  3. [App-Beta] Announcements
  4. Update 5.0 - major app overhaul!
65 Posts 22 Posters 557 Views 11 Watching
    Indeed, the placement of waypoints is way off in planning mode. I (we) missed that completely in our alpha testing, because we were unaware that anything concerning the changed GUI would impact the (as we thought unchanged) planner module. This proves the value beta testing 😉
    On my tablet (Samsung Galaxy Tab S8 5G, Android 15, One UI 7.0) it's working perfect to place waypoints by MRA-Routeplanner - in portrait orientation. But in landscape orientation, I recognise same issues.
    • Bart De Medts
      Really put the MyRoute-app beta to the test today: 315 km ridden and every single instruction was spot on.
      This one’s going to be a winner! 💛
      • Guzzist
        It's not an issue of new app version 5.0.0 - 418 - it's also in app version 4.4.1 - 410:
        Now, route planning and navigation is going over a street, which is actually closed for roadwork. The map does not longer show the icon for road closed, but only for roadwork!
        I'm sure some months before it was correct: route planning and navigation was using a detour. By the way: GoogleMaps is presenting as road closed and is navigating by detour.
        • Guzzist
          Because now, the selection buttons on start page of MRA-Routeplanner are organised as flat list (before, the buttons were in 2 columns) - now I need to scroll down to enter a target destination. It's at 4th poition.
          Ok, to scroll is not a big thing - but if developers wanted to make it more easy (less clicks) to start navigation - it could be shorter.
          It would be more than nice, if developers could make, the position of list entries could be rearranged in list by user.
          • Dave J 0
            I use both Android and iOS versions. There is a difference between Start and Finish icons. Really like the Android version with the flags instead of via icons:
            iOS 26 - iPhone 15 Pro
            Android 16 - Pixel 6 Pro
            Ducati Multistrada V4 Rally
            iPhone 18 Pro
            CHIGEE AIO-6 LTE
            • Dave J 0 Dave J 0
              @Dave-J-0 that’s probably a setting on your side. I guess you enabled track navigation on the Android 😉
              Dave J 0 1 Reply Last reply
              • Guzzist Guzzist
                @Guzzist it’s actually there already, the search icon which is literally the first option 😆
                Guzzist 1 Reply Last reply
                  Sorry: 🫣 but through Hamm nobody drives voluntarily with his motorcycle !!!
                  The update should also please make the topic of routing (curvy route without driving through cities) better or why is routed with the MRA directly through Hamm to get from Winterberg to Münster via Curvy route from A to B.
                  Unfortunately or why other apps can do that better, or are more successful on route from A to B in curvy ...
                  Sorry: 🫣 aber durch Hamm fährt keiner freiwillig mit seinem Motorrad !!!
                  Das Update sollte auch bitte das Thema Routing (kurvige Route ohne Städte zu durchfahren) besser machen oder warum wird mit der MRA direkt durch Hamm geroutet um von Winterberg nach Münster über Kurvige Route von A zu B zu kommen.
                  Leider oder warum können andere Apps das besser, bzw. sind bei Route von A zu B in kurvig erfolgreicher …
                  Curvy example same A to B task!
                  Kurviger Beispiel gleiche A zu B Aufgabe !
                  An Hamm vorbe !!
                  @Hubert-Thoring we will check this but it’s not really part of the beta 😉
                  This issue would be there in the website and the current release version.
                  • Erik Plaggenborg
                    Erik Plaggenborg
                    Erik Plaggenborg
                    Ik zie mijn eigen POI's niet meer tijdens navigeren sinds de nieuwe update. Voorheen zag ik deze tijdens navigeren altijd op de kaart voorbij komen als ik daar in de buurt was.
                    Nu zie ik in de app als ik een route kies nog wel deze POI's staan maar zodra ik ga navigeren zijn deze persoonlijke POI's niet meer op de kaart te zien.
                    Dit is best lastig omdat ik deze gebruik oa om POI's die niet op de route liggen toch te kunnen zien en daar eventueel naar toe te rijden.
                    Is dit al een bekend issue? Zo niet dan zou het een zeer wenselijke optie zijn om terug te laten komen.
                    Groet Erik.
                    Garmin XT3
                    Samsung S25+
                    MotoCon Erik Plaggenborg 2 Replies Last reply
                    • Erik Plaggenborg Erik Plaggenborg
                      Groet Erik.
                      @Erik-Plaggenborg, Ik zie ze nog wel hoor, Misschien heb je ze p/o uitgezet in de planner?
                      Erik Plaggenborg 1 Reply Last reply
                        Erik Plaggenborg
                        Erik Plaggenborg
                        Erik Plaggenborg
                        @Con-Hennekens Ik heb het gecontroleerd staan aan maar op moment van indrukken knop
                        navigeer zijn ze verdwenen..
                        Garmin XT3
                        Samsung S25+
                          Erik Plaggenborg
                          Erik Plaggenborg
                          Erik Plaggenborg
                          Poi's staan volgens mij dus in de planner aan.
                          Garmin XT3
                          Samsung S25+
                            Erik Plaggenborg
                            Erik Plaggenborg
                            Erik Plaggenborg
                            Na de button " NAVIGEER" te hebben gekozen zijn de POI's niet meer te zien.
                            Garmin XT3
                            Samsung S25+
                              @Corjan-Meijerink Doh! Yes. Every day is a learning day. 😎
                              iPhone 18 Pro
                              CHIGEE AIO-6 LTE
                                Groet Erik.
                                Erik Plaggenborg
                                Erik Plaggenborg
                                Erik Plaggenborg
                                @Corjan-Meijerink Heb jij voor dit issue een verklaring? Het bestand met POI's is een gpx-bestand
                                wat zo als te zien in mijn gedeelde plaatjes aanstaat.
                                Zoals ik al schreef zie ik ze in de planner staan maar nu tijdens navigeren zie ik ze in de versie 5.0.0-418 niet meer.
                                Groet Erik Plaggenborg
                                Garmin XT3
                                Samsung S25+
                                  Kunt u alstublieft in het Engels schrijven? We hadden afgesproken om te schrijven in de taal waarin de post begint.
                                  Please write in English. We had agreed to write in the language that the post begins with.
                                      @Jörgen I agree in general but I don’t think that can be expected in these mega threads.
                                      Feel free to create a dedicated post for specific issues.
                                          @Erik-Plaggenborg said in Update 5.0 - major app overhaul!:
                                          Zoals je ziet in mijn eerdere screenshot heb ik ook al de navigatie gestart, in zijn de POI gewoon zichtbaar. Komen bij jouw die POI niet terug als je minder ver uitzoomt? Sommige POI zijn alleen zichtbaar vanaf een bepaalde inzoom waarde.
                                          @Jörgen said in Update 5.0 - major app overhaul!:
                                          I agree, but this was a new question (in Dutch). Would have been better to start a new topic indeed.
                                          • 4
                                          Edwin_M
                                          Edwin_M
                                          PeterKerkhof
                                          PeterKerkhof
                                          Peter Schiefer
                                          Peter Schiefer
                                          Giuseppe Marino
                                          Giuseppe Marino
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Steve 2v
                                          Steve 2v
                                            Albert van den Elsen
                                          • Verminkte route op TomTom.
                                            Jacob Waterweg
                                            Jacob Waterweg
                                          • Probably a me thing
                                            Solo1138
                                            Solo1138
