  2. Routes & Tracks
  3. Public routes not in library
19 Posts 5 Posters 855 Views 1 Watching
  • Rene van Ooijenundefined Offline
    Rene van Ooijen
    At the moment I have 13 public routes and these have also been published. They are not shown in the library, on the map and they are not found via the search option. Most of them start and finsich within the area you see on the map/attachment. What could be the cause?Nu Public route.JPG
      Jack van Tilburg
      Routes in the MRA library are from MyRoute-app RouteXperts only.
      Your routes are visible on the map in your own profile page in MRA.
      • Rene van Ooijenundefined Rene van Ooijen
        Hi @Rene-van-Ooijen. As @Jack-van-Tilburg says, only routes that have been checked and verified by RouteXperts appear in the RoutyeXpert Library. Clicking on Publish will add the route to your map only.
          Rene van Ooijen
          wrote on last edited by Rene van Ooijen
          Ok thanks Jack ad Nick. Does that have to do with the 'performance' and 'route planner' section in the MRA? (see picture)Then I'll have to do some more work. Or is that reserved for designated MRA users?
            Jack van Tilburg
            @Rene-van-Ooijen
            That is "reserved for designated MRA users"
            You can find more information here RouteXpert Accreditation Programme (click)
            Rene van Ooijenundefined 1 Reply Last reply
              @Rene-van-Ooijen
              Rene van Ooijen
              @Jack-van-Tilburg. Thank you very much again Jack. These requirements are understandable. So I'll leave it at that and spread the routes in a different way.
              NL
              R1200GS
              MRA GM and Navigation user.
                NL
                R1200GS
                @Rene-van-Ooijen said in Public routes not in library:
                You can point friends and co-riders to your own profile-map, like this:
                https://www.myrouteapp.com/profile/home/1015892
                Or just send links to the route you want to share like this:
                https://www.myrouteapp.com/nl/social/route/3264018?mode=share
                  @Rene-van-Ooijen
                  That option is for everybody, that are your Performances
                    Rene van Ooijen
                    @Con-Hennekens 👍 Good tip. Thanks.
                      @Rene-van-Ooijen
                      Rene van Ooijen
                      @Hans-van-de-Ven-MRA-Master
                      When following the tips of Con Hennekens his reply, I notice the following.
                      If I open the link to my profile folder and select a route, the distance of the route is incorrect. I suspect they are listed there in Miles. See sample picture. The actual distance of the route is 257km. The time displayed is correct. The map also states The Hague in English. Furthermore, in the frame with my data the link to the route works but the button 'View route details' gives a http 404 fault.
                      Just reporting in case it's a bug.
                        Jack van Tilburg
                        Den haag staat in het Engels omdat het zo weergegeven wordt door OSM.
                        Hetzelfde geld voor Netherlands ipv Nederland.
                        Voor de aanduiding van mijlen bij de route raad ik je aan even in je profiel te kijken of de instelling "Eenheid" juist is.
                        Klik op je foto en vervolgens op <Mijn account>
                          Rene van Ooijen
                          @Jack-van-Tilburg
                          Dank je Jack. In mijn profiel (Mijn account) staat het net zo aangegeven als in je plaatje. Dus Metrich (km). Had ik al naar gekeken. Vandaar dat ik het heb gemeld als mogelijke bug.
                          Overigens erg fijn dat er forumleden zeer snel reageren en mede MRA(ppers) op weg helpen. 👍
                          Wordt zeer gewaardeerd.
                            @Jack-van-Tilburg
                            @Rene-van-Ooijen
                            Hallo Rene, deel de link van de route eens (Utrechtse Heuvelrug)
                              I suppose that OSM uses official international names. The international name of 's Gravenhage is The Hague. The one of Amsterdam is Amsterdam and Rotterdam becomes Rotterdam (duh!) 😉 I suppose most city names do not have any official international name, and therefore the local name is used.
                                @Rene-van-Ooijen
                                Rene van Ooijen
                                Bij deze.
                                https://www.myrouteapp.com/nl/social/route/4675189?mode=share
                                  Bij mij geeft hij gewoon de juiste afstand weer:
                                  Heb jij je instellingen op de PC op Engels staan misschien?
                                  Ook vanuit jouw bibliotheek:
                                  En ook als ik op de knop "Route Details" klik, werkt het gewoon zoals het moet werken.
                                    Rene van Ooijen
                                    Ik denk dat het browser gerelateerd is.
                                    Excuus dat ik de browser niet eerder heb vermeld.🤦
                                    In Chrome (v91.0.4472.114) gaat het goed.
                                    In Firefox (v72.0.2) wordt de afstand in Miles getoond.
                                    Firefox config Taal is ingesteld op NL taal. Alternatieve taal is daar niet ingesteld.
                                    In Edge (91.0.864.54) heb ik ook Miles aanduiding. Daar stond in de browser config onder Talen de optie 'Engels > 'Aanbieden om pagina's in deze taal te vertalen' aangevinkt.
                                    Uitgevinkt en browser herstart in nieuwe sessie maar de Miles blijven staan.
                                    OS Windows10 is volledig NL ingesteld.
                                    MRA is ook op NL ingesteld.
                                      Hallo @Rene-van-Ooijen
                                      Ik gebruik standaard Google Chrome, de vorige plaatjes zijn gemaakt via Chrome. Iedere browser is uptodate (laatste versie.
                                      Verder gebruik ik Windows 10 Pro (Engels) en heb ik een Engels talige office 2019 versie
                                      Deze komt uit firefox:
                                      Deze uit Edge:
                                        Deze uit Edge:
                                        Rene van Ooijen
                                        Dan moest het toch ergens aan mijzelf/mijn browsers liggen.
                                        Heb vanmorgen in alle 3 de browsers de cache eens opgeschoond. Daarna afgesloten en opnieuw opgestart. Link in URL balk geplaatst en zie daar ...... alles nu in KM. 🏍
                                        Bedankt voor alle moeite die jullie hebben gedaan. 👍
                                        Rene van Ooijen
                                        Jack van Tilburg
                                        • Problems with the "Avoid Toll Roads" option
                                        • Tracklog lost
                                        • Indicator arrow drifts all over the map.
                                          Bouke Entundefined
                                        • New update! (4.4.0)
                                          Jan 50undefined
                                          Jan 50
                                          1.4k
                                        • App crashes
                                          Jan 50undefined
                                          Jan 50
                                        • Carpuride
                                          paul69undefined
                                        • Improve Favorite POI management (visibility, categories, icons)
