  3. [App] Announcements
  4. Update 5.0.3 - Device management
55 Posts 25 Posters 15.2k Views 8 Watching
  • Hagedorn Hans-Jürgen Hagedorn Hans-Jürgen
    Hello,
    I don't think this rule is right because I use one phone for motorcycle navigation, another for CarPlay, and an iPad for route planning on the go. Why can't it be like Spotify, where only one device can be logged in at a time? It's a shame; this makes the app unusable for many of my acquaintances, and I certainly can't recommend it anymore.
    @Hagedorn-Hans-Jürgen You won't even have an issue 🙂
    You are using 2 devices as intended and sometimes a third.
    When using the third you will be asked to unlist one of the other active devices which is a very smooth action with no impact at all.
      @Corjan-Meijerink The following scenario...
      The iPad is at home, ‘switched off’.
      I am riding my motorbike and have the Pixel 9 online navigation mobile phone and MRA active, and my everyday Pixel 9 mobile phone is also online, but the MRA app is NOT active. The Motorola Edge 40 is also being used in parallel with the navigation system and is ‘completely OFFLINE’. MRA is also active.
      What happens if I start the MRA app on my everyday mobile phone and want to make a correction to the route?
      From this point on, three devices would be active with MRA (BUT ONLY TWO DEVICES ARE ONLINE).
      Please reply.
      @Peter-Zehentreiter You would indeed be using too many devices.
      Contacting customer support is the way.
        @Corjan-Meijerink said in Update 5.0.3 - Device management:
        Also when one of these 3 devices is completely offline?
        BMW R 1250 GS
        DMD-NOR7E 7"
        SPC Universal mount
        Motorola Edge 40 "offline"
        Sena SLR 3
        Sena 50 R
          @Peter-Zehentreiter At one point you will be online and that's the point where we know what devices you used. In theory if you would never use internet we indeed cannot track the device 😉
          • Brian McG
            is there a way to access the page that shows which devices I have registered or do I need to exceed the limit before this information is available?
            • Brian McG Brian McG
              @Brian-McG from the account page in the app. There is a button to view your devices (near the bottom)
                Hi everyone! 👋
                It is time for a new update!
                Device management
                This is the core aspect of this update.
                Unfortunately we are seeing a massive amount of account sharing going on.
                At MyRoute-app we try our hardest every single day to be customer oriented and keeping our prices low. As of this year our base prices for subscriptions had to be increased (for the first time since 2021) and because of new contracts with our suppliers we also have to implement a device limit per subscription.
                As we now pay per active phone we cannot (ignorantly) allow users to use our app on an unlimited amount of phones. As of this update we allow a maximum of 2 devices to be used at the same time. When exceeding this limit (3 devices) you will be presented a beautiful interface in which you can deregister another device. After doing so, you can use your current phone again 😃
                Some important notes:
                • Excessively switching between multiple phones will lead to an automatic warning
                • Attempts to use way too many devices (4) at once will lead to an automatic block
                Our terms & conditions will be updated appropriately.
                Simply put: times of sharing your account with big groups of friends or your club are over, sharing with your partner / personal use on a few devices is still allowed.
                A full announcement can be read here: https://info.myrouteapp.com/limit-of-2-devices/
                SSO fixed
                Signing into the app using a SSO authentication method (such as Apple or Google) was broken. Luckily this has now been fixed! 🎉
                Link and file opening
                Opening links and files with the app has always been possible.
                In this update the stability of these features has been improved to ensure it works as expected when the app is in any state (such as terminated / in the background / opened).
                Audio stability Android
                In some rare cases a clean install of the app would not output any audio while navigating - this now seems fixed.
                Minor fixes and stability improvements
                Many small issues that are not relevant to mention here have been fixed.
                Also we fixed a few errors that would result in route calculations failing.
                Finally a few critical CarPlay / Android Auto errors have been solved and we added a bit more logging to investigate some persistent issues a few users have.
                What's next
                Slowly but surely we are transitioning to a more focused dedication on the website.
                In the next update 5.1 we will:
                • Aim for solving all stability issues CarPlay and Android Auto
                • Add highly requested features to CarPlay and Android Auto
                • Major technical internal updates
                Cheers,
                Corjan
                peha
                peha
                peha
                Is the "map spinning when stopped" issue also adressed (maybe even fixed) here?
                • peha peha
                  @peha haven’t worked on this explicitly
                  5.1 is fully dedicated to AA / CP
                  peha 1 Reply Last reply
                    peha
                    peha
                    peha
                    @Corjan-Meijerink Thanks for your reply. I will contact support via e-mail rather than discuss this further here, then, regarding this.
                    • Adrian Avram
                      As long as you don’t restrict the app to a single device, it sounds perfect.
                      The reason is that some of us take two phones on longer trips as a backup, in case the main phone gets stolen, damaged, or lost.
                      Other than that, I’m looking forward to version 5.1.
                      Adrian
                      • Adrian Avram Adrian Avram
                        @Adrian-Avram no definitely not.
                        2 is totally allowed
                        3 is with the required unlisting of another device (very smooth experience)
                        4 results in an issue 🙂
                        Adrian Avram Nick Carthew 3 Replies Last reply
                          @Corjan-Meijerink thanks for the confirmation !
                          Adrian
                            Does 4 mean that the heavy mob will be knocking on the door 🔨
                              V5.0.3 is available for iOS in the store ✋
                              • silberfuchs67
                                silberfuchs67
                                silberfuchs67
                                Sorry for asking, but I want to be sure that I understood the new handling. Using the navigation app on two devices and planning in the browser on my Mac/PC is still possible?
                                • silberfuchs67 silberfuchs67
                                  @silberfuchs67 100%!
                                  • silberfuchs67
                                    silberfuchs67
                                    silberfuchs67
                                    Thanks, exactly what is fine for me 👍
                                      @silberfuchs67 that’s why we’ve chosen the limits as is 🙂
                                      That said, the restriction only applies for the app anyway
                                      • ginogino
                                        ginogino
                                        ginogino
                                        I tried the new app yesterday on my bike. Even in this version of Android Auto, there's a bug where starting a route from Android Auto while you're already on the route takes you back to the starting point. I wonder what the point is of reporting bugs if they aren't fixed.
                                        Otherwise, everything works as usual.
                                        • ginogino ginogino
                                          #31
                                          @ginogino thats not a bug !
                                          Before starting a route, go to Routing Settings and choose whether you want to begin from the nearest point on the route.
                                          If this option is enabled, when you are already on the route, navigation will no longer direct you to the first waypoint.
                                          As I know, on Android Auto/Car Play, when starting a route, it automatically takes you to the the beginning of the route.
                                          Adrian
                                          ginogino 1 Reply Last reply
                                          Òscar
                                          Òscar
                                          peha
                                          peha
                                          Cleo
                                          Cleo
                                          RainerT
                                          RainerT
                                          silberfuchs67
                                          silberfuchs67
                                          ginogino
                                          ginogino
                                          richard 3v
                                          richard 3v
                                          Charles Rijken 0
                                          Charles Rijken 0
                                          dungbeetle
                                          dungbeetle
                                          Steve 2t
                                          Steve 2t
                                          Lechfelder
                                          Lechfelder
                                            Marcel Versluis
                                            Marcel Versluis
                                          • MRA Navigation Next: Synchronisation by folder
                                            Parantapa
                                            Parantapa
                                            TomOnTour
                                            TomOnTour
                                          • Android Auto TFT
                                          • Route punt overslaan
                                          • Notche
                                            Adriaan Vonk
                                            Adriaan Vonk
