  4. Start route bij dichtstbijzijnde routepunt werkt niet
16 Posts 6 Posters 2.8k Views 2 Watching
  • Philippe Veys
    Philippe Veys
    Philippe Veys
    Hallo,
    Tijdens laatste motor rit was halfweg de MRA navigatie vastgelopen. Reageerde niet meer.
    Dus app en route opnieuw opgestart, maar MRA wou de route enkel herbeginnen vanaf het startpunt. Vroeger kon je start vanaf dichtstbijzijnde routepunt selecteren. Was heel handig, maar deze optie bestaat niet meer ?
    Routes rijden als tracks staat uit.
    Wat is hiervoor de oplossing of wat deed ik fout ?
    • Philippe Veys Philippe Veys
      Hallo,
      @Philippe-Veys
      Start vanaf dichtstbijzijnde waypoint is alleen beschikbaar voordat u begint met navigeren. Tik op route-instellingen en u ziet het.
      Start from nearest waypoint is only available before you start navigating. Tap routing settings and you will see it.
      • Philippe Veys
        Philippe Veys
        Philippe Veys
        Ok thanks, but this setting "Start from nearest waypoint" was on (automatically) when I restarted the navigation. Could there be another reason ?
          @Philippe-Veys
          I’m not sure why the app wanted to start from the beginning but a long press on any waypoint will skip all previous waypoints if it should happen again.
          • RainerT
            RainerT
            RainerT
            ‘Next route point’ means:
            The route point closest to my current position. This may also lead back along the route.
            Or, in unfavourable circumstances, it may be the last one.
            The safest option is to let MRA search for the first waypoint as the starting point and then manually select the one that suits me. That one is then activated.
            RT
            • RainerT RainerT
              RT
              @RainerT normally it does work like that
              • Philippe Veys
                Philippe Veys
                Philippe Veys
                When restarting the route after a (coffee)break, is there no other way then to press longtime on the next waypoint ? The function « Start at closest waypoint » is really missing in this app! I’m just back from a motor tour and selecting the next waypoint didn’t work, only from Start, the app crashed finally🤨
                Herman Veldhuizen MotoCon 2 Replies Last reply
                  @Philippe-Veys Are you navigating a route as track? The 5.0 release always starts at the first waypoint (before that you could select start or nearest). There are some issues related to this (which I have reported).
                  I dont know the implementation details but it could be wise for the app to focus first on the navigation ON the track and later try to solve the navigation TO the track.
                  I have the setting Automatic-recalculation set to off and it is therefore a bit strange to see that the app finds a way to the track if I am not on it at startup.
                    @Philippe-Veys said in Start route bij dichtstbijzijnde routepunt werkt niet:
                    No it is not. Before pressing "Start", tap "Route settings", there it is.
                    The correct way to pause a route, is to enter the menu, and tap "Stop navigation". A "Resume" button appears that always picks up where you left.
                    If you navigate tracks or use the "Navigate route as track" feature, this is skipped indeed, since you are navigating a track. You will have to decide the point of entry yourself indeed.
                    • Philippe Veys
                      Philippe Veys
                      Philippe Veys
                      Ok, I noticed that for some routes I made, I have the possibility to select Route Settings with possibility to choose Start at closest waypoint before I press Start, and for some I don’t.
                      What could be the reason for this ? I don't use the routes as tracks. As I recall, I always create the routes the same way.
                      • Philippe Veys
                        Philippe Veys
                        Philippe Veys
                          @Philippe-Veys The ones without the option are tracks the ones with the option are routes.
                          P.S I deleted your duplicate post.
                          • Philippe Veys
                            Philippe Veys
                            Philippe Veys
                            I don't use tracks, I only create routes in MRA Routeplanner and use them in the MRA app on my motorbike, so that can't be the reason I think.
                              @Philippe-Veys Are you using an A -B route?
                              I see the option to Start from nearest waypoint
                              • Philippe Veys
                                Philippe Veys
                                Philippe Veys
                                I’m using A to B route indeed. But I just noticed that if I create or change a route in the MRA app on my IPhone, I do have the options ! This must be a bug in the system 🥴
                                  I think you do, you just don't know when a track is a track, so
                                  no it is no bug...
                                  Everything you do with roundtrip generator or curvy routes actually IS a track.
                                  RainerT
                                  RainerT
                                  Philippe Veys
                                  Philippe Veys
                                  • Startpunt wijzigen
                                    Giancarlo e
                                    Giancarlo e
                                    Ed van Klink
                                    Ed van Klink
                                  • Route exporteren uit beta
                                  • Info on MyRoute-app's POI
