  2. MRA Café
  3. New group for MyRoute-app users on DMD2 systems
38 Posts 13 Posters 15.1k Views 5 Watching
  • silberfuchs67 silberfuchs67
    I‘d Like to ask the following question: in case you want to navigate within DMD2 a new route or track you will be asked if you would like to navigate with DMD2 or an external app. If I choose the external App, MRA the app won‘t start. This issue is only valid for MRA. Does anyone know about this issue?
    In case this should not be a topic here, please close or delete. Thanks.
    @silberfuchs67 said in New group for MyRoute-app users on DMD2 systems:
    ...in case you want to navigate within DMD2 a new route or track you will be asked if you would like to navigate with DMD2 or an external app...
    I slightly remind about this question. In the settings, you can disable this question.
    But the usual way to start is - like in MyRoute-App:
    if you have received a gpx file from anybody
    • transmit it to a data folder of the DMD device
    • may open DMD2 app, goto GPX-Manager and import the gpx into the app
      (that's similar to MRA-Routeplanner)
    • make the imported route or track visible on map
    • if start of route or track is close to your location, start to ride, navigation will start automatically
    • silberfuchs67
      silberfuchs67
      silberfuchs67
      Hi @Guzzist thanks for your support but I think it was a misunderstanding. I meant, if you decide within DMD2 to navigate the route with MRA the MRA App won‘t open. There is an error message. This issue happens only with MRA, Not with other naviagtion apps, e.g. Kurviger or ….
      • GHPA
        GHPA
        GHPA
        Same problem at my side. Mra start up but then message: this is taking longer than expected! And that is it. Other nav apps work like google maps. Reported problem at dmd2 but get answer that it is a mra problem also because other nav app works.
        • silberfuchs67
          silberfuchs67
          silberfuchs67
          Thanks @infohagentb.nl - this is exactly the issue I have.
          MartinW 1 Reply Last reply
          • Guzzist
            ...hmmm understood - but...
            Unfortunatelly I only remember slightly about this function. There is a option in the GPS-Settings of DMD2 app, which asks for.
            Long time ago, I have switched this option "off" because if I'm just using the DMD2 app (so, I'm inside the app) it seems pointless to me, to open then another app. If this would be my intention, I could open the other app directly upfront...
              MartinW
              MartinW
              MartinW
              wrote on last edited by MartinW
              #31
              @silberfuchs67
              Hmmm..., can't confirm this issue.
              I tried it several times, and it worked flawlessly. Are you sure you selected a routable destination?
              Guzzist 1 Reply Last reply
              • silberfuchs67
                silberfuchs67
                silberfuchs67
                I‘ll give it a try and keep you informed!
                • MartinW MartinW
                  @silberfuchs67
                  #33
                  @Martin-Wilcke ...thank you Martin, by the help with your Screenshots, now I remember by which action the question about "external app" occurs.
                  And yes - after I have switched on this question in the settings - I can confirm: routing by external app (in this case MyRoute-App) works correct as expected.
                  But I stand by my opinion: searching for a destination in the app – only to then be navigated by another app – is strange in my view. I might as well use the other app for searching and navigation.
                  • Guzzist Guzzist
                    MartinW
                    MartinW
                    MartinW
                    @Guzzist
                    DMD2 does not support using traffic data for calculation/navigation, whereas MRA does (under certain conditions).
                    Therefore, I use this feature when I have the following use case:
                    • I navigate a track with DMD2
                    • I would like to “shorten” a part for some reason by travelling as quickly as possible (also using traffic data)
                    • I select a destination point on my track and transfer this location to MRA using the method explained here
                    • This initiates an A-B routing in MRA, calculating the fastest route, and taking traffic data into account
                    • Once I have reached my destination point, I switch back to DMD2 to continue navigating my track
                    • MartinW MartinW
                      @Guzzist
                      @Martin-Wilcke ahhh got it - and I learned something new again 😊
                      But I have never used such a possibility, because where I'm usually riding - there is no traffic 😜 😜
                      • Guzzist Guzzist
                        MartinW
                        MartinW
                        MartinW
                        @Guzzist
                        I completely agree - trees don't move 🙂
                        But it's always good to have a few tools and solutions at hand, just in case...
                        • MartinW MartinW
                          @Guzzist
                          @Martin-Wilcke 😊 😁
                          • silberfuchs67
                            silberfuchs67
                            silberfuchs67
                            @Martin-Wilcke just tried your example starting the route via external app (MRA) and it didn‘t work. Got the same error message like @infohagentb.nl mentioned. This seems only to be valid for MRA.
                            MartinW
                            MartinW
                            GHPA
                            GHPA
                            Thomas Neumeyer
                            Thomas Neumeyer
                            silberfuchs67
                            silberfuchs67
                            Huibertus
                            Huibertus
                            Rob Kilbourne
                            Rob Kilbourne
                            Niek 4
                            Niek 4
                              Alderweireld Rudi 0
                              Alderweireld Rudi 0
                              Hanza 0
                              Hanza 0
                            • Weather as a service
                              Jack 13
                              Jack 13
                            • 1 bij app icoontje
                            • Map Layers
                              Don Stauffer
                              Don Stauffer
                              Andy Smith 5
                              Andy Smith 5
