  4. Proposal for an algorithm to guide around unexpected road closures
41 Posts 12 Posters 11.8k Views 7 Watching
  • Axel Härtl Axel Härtl
    OK, thanks for your response.
    I just wanted to document an idea I got during a walk with my dog.
    Best, Axel
    @Axel-Härtl that is definitely appreciated!
      In a thread "https://forum.myrouteapp.com/topic/10748/how-to-exclude-short-time-road-blocks-during-navigation/1", there was an intense discussion about the pros and cons of guided detours around unexpected road closures. Some motorcyclists prefer a solution similar to TomTom.
      I would like to propose an algorithm that, in my opinion, would enable guided detours around road closures.
      The scenario: A motorcyclist is navigating with MRA on a pre-planned route. He encounters a temporary road closure that is not marked on the planning map and is therefore not bypassed.
      The task is to create a feature in MRA that guides the rider around the closure, similar to TomTom.
      Definitions:
      Shaping Point A: the point where the motorcyclist is actually located before the roadblock.
      Shaping Point B: the point on the known planned route beyond which a roadblock is suspected.
      The algorithm could work as follows.
      1: The rider stops and selects “Detour around a roadblock” from the navigation menu. There, he enters the length of the expected roadblock (e.g., 10 km).
      2: MRA now automatically adds the two additional shaping points, A and B, to the route. The waypoints along the remainder of the route after Point A to the destination are incremented by 2, since the route now has two more shaping points.
      3: MRA excludes the section between shaping points A and B from the permitted roads—similar to how it handles highways or toll roads to be avoided, etc. To do this, a programming solution must be found that does not rely on the planning map, since this exclusion is not present there.
      4a If a planned shaping point is located on the now-blocked route, it is skipped.
      4b: If a planned viapoint is located on the now-blocked route, a warning is issued so that the rider can decide whether to be redirected to that point from B or to skip it.
      5: MRA now calculates a new route segment that leads at least to point B. If the original route is not reached again until further along toward the final destination due to road conditions, shaping point B is skipped during navigation.
      Of course, I don’t know how this can be implemented programmatically, but that’s what @corjan-meijerink, our mastermind, is here for.
      Òscar
      Òscar
      Òscar
      @Axel-Härtl I read the discussion carefully and I completely agree with your proposal. Anything that improves MRa is welcome!
      • https://t.me/MRa_by_b0hd1
      • YouTube: @demco17
        All this would be possible without all the hassle of adding extra waypoints 🙂
        That said it’s not a currently planned feature but it is in my mind after reading the interesting discussions. Quite often those suddenly magically get done (or at least a proof of concept) over a boring weekend 😉 Not making any promises!
        Òscar
        Òscar
        Òscar
        @Corjan-Meijerink Super!!!!
        • YouTube: @demco17
        • BMWBiker58
          BMWBiker58
          BMWBiker58
          As this is a subject close to my heart, I’d like to highlight once again a scenario that has become all too common, where the ability to block an exit on the planned route would be extremely helpful.
          You reach a motorway exit that has only just been closed. So you can only continue straight ahead. After a few kilometres, you are diverted at the next opportunity. At that moment, you don’t know whether the app is (incorrectly) rerouting you back or whether it has found a new way back onto the planned route beyond the closure.
          That is why it would be so important to be able to mark the closure with a button so that it is excluded from the routing. (Please bear in mind that you are driving on the motorway and cannot stop to fiddle about on the small screen).
          This scenario, as well as sudden closures on country roads due to fallen trees, landslides, etc., is unfortunately becoming increasingly common and is no longer the absolute exception.
          There are people with a very good sense of direction who don’t need this – for me, it would be a huge help.
          Axel Härtl 1 Reply Last reply
          • BMWBiker58 BMWBiker58
            Axel Härtl
            Axel Härtl
            Axel Härtl
            @BMWBiker58
            Perfect. I totally agree.
            In my proposal the usage of shaping point A and B would be as follows.
            If you press the button "here is beginning of a closure" shaping point A is automatically set.
            If you leave the highway and press "here is end of a closure" shaping point B is automatically set.
            The algorithm then excludes the road between A and B from the calculation and continues as I described.
            Best, Axel
            BMW R 1200 RT
            Tourenorientiert
            MRA lifetime member
            BMWBiker58 1 Reply Last reply
              @BMWBiker58
              Best, Axel
              BMWBiker58
              BMWBiker58
              BMWBiker58
              @Axel-Härtl Would this prevent the app from trying to reroute via the closed exit?
              If I understand your suggestion correctly, only the section from the closed exit (first press of the button) straight ahead until the second press of the button would be blocked.
              However, the exit itself (and certainly a few kilometres beyond it) – the road or motorway you actually wanted to take – would need to be blocked.
              • Guzzist
                Now we are discussing 2 different scenarios? If I understand correctly, we have:
                • the road you are driving (following the planned route) is suddenly blocked. So, you need to leave this road - and you need guidance to get back on the planned route
                • You are supposed to leave the road you’re driving on – following the planned route. But the exit is suddenly blocked. So you can’t leave this road – and you need guidance to get back on the planned route
                • Axel Härtl
                  Axel Härtl
                  Axel Härtl
                  @Guzzist @BMWBiker58
                  Yes, there are two scenarios under discussion now.
                  1: if a planned route is blocked -> the algorithm is decribed in my post #1
                  2: by selecting "here is the end of the closure" at the exit of a motorway, shaping point B would not be set on the originally planned route but somewhere else (i.e. at the exit).
                  So in this case the algorithm should navigate to the nearest point of the originally planned route.
                  Here the rule for skipping a via point between A and the location, where the original route is met again must be implemented as I proposed in post #1
                  BMW R 1200 RT
                  Tourenorientiert
                  MRA lifetime member
                  • nomko
                    Banned
                    wrote on last edited by nomko
                    @Axel-Härtl
                    Don't you have those diversion signs in Germany, like we have in the Netherlands, that direct you around the location of the roadworks when there are roadworks somewhere?
                    Or do you mean, for example, roadworks that suddenly appear without clear prior notice?
                    I get the point about having a button or function in MRA that allows you to bypass roadworks. Last year in Belgium, I experienced 3 or 4 times that roadworks suddenly appeared that hadn't been there a week before my tour. It is annoying, but stopping for a moment and checking how to get from A to B is, in my opinion, perfectly doable.
                    BMWBiker58 Axel Härtl 2 Replies Last reply
                    • nomko nomko
                      @Axel-Härtl
                      BMWBiker58
                      BMWBiker58
                      BMWBiker58
                      @Nomko-Nomden Yes, of course there are diversion signs when it’s a PLANNED construction project at a motorway exit. You can, after all, take these into account during the planning stage.
                      However, I’m talking about the increasingly frequent SUDDEN closures of motorway exits.
                      Or fallen trees or landslides on country roads.
                      In such cases, I would like to see a button that prevents the navigationdevice from repeatedly attempting to navigate through the closure.
                      I would like to point out that you simply cannot stop to look at anything or make a change because you are not allowed to stop on motorways.It would be possible on country roads, but it would be fiddly to set up a diversion manually on the small screen.
                      • nomko nomko
                        @Axel-Härtl
                        Axel Härtl
                        Axel Härtl
                        Axel Härtl
                        @Nomko-Nomden
                        Hello Nomko
                        This entire discussion pertains to the scenario where there is an unplanned, last-minute road closure. In such cases, there are often (based on experience) no detour signs. (Unfortunately, Germany is also on the decline right now, which is making the situation increasingly worse—but that’s a different discussion.)
                        In this case, you have to stop and re-plan your route. This is certainly possible with a little effort. However, adding a shaping point by pressing and holding a road segment on my phone during navigation unfortunately doesn’t work. So I have to stop the navigation, go back to planning mode, and replan.
                        However, if you encounter a closed exit on a highway, this isn’t an option, since you’re not allowed to stop on highways. By the time you reach the next possible exit, you’re no longer on the planned route and may be redirected back.
                        Various approaches to this issue (unfortunately scattered throughout the thread) have been compiled here.
                        In addition to the arguments for including a simple detour feature in MRA, we also see that other navigation systems offer this capability.
                        @Corjan-Meijerink has taken up the basic idea but has also written that implementation is not currently planned.
                        I hope this clarifies our request somewhat.
                        BMW R 1200 RT
                        Tourenorientiert
                        MRA lifetime member
                        • Nick Carthew
                          I do hope that we’re not going to over complicate the app by adding more buttons and settings. In my 50 years of using our road systems, I have encountered both blocked motorway exits caused by accidents and unexpected road closures (fallen tree) and I have always dealt with them without an additional magic button. Some of the posts in this thread paint an almost apocalyptic picture where these unexpected closures are happening on a daily basis. Just my thoughts.
                          Axel Härtl BMWBiker58 2 Replies Last reply
                            Axel Härtl
                            Axel Härtl
                            Axel Härtl
                            @Nick-Carthew
                            Hi Nick. Do you regard TomTom as being overcomplicated, since there is such a button?
                            By the way: I encounter an unexpected closure nearly on every tour. This might be because I prefer small, windy roads.
                            On those roads you hardly find detour signs. They are simply closed and that‘s it.
                            BMW R 1200 RT
                            Tourenorientiert
                            MRA lifetime member
                              Offcouse i have my opnion about this issue.
                              Many times there signs which to follow to get around the roadworks but the question i always have. Does this re-route get me back on the route or sends it me far off-route? So i rarely use these signs. I always look on the map where to go.
                              I have many years of experience of riding with TomTom and routes (track based).
                              If routeworks were not present or aware on the map during planning, but they are on the map when the route was started on the navigation. TomTom reroutes me automatic around these roadworks. No questions or remarks. 9 of 10 times it works like a charm. Especially in cities/villages. But there are limits (that's the 1 time it doesn't work).
                              Instead of a special roadworks button/option. Isn't is possible to long press on a waypoint or point on the route and then select the option roadworks. Then the navigation knows what to do.
                              A few years ago i was in Scotland and suddenly the road was closed due to an accident. We were pretty quick after the accident happened because we did see some policecars going to the accident with sirens on. I didn't took long this closure was mentioned to TomTom and TomTom found me a re-route by itself without input from me. Suddenly it told me to turn around and get an exit a mile back. It brought me as close as possible after the roadclosure back on the original route.
                              All and all.
                              I suspect a function like the roadworks button will be more and more unneseccary in the future. More and more roadworks and closures are going to be registered which are available for navigation software. Then it is up-to the software how deal with this.
                              • Axel Härtl
                                Axel Härtl
                                Axel Härtl
                                To all valued participants in this discussion.
                                I think everything essential has been said.
                                I posted this suggestion specifically in the “Suggestions and Discussion” section because I wanted to propose what I believe is an improvement to MRA.
                                The topic has been assigned to @Corjan-Meijerink, and he has already responded to it.
                                I don’t know how the decision-making processes work at MRA, but for me, the discussion here has reached a point where I don’t want to invest any more effort into it.
                                Should it come to implementation, I would be more than happy to offer my assistance in designing the process. Process development is my profession.
                                Best, Axel
                                BMW R 1200 RT
                                Tourenorientiert
                                MRA lifetime member
                                Òscar 1 Reply Last reply
                                  Best, Axel
                                  Òscar
                                  Òscar
                                  Òscar
                                  @Axel-Härtl I think it's a fantastic idea. I don't understand the "fear" some users have of improvements. If there were no improvements, we'd still be using paper maps.
                                  Again, thank you very much, Axel, for your suggestion.
                                  • YouTube: @demco17
                                  • Òscar Òscar
                                    Axel Härtl
                                    Axel Härtl
                                    Axel Härtl
                                    @b0hd1 🙏
                                    BMW R 1200 RT
                                    Tourenorientiert
                                    MRA lifetime member
                                    • Lluis Arasanz
                                      Hi all!
                                      From my point of view, if app users didn't provide suggestions for improvements or changes, we wouldn't need the wide range of apps we have: we'd all just use Google Maps, period. Or paper maps... or rely on our memory.
                                      It's true that not everything goes, but just as improvements are managed within the app itself, having a "quick" way to cancel a section of a route seems great to me. And here, everyone can use it or not, based on their personal preferences.
                                      @Nick-Carthew , it's an option that will be (I suppose) in the menu. I don't think that part is so bothersome that you wouldn't want it implemented. If it's developed and you don't want to use it, that's perfectly fine.
                                      I think it's a great idea!!!
                                      • BMW F750GS
                                        BMWBiker58
                                        BMWBiker58
                                        BMWBiker58
                                        @Nick-Carthew I don’t want to let that go unchallenged.
                                        Complication:
                                        First of all, I can’t see what would be so complicated about using a ‘block button’.
                                        Apocalyptic Szenario:
                                        The problems on German motorways and roads have become significantly worse in recent years (I’ve been riding a motorbike for exactly 50 years myself). In any case, these sudden road closures are no longer the absolute exception.
                                        General benefit:
                                        The app contains some features that aren’t relevant to ME, but I recognise that other users value them. If you don’t need help with diversions, be grateful for your sense of direction.
                                        As I’m unfortunately not blessed with one, I use a Navdevice and would be grateful for any further technical support to get me back on track to my destination.
                                        Or as we say say in Germany: "Haben ist besser als brauchen!" ("to have is better than to need") 🙂
                                        • Nick Carthew
                                          Let me state now that I am not opposed to developing the app, I have every faith in the development team at MRA to come up with a good solution to this request if it is achievable. Maybe the reality of the real world is different to mine, I try to avoid motorway riding as much as possible, preferring roads with grass in the middle if possible. So perhaps the need for a magic button is greater than what I perceive. If I ever come across a situation where I need the magic button I would certainly not hesitate to tap it.
                                          Òscar
                                          Òscar
                                          Axel Härtl
                                          Axel Härtl
                                          BMWBiker58
                                          BMWBiker58
                                            Albert van den Elsen
                                          • Verminkte route op TomTom.
                                            Jacob Waterweg
                                            Jacob Waterweg
                                          • Probably a me thing
                                            Solo1138
                                            Solo1138
                                          • MRA V6.0.0 (531) Download offline maps ?
