  4. Mixed mode route
Mixed mode route
7 Posts 5 Posters 1.3k Views 1 Watching
  • Mike Luca 0 Offline
    Mike Luca 0 Offline
    Mike Luca 0
    Looking to create a route. The very beginning is on highway to get out of the city and to the good stuff fast. In Garmin BaseCamp and CaliMoto I can just choose those segments to allow highway and avoid it for the rest of the route. I don't see a way to do this in MRA. Hoping this is easy and I'm just missing it.
    Nick Carthew nomko Con Hennekens 3 Replies Last reply
    • Mike Luca 0 Mike Luca 0
      Nick Carthew Online
      Nick Carthew Online
      @Mike-Luca-0 Segments are available but only when using the planning map from OpenStreetMap.
      You could just use route points to determine your route. That’s what a route planner does best.
        nomko Offline
        nomko Offline
        @Mike-Luca-0
        From what i understand is, is that you want to avoid highway's and such?
        This can be done under the Toolkit menu.
        I am using the HERE map as default map due to the fact i'm using a Garmin Zumo XT as navigation device on 1 of my bikes beside the MRA Next app.
        You can select or deselect the following "obstacles":
        • Toll roads
        • Highway's
        • Ferries
        • Rail transportation
        • Tunnels
        • Unpaved roads
        • Environmental zone
        Screenshot below is in Dutch, but it gives you an idea were to look.
        Also, if you want to go from A to B (or as in your example, get as quick as possible away out the city and going to the good stuff) place a startpoint (waypoint) from were you want to start the route and place an end point at th elocation you want to go. If you set the options as shown in the screenshot correct, MRA routreplanner will create a route from A to B avoiding the items you checked.
        | MRA Gold Member |
        | MRA Next + Kawasaki Z650 |
          @Mike-Luca-0, if you want to go out of the city as quickly as possible, just set your first waypoint outside of the city.
            Mike Luca 0 Offline
            Mike Luca 0
            All good suggestions. Thanks. I already knew how to avoid highway but it’s a whole route setting, and placing huge amounts of waypoints to choose my escape will likely be what I do to work around this. I will also tinker with open street maps for segment control. Thank you all again.
              Mike Luca 0 Offline
              Mike Luca 0
              Well OpenStreetmaps has the setting that I was after ! Thanks all!!
              • Travellexxie Offline
                Yes OSM has the settings, but now comes the tricky part, on what device or with what app do you want to navigate?
                If it is an app or device based on OSM, no problems. If it is based on the TomTom or Garmin map, you should use the toolkit and compare the route you just made, with the TomTom and/or Garmin map and put enough waypoints to the route, to make the route on the 3 maps equal.
                Mike Luca 0
                Mike Luca 0
                  Peter Burch 1 0
                  Peter Burch 1 0
                • How do I remove an old device?
                  Bruno 7
                  Bruno 7
                • No location in Android Auto ! App unusable !
                  Jeff Causey
                  Jeff Causey
                • Volume not restored after announcement
                • Can others follow my progress using MY Route App?
                • New update 5.2.1
                  1.8k
