  4. Map "spinning" when standing still
110 Posts 33 Posters 52.7k Views 10 Watching
    Is this a HERE internal problem ???
    Noticed to see as a hint:
    • This also seems very familiar to me, one reason is that the MRA machine internally means that you turn and turns the map in the planned direction of the tour, unfortunately the MRA machine does not know exactly that you unfortunately had to stop before turning, and since it does not go any further, the card changes back and that goes back and forth....
    Proposal for the MRA machine:
    • The turn and the associated arrow position of the location should be followed more slowly and not hastily so that the turning can also be done safely on the map ...
    So it is better solved with other apps and does not irritate so much.
    • Currently it is important to know where the route should actually lead in such an incident and without looking at the map ..!
      I noticed the same on my tablet.
      peha
      peha
      peha
      wrote on last edited by peha
      @Corjan-Meijerink said in Map "spinning" when standing still:
      Haven't seen it myself!
      That said, it can indeed be caused by "incorrect" location updates.
      Not an issue exclusive to MRA.
      @Corjan-Meijerink You can see an example of the problem in this video (I had my passenger film this with their phone, so that my own phone was exactly as it always is while navigating and the "setup would not be compromised" by moving the phone that controls the navigation): once I stop at a traffic light during navigation, the map rotates. Often, that also triggers rerouting. It happens both in my car and on the motorcycle (same phone, different Carpuride devices).
      This only happens with MyRouteApp; with other apps I use, this doesn't happen. It seems rude to post apps other than the one this forum is about, so I didn't include it, but I also had my passenger film a similar situation a few minutes later with a different app, same phone (unmoved), same ride, and no such unwanted rotation happens.
      I really hope a solution might be found for this? ❓🙂
      • LE DIZES Freddy
        LE DIZES Freddy
        LE DIZES Freddy
        idem pour moi , il me semble que c'est surtout en ville , lorsque je m'arrête en campagne , je n'ai pas ce problème
        ça le faisait aussi avec les autres versions
        • Peter Zehentreiter
          Can confirm that I had the same issue last week, with the new version 5, but it happened also in the previous version.
          Pixel 9 / all settings up to date
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Motorola Edge 40 "offline"
          Sena SLR 3
          Sena 50 R
          • peha
            peha
            peha
            @Corjan-Meijerink Do you plan to investigate this phenomenon further, as it seems there are a number of users experiencing this, not just me?
              I stand by my previous statement: https://forum.myrouteapp.com/post/71634 😉
              The issue is definitely not related to v5 specifically. Yes, it can be annoying but there are so many factors that can cause the issue which makes it hard to investigate. After driving with quite a bit of Android Auto / CarPlay lately I can only confirm that I did not observe the behavior.
              • MotoCon
                I actually find it helpful for orienting on the surroundings... 😉
                But I never could discover under what circumstances it happens, and when not.
                • peha
                  peha
                  peha
                  Thank you for your reply. It's possible that I just didn't notice it as much before. What I can say for sure, though, is that it now occurs at practically each and every single stop when driving through Berlin (i.e. every three minutes), which is really annoying and makes it necessary to memorize which way to go before your stop (so that one can drive the desired route despite the unwillingly recalculated navigation pointing in a wrong direction. And that's a bad thing for a navigation app, I would say!
                  It has been said by others above that it seems to be a problem while driving through the city rather than the countryside. Maybe you have driving mostly outside urban areas?
                  I understand it might be hard to debug, but given that this happens with none of the other navigation apps I have installed, it's obviously a MRA-specific (or HERE-specific) problem. And I don't think the hardness of a problem's debuggability is a helpful measure in software engineering in order to achive a great product.
                    Hi, I had this the other day on countryside. When I stopped the screen turns half to one site and then 360° to the other side and then stays mostly in other direction then you have to drive.
                    When I tried to make a screen recording (what is difficult during driving) it was gone, I could not replicate it that day.
                    I will try next time.
                      @Jörgen, I think we all know what it looks like, just don't try to make screen recordings while driving, stay safe instead 😉
                      • Thomas Neumeyer
                        Thomas Neumeyer
                        Thomas Neumeyer
                        Updated my Samsung Tab with 5.0.0. Same spinning while standing like on the Ulefone. Regards Thomas
                          I’ll investigate this more in depth for 5.0.2 🙂
                          peha 1 Reply Last reply
                            peha
                            peha
                            peha
                            @Corjan-Meijerink That's great to hear. 👍
                              Thank you very much for your care. I know safety comes first. That's why I started the screen recording beforehand today. And I edited the video afterwards.
                              I had to stop at that point (at 38 seconds) because of oncoming traffic.
                              The direction of travel was clear here, but when you're standing at an intersection and the screen rotates like that, it's not clear.
                              Anyway, just to demonstrate: https://youtu.be/t1NSoV13yYs
                              • Herman Veldhuizen
                                #26
                                same here. more spinning with v5 when standing still. Android.
                                The app seams to think that i am moving. In the video I am standing still roughly where the flag is.
                                https://drive.google.com/file/d/1-D0rNg9ln68wxD20lb55MHg3RJQ8ech-/view?usp=drivesdk
                                  @Herman-Veldhuizen what version of the app are you using. In 433 it should have been solved
                                    @Marinus-van-Deudekom that’s not true.
                                    I’ll look into the subject for next update
                                    • Travellexxie
                                      Ik heb samen met Hans een paar kleine testjes gedaan. Beide zitten we in onze woonkamer (ik zit stil in Wachtberg Duitsland, geen idee wat hij uithaalt, maar hij schijnt in Helmond te zitten 😆) hij met z'n iPhone 16 plus met IOS 26.1, ik met aan de ene kant van mijn bureau een Samsung Galaxy S22 Ultra met Android 16 en aan de andere kant een Samsung Tab Active4 Pro met Android 15.
                                      Locatiegegevens bij alle drie op maximaal (Toegestaan bij gebruik App vs Altijd toestaan, gaf een gering verschil). Waar bij Hans de cursor stil bleef staan. Danste hij bij mij (op beide apparaten) door de hele buurt, met een verschil in locatie van ca 100 meter. Ik was (wonend op nummer 4) vnl. bij de buren van 10 op bezoek, volgens beide apparaten. Pas na ca. 1,5 minuut werd het hem duidelijk, dat ik toch echt op 4 zat, maar niet echt heel enthousiast.
                                      Zou het dan toch een IOS vs Android/Samsung dingetje zijn, of is onze locatie zo duidelijk anders qua ontvangst? 🤔
                                      Nu maar hopen, dat mijn robotstofzuiger mijn slaapkamer weet te vinden. 🙈
                                      • Herman Veldhuizen
                                        wat is zie is dat het vaak gebeurt als er 2 wegen naast elkaar liggen. dan springt de cursor heen en weer van de ene weg naar de andere en weer terug
                                          @Corjan-Meijerink oeps, ik dacht dat het al gefixed was
                                          • 4
                                          • 5
                                          • 6
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          TomOnTour
                                          TomOnTour
                                          Albert van den Elsen
                                          Paul Steinberg
                                          Paul Steinberg
                                          peha
                                          peha
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Bill Harrison
                                          Bill Harrison
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
