  4. Audio cuttet via Bluetooth
72 Posts 15 Posters 35.4k Views 7 Watching
  • nomko
    Banned
    wrote on last edited by nomko
    Okay... I'm not the only one i see. I thought it was my (cheap Aliexpress) bluetooth headset... But apparently it is not. I never paid any attention to it or got frustrated about it since i assumed it was my headset causing this issue.
    Love to see a fix!
    • MotoCon
      Yes, I have already experienced this in alpha stage indeed, but we were unable to verify that this is unexemplary behaviour. In fact after some attempts to fix it, we were convinced the problem is down to my Ford Sync3 headend (which is known to be problematic in multiple areas...).
      It would be nice to know with which Android Auto systems you are having this problem.
      For the record, in my case: what happens is that the first syllables of any voice instruction are being cancelled. The audio duck (lowering the music volume) is done immediately before the first (wrong) syllable is audible (which is very abrupt, one second would be nice). After the voice instruction, it takes about 4 seconds for the audio duck to return to normal volume (which is far too long in my opinion). It happens ONLY when connected to Android Auto, with music coming from the headend itself (so NOT when your phone is the music source).
      • Jan Weerheim
        Jan Weerheim
        Jan Weerheim
        Mijn ervaring: als de autoradio in gebruik is slikt de routebegeleiding bij mij ook de eerste woorden in. Als ik muziek speel via spotify (android auto) dan wordt alle teks wel uitgesproken.
          I remember the TomTom Rider days when you could still edit the audio files yourself. Some headsets also had this problem. The solution was to extend each audio file by half a second at the beginning. This was because the Bluetooth connection had to be established before the audio file was sent.
          I don't know how much this helps. Nowadays, the announcements are generated by the smartphone itself. Perhaps you would have to open the channel first and then start the announcement with a delay.
            It's a frustrating issue indeed.
            We verified that we do everything correctly (in theory) 😉
            I've delayed the start of the audio instructions by 1 second if you are connected to Android Auto but Android Auto almost seems to ignore this.
            As users also indicate, the behavior differs depending on if you are listening to the car radio or to spotify. But we don't know what you are listening to.
            We simply communicate to Android:
            • MyRoute-app wants priority
            • Please "duck" (lower the volume of) other apps
            • Wait 1 second (if connected to Android Auto) otherwise we don't add an extra wait
            • Speak the instruction
            • Tell the OS we are finished so other audio can gain priority again
            This is how it should work and how it works well for a lot of users.
            The whole ecosystem of Android, the amount of different (bluetooth) configurations, Flutter as development platform and our priorities simply don't help in getting this solved 🙂
              @Corjan-Meijerink, Indeed, the 1 second pause did seem to help, but it is just not enough, for my specific case I mean. You absolutely cannot introduce a longer pause everyone not having this problem 😉 My theory, not being held back by any knowledge, is that some AA devices simply do not honour the "wants priority" command, but listen to audio (voice) itself and decide (too late) to duck for themselves.
              Yes, but that is quite logical. When playing spotify (or anything else) from your phone, the media channel is continuously open. The phone ducks spotify, and not AA.
              • Haug
                Haug
                Haug
                In scenic for instance, I have 2 seconds audio delay and it works perfect.
                • Haug
                  Haug
                  Haug
                  Remark: this happens even, if the iPhone is directly connected to Bluetooth headphones without CP or AA
                  • Haug Haug
                    @Haug, thanks for this. This proves that not only MRA is struggling with this problem...
                    @Corjan-Meijerink, what do you think about this?
                      I've this problem also. Already for a while. It was introcduced in one of the latest 4.** version.
                      My headset did not change. The software of the headset did not change. The settings of my headset did not change.
                      The android auto setup did not change (built-in Honda Goldwing). The software of the Goldwing did not change.
                      The Android phone did not change.
                      But...
                      Offcourse there where severall software updates on my phone. MRA, Android Auto app, others apps.
                      When i play Spotify or other media, the audio of MRA is not cut of at the front. But if MRA is only source of audio. Then the first word or words (about 0.5-1 sec of text) is cut off.
                      This behaviour is in my situation very stable.
                        In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
                        nomko 1 Reply Last reply
                        • Haug
                          Haug
                          Haug
                          One remark: it has nothing to do with AA oder CarPlay, it’s even if you connect your iPhone directly via bluetooth without any CarPlay or android auto.
                          • Haug Haug
                            @Haug, Probably, but only when your head unit is doing the audio ducking of music playing from the head unit itself.
                            Haug 1 Reply Last reply
                              Haug
                              Haug
                              Haug
                              @Con-Hennekens I never hear Musik during motorcycling, I just listen to my boxer 😉
                              • Haug Haug
                                @Haug, Sometimes I do, only when driving alone. But that is not the point. I don't use AA on the bike. I do in my car. No boxer sounds te prefer there 😉
                                  Haug
                                  Haug
                                  Haug
                                  I use chigee with CarPlay but as I wrote, it has nothing to do with CP because the sound goes not via CarPlay and the cut of the voice is there, when contacted via Bluetooth to a headset or even to my Autoradio
                                  • Haug Haug
                                    @Haug, Yes, same thing... It happens not AA specifically indeed, but when an audio headend has its own failing logic for when to lower its music channel in favor of instructions from your phone, instead of trusting the priority commands of the connected equipment. So you are correct, it also happens with other then AA connections.
                                    Most important thing: has it been solved for your specific setup?
                                    • Haug Haug
                                      Hello MRA User,
                                      I have the Problem, that Audio commands via bluetooth a cuttet at beginning. When I use Audio Output via the iPhone speaker, everything works fine.
                                      For sure it has to do with Delay to the Bluetooth device.
                                      On other Apps you can set up a Delay for Bluetooth Audio.
                                      Anybody Else with this Problem?
                                      Thanks
                                      Günter
                                      Robert Laudensack
                                      Robert Laudensack
                                      Robert Laudensack
                                      @Haug Yes I also noticed cut voice prompts. It starts saying something, but the cuts of in the middle of it
                                      • Haug
                                        Haug
                                        Haug
                                        I set now a delay of 2 sec but the beginning of the speech is still cuttet.
                                        • Haug Haug
                                          @Haug, can you please check the version of the app?
                                          Main screen, tap the account icon top right, scroll completely down.
                                          What's the number there?
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                          • Elektrisch rijden
                                            John mq
                                            John mq
                                            Albert van den Elsen
                                          • Verminkte route op TomTom.
                                            Jacob Waterweg
                                            Jacob Waterweg
                                          • Audio cuttet via Bluetooth
                                            35.4k
                                          • Probably a me thing
                                            Solo1138
                                            Solo1138
                                          • MRA V6.0.0 (531) Download offline maps ?
                                          • Statement on Commercial Clubs
