  4. Map "spinning" when standing still
110 Posts 33 Posters 46.7k Views 10 Watching
    Hi, I had this the other day on countryside. When I stopped the screen turns half to one site and then 360° to the other side and then stays mostly in other direction then you have to drive.
    When I tried to make a screen recording (what is difficult during driving) it was gone, I could not replicate it that day.
    I will try next time.
    @Jörgen, I think we all know what it looks like, just don't try to make screen recordings while driving, stay safe instead 😉
    • Thomas Neumeyer
      Thomas Neumeyer
      Thomas Neumeyer
      Updated my Samsung Tab with 5.0.0. Same spinning while standing like on the Ulefone. Regards Thomas
        I’ll investigate this more in depth for 5.0.2 🙂
        peha 1 Reply Last reply
          peha
          peha
          peha
          @Corjan-Meijerink That's great to hear. 👍
            Thank you very much for your care. I know safety comes first. That's why I started the screen recording beforehand today. And I edited the video afterwards.
            I had to stop at that point (at 38 seconds) because of oncoming traffic.
            The direction of travel was clear here, but when you're standing at an intersection and the screen rotates like that, it's not clear.
            Anyway, just to demonstrate: https://youtu.be/t1NSoV13yYs
            • Herman Veldhuizen
              #26
              same here. more spinning with v5 when standing still. Android.
              The app seams to think that i am moving. In the video I am standing still roughly where the flag is.
              https://drive.google.com/file/d/1-D0rNg9ln68wxD20lb55MHg3RJQ8ech-/view?usp=drivesdk
                @Herman-Veldhuizen what version of the app are you using. In 433 it should have been solved
                  @Marinus-van-Deudekom that’s not true.
                  I’ll look into the subject for next update
                  • Travellexxie
                    Ik heb samen met Hans een paar kleine testjes gedaan. Beide zitten we in onze woonkamer (ik zit stil in Wachtberg Duitsland, geen idee wat hij uithaalt, maar hij schijnt in Helmond te zitten 😆) hij met z'n iPhone 16 plus met IOS 26.1, ik met aan de ene kant van mijn bureau een Samsung Galaxy S22 Ultra met Android 16 en aan de andere kant een Samsung Tab Active4 Pro met Android 15.
                    Locatiegegevens bij alle drie op maximaal (Toegestaan bij gebruik App vs Altijd toestaan, gaf een gering verschil). Waar bij Hans de cursor stil bleef staan. Danste hij bij mij (op beide apparaten) door de hele buurt, met een verschil in locatie van ca 100 meter. Ik was (wonend op nummer 4) vnl. bij de buren van 10 op bezoek, volgens beide apparaten. Pas na ca. 1,5 minuut werd het hem duidelijk, dat ik toch echt op 4 zat, maar niet echt heel enthousiast.
                    Zou het dan toch een IOS vs Android/Samsung dingetje zijn, of is onze locatie zo duidelijk anders qua ontvangst? 🤔
                    Nu maar hopen, dat mijn robotstofzuiger mijn slaapkamer weet te vinden. 🙈
                    • Herman Veldhuizen
                      wat is zie is dat het vaak gebeurt als er 2 wegen naast elkaar liggen. dan springt de cursor heen en weer van de ene weg naar de andere en weer terug
                        @Corjan-Meijerink oeps, ik dacht dat het al gefixed was
                          Hi, wenn Ihr in Niederländisch schreibt, brauche ich ja auch nicht meinen Text zu übersetzen und kann in Deutsch schreiben. 😘
                          @Lex.Kloet.RX innerhalb eines Gebäudes ist das doch normal, der Satellitenempfang ist da zu schlecht.
                          Heute hat sich die Karte auch ein paar mal an einer Kreuzung gedreht, wenn man gerade steht, ist das doof, man weiß erstmal nicht in welche Richtung man fahren muss.
                            wrote on last edited by Travellexxie
                            #33
                            @Jörgen das ist mir bekannt, es ging mir um das verschiedene Verhalten. Aber ich habe das öfters, das bei mir bei Ampeln am Rad gedreht wird. 😵‍💫
                              I've investigated the issue, found a possible cause and implemented changes in 5.0.2.
                              Will need some extensive beta testing on different devices but I'm hopeful the issue will be resolved 🙂
                                Wanneer ongeveer komt deze Beta (5.0.2) beschikbaar zodat ik eventueel wat kan plannen om te testen; Ik heb ook last van dit "spinning" als ik bij verkeerslichten of een kruising stil sta!
                                  Expecting after the weekend but maybe I'll submit it tomorrow 😉
                                  Depending on the platform you are using it will also take another day or two before it's available.
                                  • peha
                                    peha
                                    peha
                                    wrote on last edited by peha
                                    #37
                                    @Corjan-Meijerink Are more beta testers needed? I'd be willing to test a little, if it helps (my setup is noted in the footer: Android with two AA-devices).
                                      I did see it on my normal navigation phone on a few trips. Today i use my daily phone, which i only use in the car for navigation (not on my bike). On this phone i saw the behaviour also
                                      Both were running Android Auto.
                                      On the bike it spins more than once on the same spot (but not constant) mostly back and forth. In the car mostly it spins only once. Just as soon as i stopped.
                                      Let's what the new version brings
                                      • Albert van den Elsen
                                        This issue may simply be due to a weak GPS signal. I don’t think it’s related to MRA.
                                        iPhone 15,
                                        Carpuride W702 Pro
                                        Sena 20S EVO headset
                                        Harley Davidson Road King M8
                                          @Albert-van-den-Elsen my Guess is that it's the combination of some type of phones, mostly Android based and some AA/CP devices. I havent seen the issue at all.
                                          • 4
                                          • 5
                                          • 6
                                          peha
                                          peha
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          Bill Harrison
                                          Bill Harrison
                                          TomOnTour
                                          TomOnTour
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                          Paul Steinberg
                                          Paul Steinberg
                                            3.6k
                                            Robineke
                                            Robineke
                                            Reinhard Grossmann h 0
                                          • Overlay Routes like the App does and waypoints without routes
                                            Rob Kelley
                                            Rob Kelley
                                          • Route Breakdown
                                            Scarecrow
                                            Scarecrow
                                          • Brittany routes
                                            Tony 13
                                            Tony 13
                                          • Vergrendel scherm zet alles op z'n kop
