  3. [App] Announcements
  4. Update 5.0.3 - Device management
55 Posts 25 Posters 14.6k Views 8 Watching
  • Hagedorn Hans-Jürgen
    Hello,
    I don't think this rule is right because I use one phone for motorcycle navigation, another for CarPlay, and an iPad for route planning on the go. Why can't it be like Spotify, where only one device can be logged in at a time? It's a shame; this makes the app unusable for many of my acquaintances, and I certainly can't recommend it anymore.
    Peter Zehentreiter Corjan Meijerink 2 Replies Last reply
    • Hagedorn Hans-Jürgen Hagedorn Hans-Jürgen
      Hello,
      @Hagedorn-Hans-Jürgen As far as I understand...you can have 2 devices parallel online, as soon as you start a 3rd device online, you have to close one Application of one of the running devices.
      So planning on the go should work as long as only two devices are online.
      Please enlighten me if this is not correct
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      • Lluis Arasanz
        Hi all,
        I found that device limit is something good to left no one abuse this application.
        I know also that more and more people installs in 2 phones (primary and backup) and uses a bigger screen, like a tablet, to route edit.
        Perhaps, the device limit can be "launch" when user tries to "Navigate" a route? This allow use more devices for planning scenarios with no limits , but only a max of 2 to navigate.
        • BMW F750GS
          Hello,
          @Hagedorn-Hans-Jürgen You won't even have an issue 🙂
          You are using 2 devices as intended and sometimes a third.
          When using the third you will be asked to unlist one of the other active devices which is a very smooth action with no impact at all.
            @Corjan-Meijerink The following scenario...
            The iPad is at home, ‘switched off’.
            I am riding my motorbike and have the Pixel 9 online navigation mobile phone and MRA active, and my everyday Pixel 9 mobile phone is also online, but the MRA app is NOT active. The Motorola Edge 40 is also being used in parallel with the navigation system and is ‘completely OFFLINE’. MRA is also active.
            What happens if I start the MRA app on my everyday mobile phone and want to make a correction to the route?
            From this point on, three devices would be active with MRA (BUT ONLY TWO DEVICES ARE ONLINE).
            Please reply.
            @Peter-Zehentreiter You would indeed be using too many devices.
            Contacting customer support is the way.
              @Corjan-Meijerink said in Update 5.0.3 - Device management:
              Also when one of these 3 devices is completely offline?
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
                @Peter-Zehentreiter At one point you will be online and that's the point where we know what devices you used. In theory if you would never use internet we indeed cannot track the device 😉
                • Brian McG
                  is there a way to access the page that shows which devices I have registered or do I need to exceed the limit before this information is available?
                  • Brian McG Brian McG
                    @Brian-McG from the account page in the app. There is a button to view your devices (near the bottom)
                      Hi everyone! 👋
                      It is time for a new update!
                      Device management
                      This is the core aspect of this update.
                      Unfortunately we are seeing a massive amount of account sharing going on.
                      At MyRoute-app we try our hardest every single day to be customer oriented and keeping our prices low. As of this year our base prices for subscriptions had to be increased (for the first time since 2021) and because of new contracts with our suppliers we also have to implement a device limit per subscription.
                      As we now pay per active phone we cannot (ignorantly) allow users to use our app on an unlimited amount of phones. As of this update we allow a maximum of 2 devices to be used at the same time. When exceeding this limit (3 devices) you will be presented a beautiful interface in which you can deregister another device. After doing so, you can use your current phone again 😃
                      Some important notes:
                      • Excessively switching between multiple phones will lead to an automatic warning
                      • Attempts to use way too many devices (4) at once will lead to an automatic block
                      Our terms & conditions will be updated appropriately.
                      Simply put: times of sharing your account with big groups of friends or your club are over, sharing with your partner / personal use on a few devices is still allowed.
                      A full announcement can be read here: https://info.myrouteapp.com/limit-of-2-devices/
                      SSO fixed
                      Signing into the app using a SSO authentication method (such as Apple or Google) was broken. Luckily this has now been fixed! 🎉
                      Link and file opening
                      Opening links and files with the app has always been possible.
                      In this update the stability of these features has been improved to ensure it works as expected when the app is in any state (such as terminated / in the background / opened).
                      Audio stability Android
                      In some rare cases a clean install of the app would not output any audio while navigating - this now seems fixed.
                      Minor fixes and stability improvements
                      Many small issues that are not relevant to mention here have been fixed.
                      Also we fixed a few errors that would result in route calculations failing.
                      Finally a few critical CarPlay / Android Auto errors have been solved and we added a bit more logging to investigate some persistent issues a few users have.
                      What's next
                      Slowly but surely we are transitioning to a more focused dedication on the website.
                      In the next update 5.1 we will:
                      • Aim for solving all stability issues CarPlay and Android Auto
                      • Add highly requested features to CarPlay and Android Auto
                      • Major technical internal updates
                      Cheers,
                      Corjan
                      peha
                      peha
                      peha
                      Is the "map spinning when stopped" issue also adressed (maybe even fixed) here?
                      • peha peha
                        @peha haven’t worked on this explicitly
                        5.1 is fully dedicated to AA / CP
                        peha 1 Reply Last reply
                          peha
                          peha
                          peha
                          @Corjan-Meijerink Thanks for your reply. I will contact support via e-mail rather than discuss this further here, then, regarding this.
                          • Adrian Avram
                            As long as you don’t restrict the app to a single device, it sounds perfect.
                            The reason is that some of us take two phones on longer trips as a backup, in case the main phone gets stolen, damaged, or lost.
                            Other than that, I’m looking forward to version 5.1.
                            Adrian
                            • Adrian Avram Adrian Avram
                              @Adrian-Avram no definitely not.
                              2 is totally allowed
                              3 is with the required unlisting of another device (very smooth experience)
                              4 results in an issue 🙂
                              Adrian Avram Nick Carthew 3 Replies Last reply
                                @Corjan-Meijerink thanks for the confirmation !
                                Adrian
                                  Does 4 mean that the heavy mob will be knocking on the door 🔨
                                    V5.0.3 is available for iOS in the store ✋
                                    • silberfuchs67
                                      silberfuchs67
                                      silberfuchs67
                                      Sorry for asking, but I want to be sure that I understood the new handling. Using the navigation app on two devices and planning in the browser on my Mac/PC is still possible?
                                      • silberfuchs67 silberfuchs67
                                        @silberfuchs67 100%!
                                        • silberfuchs67
                                          silberfuchs67
                                          silberfuchs67
                                          Thanks, exactly what is fine for me 👍
                                          RainerT
                                          RainerT
                                          silberfuchs67
                                          silberfuchs67
                                          peha
                                          peha
                                          Cleo
                                          Cleo
                                          ginogino
                                          ginogino
                                          richard 3v
                                          richard 3v
                                          Charles Rijken 0
                                          Charles Rijken 0
                                          dungbeetle
                                          dungbeetle
                                          Steve 2t
                                          Steve 2t
                                          Lechfelder
                                          Lechfelder
                                          • Missing info from CarPlay
                                          • File en omrijden
                                            Robineke
                                            Robineke
                                          • Geen pictogram van een motor
                                          • Routenplaner on iPad
                                            Risto Motorcycling
                                            Risto Motorcycling
