  4. Problem: Scenic routing ignore setup for avoiding motorways
15 Posts 5 Posters 2.3k Views 4 Watching
    Hi, just tried the same.
    And there is indeed a motorway on the route to the biker ranch.
    Actually, I can't see any difference on the small screen whether “avoid motorways” is on or off; both routes look the same.
    TomOnTour
    TomOnTour
    TomOnTour
    @Jörgen said in Problem: Scenic routing ignore setup for avoiding motorways:
    Yep, that i exactly what I have seen on the screen 🙂
    They look the same and switching the motorway avoidance on or off changed nothing.
      Nobody else seen this problem?
      • CD130
        You mean the “scenic” option in the app, right?
        TomOnTour 1 Reply Last reply
        • CD130 CD130
          TomOnTour
          TomOnTour
          TomOnTour
          @CD130 Yes, excactly:
          I switch ti scenic and selct the middle curvy variant (the one between very straight and the very curvy option 🙂 )
          CD130 1 Reply Last reply
          • TomOnTour TomOnTour
            @TomOnTour Just tested 3 different destinations and seems to be doing well here. Motorways are avoided.
            • CD130 CD130
              TomOnTour
              TomOnTour
              TomOnTour
              @CD130 Thank you for the feedback. As weather is beautiful again I will do another test to a different location.
              • TomOnTour
                TomOnTour
                TomOnTour
                I just used some waiting time to make a small test: Inused my iphone with myrouteAPP and surprisingly the iphone version is not using the motorway. I will double check this when I am back home again.
                  @TomOnTour , @Jörgen , @CD130
                  Hey can confirm the error, switch off the chargeable road at medium curve, then the A43 will no longer be used for me !!
                  We do not have such a chargeable street in the region !!
                  Hey kann den Fehler bestätigen, schaltet mal bei mittlerer Kurvigkeit zusätzlich die Gebührenpflichtige Straße aus, dann wird bei mir die A43 nicht mehr genutzt !!
                  Bei uns gibt es keine solche Gebührenpflichtige Straße in der Region !!
                    TomOnTour
                    TomOnTour
                    TomOnTour
                    @Hubert-Thoring @CD130 @Jörgen
                    Thank you very much for all the information.
                    I have done some more testing and can confirm, that switching off "Gebührenpflichtige Straße" fixed te issue.
                    I also dine sommore testing around potetial different behaviors between iOS and Android and can confirm, that both versions behave in exactly the same way and the workaround provided by Hubert works for both platforms.
                    So, that leaves one fna question (at least for me):
                    Why does Here classify the A4 not as Motorway, but as a toll road?
                    • AWDC LAO
                      Very good to know !
                        The same for the A44, if you prevent toll road, then the route is not using highway.
                        There is something wrong with "Autobahn vermeiden" (prevent highway) and toll road. And for both curvy options.
                        • TomOnTour
                          TomOnTour
                          TomOnTour
                          I am not sure, if it is a,problem within MRA Next or an Here-Map-issue.
                          I have done acouple more "dry-runs" from different starting and ending locations and I haven't be able to reproduce the problem in for example the Sauerland area. Even when I have been in the Eifel today, I haven't ben able to reproduce the problem by selecting a locaton going south, but as soon as I tried to go back home, the problem was coming up consistantly, as long as I allowed the toll roads.
                          TomOnTour
                          TomOnTour
                          • Kaart niet zichtbaar
                            Bé Jeuring
                            Bé Jeuring
                          • Xpert overlay not clear
                          • Google maps
                            Ed Bos 0
                            Ed Bos 0
                          • Navigation Next op telefoon wel naar v6 maar Android 14 systeem op motor niet
                            Jaap van Maanen
                            Jaap van Maanen
                            Corrado Miniati 0
                            Corrado Miniati 0
