Route Optimisation
Under Routing Options, when using Here, I get three options; Avoid, Disable seasonal closures and Offroad. I would to also like to have Route Optimisation. How do I get that option?
Change the profile in from motor to auto
Under Routing Options, when using Here, I get three options; Avoid, Disable seasonal closures and Offroad. I would to also like to have Route Optimisation. How do I get that option? @Ben-Harrison-Graham said in Route Optimisation: Under Routing Options, when using Here, I get three options; Avoid, Disable seasonal closures and Offroad. I would to also like to have Route Optimisation. How do I get that option? As said, use the transport profile for Cars (Auto) instead of Motor. This avoids some of the issues. Looking at your options available, are you a Gold/Silver member? Or a basic member? As a basic member you cannot use the HERE map. But it confuses me looking at your options. Mentioning HERE you should be a Silver/Gold member...??? In HERE, before you start plotting a route, set Route optimization to shortest (or short) (in Dutch: Kortste route). With this set to shortest, you will also solve some issues.
Thanks for your help. I have now resolved this. I am a gold member. The options I get under Route Optimisation are Shortest and Fastest. I understand that you recommend I select Shortest.
It depends on your what you want. Shortest means every little s***street available or streets through large cities will be in your route. But you can try both possibilities and decide what comes closest to your needs.
OK thanks for the help
It depends on your what you want. Shortest means every little s***street available or streets through large cities will be in your route. But you can try both possibilities and decide what comes closest to your needs. @Lex.Kloet.RX said in Route Optimisation: It depends on your what you want. Shortest means every little s***street available Lex, thats really harsh to put it like this! It's not only streets but also ferry's and so on. @Ben-Harrison-Graham
 A lot of users who keeps optimization on fastest experience problems like crossing a river with ferry.Why?. And this is wat @Lex.Kloet.RX dors not explain to you:
 Having optimization on fastest means that MRA calculate the fastest route which might not be the route you want.As example: getting from A to B might take 60 minutes with a ferry and MRA set on shortest while having MRA set to fastest takes 50 minutes using a bridge further down the river. Guess which route MRA will choose when optimization set to fastest although you wanna cross the river using the ferry..... It is recommended to set optimization to shortest to utilize MRA fully.
OK thanks again guys.
I have found fastest to be more suitable for a day's ride I've just planned. Shortest and fastest did what they say.
 Thanks
 Thanks@Ben-Harrison-Graham jep, me too. You can always correct the route with a few shapingpoints. Shortest and a big city ahead, is not funny.
 Having optimization on fastest means that MRA calculate the fastest route which might not be the route you want.As example: getting from A to B might take 60 minutes with a ferry and MRA set on shortest while having MRA set to fastest takes 50 minutes using a bridge further down the river. Guess which route MRA will choose when optimization set to fastest although you wanna cross the river using the ferry..... It is recommended to set optimization to shortest to utilize MRA fully. @Nomko-Nomden said in Route Optimisation: It is recommended to set optimization to shortest to utilize MRA fully. This may be recommended by @Nomko-Nomden, but certainly not by everyone.
 @Nomko-Nomden please stop pushing YOUR preferences as generally advised.
 Having optimization on fastest means that MRA calculate the fastest route which might not be the route you want.As example: getting from A to B might take 60 minutes with a ferry and MRA set on shortest while having MRA set to fastest takes 50 minutes using a bridge further down the river. Guess which route MRA will choose when optimization set to fastest although you wanna cross the river using the ferry..... It is recommended to set optimization to shortest to utilize MRA fully. @Nomko-Nomden stay with your preferences and I will stay with mine. There is no need to get personal...
@Nomko-Nomden stay with your preferences and I will stay with mine. There is no need to get personal... @Lex.Kloet.RX said in Route Optimisation: @Nomko-Nomden stay with your preferences and I will stay with mine. There is no need to get personal... @Lex.Kloet.RX
 Als jij het persoonlijk neemt is het jouw eigen probleem. Maar je staat vanaf nu op negeren bij mij dus reageren op mijn berichten heeft geen zin meer.
 @Nomko-Nomden please stop pushing YOUR preferences as generally advised.@Con-Hennekens said in Route Optimisation: @Nomko-Nomden said in Route Optimisation: It is recommended to set optimization to shortest to utilize MRA fully. This may be recommended by @Nomko-Nomden, but certainly not by everyone.
 Were did i said it was generally advised????
 Ook jij gaat bij op blokkeren...
 Ook jij gaat bij op blokkeren...@Nomko-Nomden said in Route Optimisation: Ook jij gaat bij op blokkeren... Je had eerder al beloofd dat je mij had geblokkeerd
 Zoals ik hierboven al heb aangehaald:@Nomko-Nomden said in Route Optimisation: It is recommended to set optimization to shortest to utilize MRA fully. DAT is dus een advies dat doet voorkomen alsof dat algemeen gedragen wordt. En dat is niet zo.
 It is advised = algemeen
 I advise = wat JIJ adviseertIk ga jou NIET op blokkeren zetten, want het is veel te belangrijk dat sommige van jouw uitspraken gecorrigeerd worden. Dat kun je irritant vinden, maar dan kun je het beter laten. Niemand hier zit te wachten op desinformatie.
I am locking this topic as the original question has been answered and the replies are becoming personal. The route optimisation tool is like any tool in the toolkit, how you choose to use it is a personal thing. Some people prefer to use a hammer instead of a screwdriver, that is their choice!
 undefined Nick Carthew locked this topic undefined Nick Carthew locked this topic
