  4. Android 9: no tracklogs
4 Posts 2 Posters 134 Views 2 Watching
  • Gijs Jonkerundefined Offline
    Gijs Jonker
    Instead of using my expensive new smartphone, I like to use my old Android 9 smartphone which still works fine. While at home, connected to wifi, I can use my tracklogs in the app. However, when on the road (and offline) the Tracklogs screen doesn't show my tracklogs anymore but only shows an exclamation mark and the message 'No Internet'.
    In Android 11 my tracklogs are available in the app, offline and online.
    I found out that I can download the tracklog, open it and use it but it would be nice to have my tracklogs available in the tracklog list the same way as in Android 11.
    Gijs Jonkerundefined Guzzistundefined 2 Replies Last reply
    • Gijs Jonkerundefined Gijs Jonker
      Gijs Jonker
      In the app (version 5.0.4-451) the list of routes is available, it is the list of tracklogs that gets empty when offline.
        Guzzistundefined Offline
        wrote last edited by Guzzist
        @Gijs-Jonker did you enable on your old Android 9, also the automated synch?
        And are you sure, you are using track-logs? Not route-tracks?
        I'm asking, because the synch of track-logs is only working, when online.
          Gijs Jonker
          Yeah, I see what you mean. But it is not the syncing that's the issue, that works fine.
          When I have a track (gpx 1.1 file with trk, trkseg, trkpt xml-tags) I can upload it in MRA Routeplanner on PC as Route-track and as Tracklog.
          In the MRA-app with Navigation on my smartphone I can select Routes & Tracklogs and the track can be seen under 2 tabs: Routes or Tracklogs. The track can appear in both lists depending on being uploaded as Route-track or as Tracklog.
          However, when my smartphone has no internet connection anymore, the Tracklogs list gets empty on Android 9 but remains available on Android 11. This is a bug i.m.o.: instead of showing 'No internet' in the Tracklogs list, show the tracklogs.
          So this also gives a solution: import the track as Route-track, not as Tracklog.
          Gijs Jonker
          • Following a track
            RetiredWingManundefined
          • Route draait terug
            Kris Lemaireundefined
            Kris Lemaire
            Ewout Dundefined
            Ewout D
            1.7k
          • Cameraknop
            Arjan de Vriesundefined
            Arjan de Vries
          • Route omkeren
          • Use Silverfox C1 to skip waypoints
            Makroundefined
            Makro
          • Kaartweergave na gebruik pijltoetsen remote
            CD130undefined
          • Zoom Out in north Up view
