  4. Can I change the transport mode of a recorded track?
5 Posts 4 Posters 593 Views 3 Watching
  • Marco Strani
    Marco Strani
    Marco Strani
    Hi everyone,
    Last weekend I used MRA for a couple of bicycle rides. On the first day, I accidentally left the tracking mode set to "motorbike," so the track is now saved with the wrong vehicle type.
    Is there a way to edit the transport mode of an already recorded track and change it to "bicycle"?
    Thanks for the help!
    Marco
    BTW: 5.1.0 is really great!!!
    • Nick Carthew Nick Carthew moved this topic from [Web] Problems, Bugs and other Issues on
    • Marco Strani Marco Strani
      Hi everyone,
      Marco
      No! After saving you can't. Before you tap the safe-button is the last moment to change the transport mode. Somebody inside MRA calls this "track-log discipline" 😁
      • Travellexxie
        For your peace of mind, you can use the track as a route again:
        • change the mode of transport to bicycle
        • check if the route is identical to the track
        • save as GPX 1.1
        • import the track from the GPX file
        • done
        John Matthews 0 1 Reply Last reply
        • Marco Strani
          Marco Strani
          Marco Strani
          Thanks, this just what i was going to test next
          • Travellexxie Travellexxie
            • save as GPX 1.1
            • done
            John Matthews 0
            John Matthews 0
            John Matthews 0
            wrote on last edited by John Matthews 0
            • save as GPX 1.1
            • done
            I believe this method can only provide an accurate representation of the original track if there is a recognised track/road displayed on the map for the complete track, ie. so that those track/roads can be used by the track to route conversion algorithm. Furthermore, as far as I can tell the number of points are significantly rationalised and the detailed logging information is lost. Unless I am mistaken, this renders the resulting track of limited value.
            I just used the app to log the track of a short walk to a restaurant, where some of the tracks were not shown on the map (HERE terrain)...
            Screenshot 2026-06-28 at 17.17.44.png.
            Unfortunately, I saved it as I had done previously with transport mode Motorhome- not realising that it was nor possible to change the mode after it had been saved. While the workaround may be acceptable in some circumstances, I do not believe it is in most cases.
            John
            John Matthews 0
            John Matthews 0
            Marco Strani
            Marco Strani
            • My Routeapp Stays questions
            • Kort voorstellen
            • Foutmelding In MRA Next
              Hans Lamers
              Hans Lamers
            • Strange translation
