  4. MRA and tunnels
MRA and tunnels
24 Posts 12 Posters 10.1k Views 7 Watching
  • Guzt
    Guzt
    Guzt
    Using off line navigation or not, always switch off roaming in Switserland. They have their own telecom rules and are not part of the EU which implicates that the EU roaming agreements don't apply for them. As soon as your telephone makes contact to a Swiss telephone service, costs kick in. To avoid this, use a Swiss eSIM .
    https://saily.com/download-esim-app/
    Peter Zehentreiter Rob Verhoeff 2 Replies Last reply
    • Tony 13
      Tony 13
      Tony 13
      For the roaming you just need to check your contract. O2 does include Switzerland in roaming from the UK
      https://www.o2.co.uk/help/international-and-network/using-your-phone-abroad/roaming-in-europe-pay-monthly
      • Guzt Guzt
        @Guzt However, this is only partially true. For example, Deutsche Telekom's tariffs include roaming in Switzerland and the UK.
        I can't comment on other providers.
        BMW R 1250 GS
        DMD-NOR7E 7"
        SPC Universal mount
        Motorola Edge 40 "offline"
        Sena SLR 3
        Sena 50 R
        • Guzt Guzt
          @Guzt I mentioned this before... That's not entirely true! There are Dutch providers that simply consider Switzerland an EU country. For example, with my Dutch mobile plan, I'm allowed to use 50GB per month from my Dutch data bundle in an EU country (including Switzerland). So you really need to check the terms and conditions of your provider in your own country!
          • Guzt
            Guzt
            Guzt
            My provider blocks Switzerland just to avoid the possible surprise. I have to activate it or buy a data plan for it. But then, Belgian telecom is so what the most expensive in the EU.
            So it is up to Adrian to check this with his telecom provider.
            • Guzt Guzt
              @Guzt said in MRA and tunnels:
              Time to shop elsewhere 😉
              • nomko nomko
                Does offline navigation not solve this issue? Or are you even with offline navigation depending on a good/solid/working GPS connection?
                @Nomko-Nomden offline navigation depends also on good GPS receive. Means: you don't need roaming/eSIM for Internet connection. But in long tunnels, you will loose GPS - and if there is an exit inside the tunnel, you need to take- MyRoute-App may will not navigate you!
                • Herman Veldhuizen
                  i drove through many tunnels in Norway today, including the 25km long Laerdals tunnel. MRA worked without a glitch inside these tunnels, no spinning, no jumping to roads above the tunnel. This is with the 5.0.3 version. I even had a shaping point inside one of the tunnels and that worked as well.
                  Guzzist TomOnTour 2 Replies Last reply
                    @Herman-Veldhuizen ...then you are lucky.
                    The reasons are:
                    • Navigation systems can also interpolate their own position from direction and speed. But that only works in straight tunnels.
                    • In some tunnels are so called beacons installed, by this navigation systems can also calculate the actual position (in GoogleMaps, this option must be activated in settings).
                    • In other tunnels there may be TunnelSat installed. This is an advanced tunnel GPS system that extends reliable satellite navigation underground, delivering accurate, real-time positioning signal.
                    It depends on the tunnel operator.
                    • Guzzist Guzzist
                      The reasons are:
                      #21
                      @Guzzist the fact that it worked in all tunnels made me think that HERE maybe has made an improvement (i assume a newer version of the sdk is used since I last tried it). The cursor followed the tunnel shape.
                      I will soon drive through the tunnel again in which I know MRA was struggling.
                      I dont think that I made any changes on my phone to settings to improve the gps accuracy.
                      • Garry Davis
                        Garry Davis
                        Garry Davis
                        Never knew about the beacons in tunnels or activation in settings. Just activated mine in Google maps. Thanks for that.
                        • Herman Veldhuizen
                            TomOnTour
                            TomOnTour
                            TomOnTour
                            @Herman-Veldhuizen
                            I had exactly the same experience when I was in Norway last year. I also couldn't remember any problems in any oher tunnel I ever used: Neither in the alps, nor in the german tunnels like Elbtunnel.
                            Greetings
                            Thomas
                            MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
                            TomOnTour
                            TomOnTour
                            Guzt
                            Guzt
                            Garry Davis
                            Garry Davis
                            Tony 13
                            Tony 13
                            Makro
                            Makro
                              Alderweireld Rudi 0
                              Alderweireld Rudi 0
                              Hanza 0
                              Hanza 0
                            • Weather as a service
                              Andy Smith 5
                              Andy Smith 5
                            • Lane view in Android Auto
                              denWINNE
                              denWINNE
