  4. Something super weird happened while navigating with MRA App...???
7 Posts 5 Posters 1.4k Views 3 Watching
  • LennyO Offline
    LennyO Offline
    Created a route as usual with HERE maps, Highways and Unpaved roads avoided.
    Here it is: link text
    Towards the middle of the ride, all of a sudden, the app started directing me into side streets to make a loop or a U-turn at the end of the street and come back to the Route.
    I ignore it, it tries to do the same at the next upcoming street along the route. Happened many times...
    I cancelled the Navigation, loaded the route again and it did the same thing.
    The interesting point is that I had that route loaded into my Zumo XT, which was running concurrently
    ( I am testing the MRA App for reliability). And Zumo had NON OF THAT happening....
    So, I wonder... was anything done to the App behind the scenes recently and not announced???
    Should I delete and completely re-install the APP????
    It's just WEIRD and does not make me feel warm and fuzzy using the App...
    Thanks, all!
    Nick Carthew Marinus van Deudekom 2 Replies Last reply
    • Hubert Thoring Offline
      @Lenny-O : Hi, I'd like to check the exact location of the waypoints.
      Note: The MRA app routes based on the HERE map, and only that map matters if you're navigating with it.
      So, plan your route using OSM, TomTom, or HERE, but at the end, set the calculation to HERE and check it on the HERE map. Then it should work.
      Tip: Never place waypoints too close to junctions. Always place them after the junction, then 100 meters further on, and so on.
      Best regards
        @Lenny-O ; Your route is fine with the HERE map and HERE navigation in the web planner, then please check your phone's navigation settings: in front of the start button, below that is the Avoidances menu, swipe up to access it.
        • LennyO LennyO
          Thanks, all!
          Nick Carthew Offline
          @Lenny-O In situations like this the upcoming waypoint icon can tell you what is going on. If it is showing the number of the waypoint that you should have passed, then the chances are that the app is attempting to send you back to it as it wasn’t registered as being passed. A tap or long press of the upcoming waypoint icon will skip that waypoint and hopefully the app will continue to route you.
          • Aiello antonino Offline
            It happened to me too a few weeks ago, the Waypoints were positioned correctly, and I also had the zumo xt which instead indicated the entire itinerary correctly, I too am getting used to travelling with MRA, I closed the app completely, reopened it and started again and it seemed solved…
            • LennyO LennyO
              Thanks, all!
              Marinus van Deudekom Offline
              @Lenny-O i've looked at your route
              The only thing I noticed that you had the OSM layer active while using the Here map. Shouldn't be a problem. The other thing was that you used the motorcycle profile.
              When I set the map layer to Here and changed to profile to car I looked at the waypoints again.
              They where still spot on so that's not the problem
              The only thing I van think of is like @Nick-Carthew suggested that you somehow missed a waypoint and therefore were sent back to one
                In this case, it is recommended to set the app to automatically skip WP, or to use a BT keyboard to see early by zooming that an illogical reversal follows. VG
                  Simon James Hancock
                  Simon James Hancock
                  8.8k
                  Albert Jan Gombert
                  Albert Jan Gombert
                • Hi Folks
                • route niet zichtbaar op audi scherm
                • Embedding daily routes into a whole trip route file - How do I do this?
                • Zumo XT3/Tread
