  4. Layer menu displayed without calling it
15 Posts 6 Posters 5.2k Views 4 Watching
  • Lluis Arasanz
    @Rob-Verhoeff
    I know but the problem is that this behavior is not shown on iPad (portrait or landscape) nor on Android.
    I only reproduce on iPhone.
    And yes, I tried other functions of app, but this post is done for a colleague that does not have English knowledge and can’t send the post.
    I don’t know when web planner will be revamped, but, meanwhile, users can use it in the way they know. Also, even in-app planner is good, it’s not so good as web planner, which is more known for users.
    • BMW F750GS
    • Lluis Arasanz
      Also…. Using web route planner from Safari does not shows this behavior, while in-app navigator does.
      • BMW F750GS
      Òscar 1 Reply Last reply
      • Lluis Arasanz Lluis Arasanz
        Òscar
        Òscar
        Òscar
        @Lluis-Arasanz Thanks again, Lluís, for reporting what isn't working correctly and not trying to hide it by explaining what is. We're here to improve the product, not to conceal its flaws. Keep it up!
        • https://t.me/MRa_by_b0hd1
        • YouTube: @demco17
        • Òscar Òscar
          @b0hd1, we are also here to see if it really is a flaw, or for example ghost-touch by a dirt or defective screen, or any other reason. Since this is the first question like this in many years, I cannot imagine it is induced by the app itself. One way to test is to try to reproduce this on other devices. The fact that it does not do that in Safari is good to know, but not a definitive reason to call it bug or being induced by the app itself, since the tap location can be slightly different. Of course you can also submit a support ticket. But what @Rob-Verhoeff says is correct, not much development will be done on the current web planner, especially not for one single person having a problem with it, that can be solved otherwise.
            @Con-Hennekens ,
            This has been verified on, at least, 2 different devices.
            First, a team mate with iPhone 17
            Second, on my iphone 14.
            I can't reproduce on Android phone (the one I use on Bike) nor in iPad (also with IOS 26.2)
            I used In-App Web planner before and do not noted this behavior.
            Perhaps is not a bug, is only a missfunction o a ghost touch, but I think this is rare o two different same brand, different model phones used by 2 different people.
            Also, is not first time that any programmer can install a bug (new or old) on a new software version. I do not say this is the problem, bun no one has the True.
            After that, perhaps development team can make a test on other iphone also.
            Best Regards
            • BMW F750GS
              @Con-Hennekens ,
              Best Regards
              @Lluis-Arasanz, yes it is good to know that it is reproducible, at least on two very different iPhones. I cannot help there, since I have no iPhone 😉 . If it is really cumbersome you can submit a support ticket of course.
              • Nick Carthew
                @Lluis-Arasanz Can I suggest that in the toolkit you turn off Ask for waypoint name then there are fewer interactions with the screen. I have tested by making several routes using my iPhone 11 iOS 26.2 and I cannot reproduce your problem. Test video
                Lluis Arasanz 2 Replies Last reply
                  @Nick-Carthew
                  Yes, this is a good point of view. Both of us will try and post results here.
                  Thank's!!!
                  • BMW F750GS
                    @Nick-Carthew
                    We check it:
                    • With Toolkit option "Ask for waypoint name" on, Layer selecton menu appears "randomly even not touching near button icon.
                    • Deactivating "Ask for waypoint name", all works as expected.
                    Have you tested with this option on? At least, to see if it's a global behavior or not.
                    Thanks for suggest!
                    • BMW F750GS
                    MotoCon Nick Carthew 2 Replies Last reply
                      @Nick-Carthew
                      We check it:
                      Thanks for suggest!
                      @Lluis-Arasanz, that's a good find!
                        @Nick-Carthew
                        We check it:
                        Thanks for suggest!
                        @Lluis-Arasanz Yes I have tested. I believe it happens because of the position of the OK button for the waypoint name is on top of where the overlay maps are.
                          @Nick-Carthew
                          Great!
                          Thank's again for suggest.
                          • BMW F750GS
                          • Aiello antonino
                            With iPhone 16 plus and iOS 18, option active, it doesn't happen, it doesn't happen on iPad Air 4 with iOS 26 either, I wouldn't want to fix an iOS 26 problem on iPhone...
                            Òscar
                            Òscar
                            • Startpunt wijzigen
                              Giancarlo e
                              Giancarlo e
                            • Route exporteren uit beta
                              Ed van Klink
                              Ed van Klink
                            • Vrienden toevoegen
