.com
    Good Afternoon
    I have created a route last night to use today, all looks ok, used "Here" map like i always do. when i went to start the navigation it goes "crazy!! luckily i guided myself via the waypoints i put within the route.
    Please have a look and let me know if there is anything i can do from my side.
    Unfortunately i cant upload the route or the video as it says i have no permissions
    Vitor
    • Marinus van Deudekom
      Wel Here's my upvote to help you out. You just have to wait a little to get more and then the time restriction is off
      • Con Hennekens
        Video cannot be uploaded at all. You will need to use a video service for that, like google photos or youtube.
          RideToPortugal.com
          RideToPortugal.com
          wrote on last edited by RideToPortugal.com
          Thank you for the help really appreciate it.
          https://youtube.com/shorts/JotzrdFmEhU?feature=share
          This is what happens when i click navigate???
          regards to you all
            Hello,
            Please share the route here, that works with the option to set it to public and to share the link here...
            • RideToPortugal.com RideToPortugal.com
              regards to you all
              @RideToPortugal.com interesting. Like @hubert-thoring said share the route, copy paste the url here so we can have a look at it
                RideToPortugal.com
                RideToPortugal.com
                Good afternoon gents, thanks for the pointers! Here you are the route.
                https://www.myrouteapp.com/en/social/route/13648934?mode=share
                  @ridetoportugal.com : The route has to cope with some construction sites ... these are real disturbances in the direction of travel ...
                    In the route lab on HERE map and traffic turn on then you can see it when you zoom closer ...IMG_9603.jpeg
                      Remove the rake so you can see something
                        The road from WP 21 is causing problems in one direction or all? ..
                          I type approx. WP 21 to approx. WP 28 construction sites and direction of travel are only possible in the other direction, so the MRA tries to approach the WP from behind...
                            RideToPortugal.com
                            RideToPortugal.com
                            Thanks everyone, i know for a fact that there arent any road works, i have done it today again!!!
                            to bypass this, in "Route Planner" i have chosen, "OpenStreetMap" and uses as a track... its sorted!
                              Then, as so often, blocks are not unsubscribed in HERE, that will take another two days 😉
                                Good idea and solution to do this if you know the streets better than the HERE maps base specifies.
                                • Route algorithm "OSM"
                                • Navigate as "track"
                                  RideToPortugal.com
                                  RideToPortugal.com
                                  Cherers everyone for being so helpful! Have a good day.
                                  RideToPortugal.com
                                  RideToPortugal.com
                                  • Strange translation
                                  • Undo/Redo tool is hidden
                                  • Crazy routing
                                    martin-phogel.de
                                    martin-phogel.de
                                    10.4k
