  4. Layer menu displayed without calling it
15 Posts 6 Posters 2.7k Views 4 Watching
  • Lluis Arasanzundefined Offline
    Also…. Using web route planner from Safari does not shows this behavior, while in-app navigator does.
    • BMW F750GS
    b0hd1undefined 1 Reply Last reply
    • Lluis Arasanzundefined Lluis Arasanz
      b0hd1undefined Offline
      @Lluis-Arasanz Thanks again, Lluís, for reporting what isn't working correctly and not trying to hide it by explaining what is. We're here to improve the product, not to conceal its flaws. Keep it up!
      • https://t.me/MRa_by_b0hd1
      • YouTube: @demco17
      • b0hd1undefined b0hd1
        @b0hd1, we are also here to see if it really is a flaw, or for example ghost-touch by a dirt or defective screen, or any other reason. Since this is the first question like this in many years, I cannot imagine it is induced by the app itself. One way to test is to try to reproduce this on other devices. The fact that it does not do that in Safari is good to know, but not a definitive reason to call it bug or being induced by the app itself, since the tap location can be slightly different. Of course you can also submit a support ticket. But what @Rob-Verhoeff says is correct, not much development will be done on the current web planner, especially not for one single person having a problem with it, that can be solved otherwise.
        Lluis Arasanzundefined 1 Reply Last reply
          @Con-Hennekens ,
          This has been verified on, at least, 2 different devices.
          First, a team mate with iPhone 17
          Second, on my iphone 14.
          I can't reproduce on Android phone (the one I use on Bike) nor in iPad (also with IOS 26.2)
          I used In-App Web planner before and do not noted this behavior.
          Perhaps is not a bug, is only a missfunction o a ghost touch, but I think this is rare o two different same brand, different model phones used by 2 different people.
          Also, is not first time that any programmer can install a bug (new or old) on a new software version. I do not say this is the problem, bun no one has the True.
          After that, perhaps development team can make a test on other iphone also.
          Best Regards
          • BMW F750GS
            @Con-Hennekens ,
            Best Regards
            @Lluis-Arasanz, yes it is good to know that it is reproducible, at least on two very different iPhones. I cannot help there, since I have no iPhone 😉 . If it is really cumbersome you can submit a support ticket of course.
            • Nick Carthewundefined Online
              @Lluis-Arasanz Can I suggest that in the toolkit you turn off Ask for waypoint name then there are fewer interactions with the screen. I have tested by making several routes using my iPhone 11 iOS 26.2 and I cannot reproduce your problem. Test video
              Lluis Arasanzundefined 2 Replies Last reply
                @Nick-Carthew
                Yes, this is a good point of view. Both of us will try and post results here.
                Thank's!!!
                • BMW F750GS
                  @Nick-Carthew
                  We check it:
                  • With Toolkit option "Ask for waypoint name" on, Layer selecton menu appears "randomly even not touching near button icon.
                  • Deactivating "Ask for waypoint name", all works as expected.
                  Have you tested with this option on? At least, to see if it's a global behavior or not.
                  Thanks for suggest!
                  • BMW F750GS
                  Con Hennekensundefined Nick Carthewundefined 2 Replies Last reply
                    @Nick-Carthew
                    We check it:
                    Thanks for suggest!
                    @Lluis-Arasanz, that's a good find!
                      @Nick-Carthew
                      We check it:
                      Thanks for suggest!
                      @Lluis-Arasanz Yes I have tested. I believe it happens because of the position of the OK button for the waypoint name is on top of where the overlay maps are.
                        @Nick-Carthew
                        Great!
                        Thank's again for suggest.
                        • BMW F750GS
                        • Aiello antoninoundefined Offline
                          With iPhone 16 plus and iOS 18, option active, it doesn't happen, it doesn't happen on iPad Air 4 with iOS 26 either, I wouldn't want to fix an iOS 26 problem on iPhone...
                          b0hd1undefined
                            pehaundefined
                            peha
                            Stephen l. Weberundefined
                            Stephen l. Weber
                          • Veekeersinfo en omleiden
                          • Last Route selection inconsistant
                            RetiredWingManundefined
                            Leike Lodiersundefined
