  4. MRA V5.2, Navigation alters the route
16 Posts 4 Posters 111 Views 2 Watching
  • RideToPortugal.com
    RideToPortugal.com
    RideToPortugal.com
    wrote on last edited by RideToPortugal.com
    Thank you for the help really appreciate it.
    https://youtube.com/shorts/JotzrdFmEhU?feature=share
    This is what happens when i click navigate???
    regards to you all
      Hello,
      Please share the route here, that works with the option to set it to public and to share the link here...
      • RideToPortugal.com RideToPortugal.com
        regards to you all
        @RideToPortugal.com interesting. Like @hubert-thoring said share the route, copy paste the url here so we can have a look at it
          RideToPortugal.com
          RideToPortugal.com
          Good afternoon gents, thanks for the pointers! Here you are the route.
          https://www.myrouteapp.com/en/social/route/13648934?mode=share
            @ridetoportugal.com : The route has to cope with some construction sites ... these are real disturbances in the direction of travel ...
              In the route lab on HERE map and traffic turn on then you can see it when you zoom closer ...IMG_9603.jpeg
                Remove the rake so you can see something
                  The road from WP 21 is causing problems in one direction or all? ..
                    I type approx. WP 21 to approx. WP 28 construction sites and direction of travel are only possible in the other direction, so the MRA tries to approach the WP from behind...
                      RideToPortugal.com
                      RideToPortugal.com
                      Thanks everyone, i know for a fact that there arent any road works, i have done it today again!!!
                      to bypass this, in "Route Planner" i have chosen, "OpenStreetMap" and uses as a track... its sorted!
                        Then, as so often, blocks are not unsubscribed in HERE, that will take another two days 😉
                          Good idea and solution to do this if you know the streets better than the HERE maps base specifies.
                          • Route algorithm "OSM"
                          • Navigate as "track"
                            RideToPortugal.com
                            RideToPortugal.com
                            Cherers everyone for being so helpful! Have a good day.
                            RideToPortugal.com
                            RideToPortugal.com
                            • Opstarten app in Android.
                              Beemerfrankie
                              Beemerfrankie
