  3. [App-Beta] Announcements
  4. Update 5.0 - major app overhaul!
65 Posts 22 Posters 557 Views 11 Watching
  • CD130
    Looks very sleek 👌 Just wanted to update the offline maps and that crashed. Then I had to download them again 1 by 1. Do others have that too?
    Edwin_M 1 Reply Last reply
    • CD130 CD130
      Edwin_M
      Edwin_M
      Edwin_M
      @CD130 no crash, but the update simply doesn't start.
      On Android
      • Peter Schiefer
        Peter Schiefer
        Peter Schiefer
        erste Gehversuche, tut mir leid sehr Buggy.
        Wegpunkte genau setzen auf dem iPad ist unmöglich.
        man drückt unten auf den gelben Dot und irgendwo in der Mitte setzt sich der Wegpunkt.
        Oder man drückt lange mit dem Finger in der Karte und der Punkt ist nicht genau dort.
        Peter
        • Peter Schiefer
          Peter Schiefer
          Peter Schiefer
          wrote on last edited by Peter Schiefer
          Das Textfeld nimmt viel zu viel Platz weg ipad 10“
          Wegpunkte setzen das stimmt was nicht
          Peter
          • Marinus van Deudekom
            Like @Peter-Schiefer said using the IPad in landscape mode and creating a route the placing of the waypoints is of. Using it in portrait mode, witch is not my preferred mode the placing of the waypoints is good. The textbox in that mode is also better. Zooming in max makes the waypoint disapear.
              #21
              I can confirm, the iPad planing e.g. waypoint setting in landscape is not working properly. The waypoint is not set at the button of the icon, it is set with the top (the fingertip) of the icon.
              Portrait mode is ok for WP setting.
              I thing the crosshair was better for positioning a WP on tablet/smartphone.
              Why are the waypoint icons that big? (See pic)
              I used the simulation for testing. After stopping the route and the simulation, the position point (icon) is still moving over the map (as in the simulation).
              Looks like simulation is still on.
              • MotoCon
                Indeed, the placement of waypoints is way off in planning mode. I (we) missed that completely in our alpha testing, because we were unaware that anything concerning the changed GUI would impact the (as we thought unchanged) planner module. This proves the value beta testing 😉
                Guzzist 1 Reply Last reply
                  #23
                  Tablets will be optimised before release for sure! 🙂 @Peter-Schiefer
                  Edit: not so much tablet as indeed some landscape mode improvements but tablet are almost always landscape
                    #24
                    @Corjan-Meijerink :
                    Thanks for the user UI update, I will test it extensively, the first impression is Bund and some functions you have to look for.
                    Attention ⚠️ 1.) Question
                    I have already noticed that the route A to B is calculated directly after a destination search and only the curvy variants can be selected, how do I select the fastest direct route if I don't like the three possible curvy routes (TrackRoute)?
                    Or do you have to see it that way the 1.) Navigate = fastest route etc. s. Picture below
                    Old version :
                    1.) Route Fast connection
                    2.-4.) Routen Track
                      @Corjan-Meijerink :
                      Old version :
                      2.-4.) Routen Track
                      @Hubert-Thoring said in [Update 5.0 - major app overhaul!](/
                      After entering your destination tap Navigate for the fastest option, if you want curvy tap the Scenic button.
                        Display problem!
                        The German word for quickest is not displayed.
                        I would change the translation from "Am schnellsten" into "Schnellste".
                        Then it would be displayed correctly, as well as "Kürzeste" (shortest)
                          CarPlay start, the arrow is not centred correctly.
                          It will move later, after 1-2km to correct position.
                          • richtea999
                            Very nice! Good work, MRA dev team.
                            Minor irritations:
                            1. Android Back button doesn't exit the app.
                            2. Forcing users to step through all the features on first starting is unnecessary. A single popup asking if they want to see the latest changes is sufficient.
                              #29
                              It is not possible to move the menu more up, to see more options.
                              You also do not see a bar on the side, to make you aware that there are more options.
                              Only if you move your finger at this area, you see more options and a bar.
                              • Steve 2v
                                Steve 2v
                                Steve 2v
                                Loving the new UI, same minor issues as others have posted about. In relation to the options piece in the post above, it would be great if we could change the travel mode here as well as part of the navigation options. I frequently swap between bike and car and forget to swap it over in the settings.
                                • Dave J 0
                                  Great work with the new UI - top job. A couple of issues I experienced today on a quick test route I made with the new planner on the phone (worked well).
                                  Same Point Navigation. The route was deliberately planned with only Via points to see what would happen with recalculation etc. The navigation worked well apart from how the app managed a return to the same point (Waypoint 1 and Waypoint 3) after navigating elsewhere. Regardless of what I did to route to Waypoint 3, the app said Waypoint 1. Videos show me selecting Waypoint from the Waypoints’ list and also manually skipping the Waypoint to 3 with the top right Waypoint Icon. Each time the app went back to showing Waypoint 1!
                                  Car Play Manual Zoom Button. Tested on 2 different devices with the first screenshot on my car’s system through wired connection showing overlapping icons for zoom in and zoom out. Moreover, selecting these buttons made no change on the CarPlay screen.
                                  When trying the same on me Chigee on the bike through wireless connection, the same thing happened but I noticed that the zoom was changing on the iPhone but not on the CarPlay Screen until exited the manual zoom function and then reselected the manual zoom again. This may have also happened on the wired connection:
                                  Exit and re selection of manual zoom:
                                  Ducati Multistrada V4 Rally
                                  iPhone 18 Pro
                                  CHIGEE AIO-6 LTE
                                  Google Pixel 6 Pro
                                  • Edwin_M
                                    Edwin_M
                                    Edwin_M
                                    De app is op Android niet te stoppen vanuit de App zelf. Een quit app optie zou wel prettig zijn. Of na een paar keer terug drukken de App af kunnen sluiten
                                      #33
                                      Sorry: 🫣 but through Hamm nobody drives voluntarily with his motorcycle !!!
                                      The update should also please make the topic of routing (curvy route without driving through cities) better or why is routed with the MRA directly through Hamm to get from Winterberg to Münster via Curvy route from A to B.
                                      Unfortunately or why other apps can do that better, or are more successful on route from A to B in curvy ...
                                      Sorry: 🫣 aber durch Hamm fährt keiner freiwillig mit seinem Motorrad !!!
                                      Das Update sollte auch bitte das Thema Routing (kurvige Route ohne Städte zu durchfahren) besser machen oder warum wird mit der MRA direkt durch Hamm geroutet um von Winterberg nach Münster über Kurvige Route von A zu B zu kommen.
                                      Leider oder warum können andere Apps das besser, bzw. sind bei Route von A zu B in kurvig erfolgreicher …
                                      Curvy example same A to B task!
                                      Kurviger Beispiel gleiche A zu B Aufgabe !
                                      An Hamm vorbe !!
                                        On my tablet (Samsung Galaxy Tab S8 5G, Android 15, One UI 7.0) it's working perfect to place waypoints by MRA-Routeplanner - in portrait orientation. But in landscape orientation, I recognise same issues.
                                        • Bart De Medts
                                          Really put the MyRoute-app beta to the test today: 315 km ridden and every single instruction was spot on.
                                          This one’s going to be a winner! 💛
                                          • 4
                                          Edwin_M
                                          Edwin_M
                                          Peter Schiefer
                                          Peter Schiefer
                                          PeterKerkhof
                                          PeterKerkhof
                                          Giuseppe Marino
                                          Giuseppe Marino
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Steve 2v
                                          Steve 2v
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
