  4. Copying a Waypoint
Copying a Waypoint
9 Posts 5 Posters 3.2k Views 3 Watching
    Corrado Miniati 0
    Sometimes during one or more travel days, you start from your base and return to the same base (e.g., a hotel, B&B, etc.) because you use a center of gravity for logistical convenience to explore a specific area.
    It would be nice to be able to copy the base waypoint so you don't have to create it each time. What do you think?
    Nick Carthewundefined Guzzistundefined 2 Replies Last reply
    • Corrado Miniati 0undefined Corrado Miniati 0
      Nick Carthewundefined Online
      @Corrado-Miniati-0 Make it a favourite by clicking the star. Then with each new route click on the favourite and then add it as a route point.
        Corrado Miniati 0
        Hi Nick, thanks a lot for the feedback.
        Your suggestion helps, but I keep in mind that I add frequently used waypoints (home, work, parents, etc.) to my favorites.
        If you need to copy a waypoint as the start and end point for even just one day, adding it to your favorites is impractical in my opinion, because you have to recall it in the dedicated menu and then you'll delete it 99% of the time because I'd never stay at that hotel again.
        Being able to copy a waypoint directly from the list would be much faster.
          Guzzistundefined Offline
          @Corrado-Miniati-0 / @Nick-Carthew ...making a waypoint to a favorite - and then reuse it in same or other routes, may be a possibility. But it's not really a solution und will loose the additional note, you may have added to the original WP. And you may not remember the name of the favorite, if you try to find it in the long list...!
          My shorter (not better) solution is: klick on a WP on map, copy the lat/lon coordinates in the description, enter it in search field in map, add search result as new WP.
            Corrado Miniati 0
            Hi Guzzist, thanks for the feedback.
            Copying the GPS coordinates is what I do too, but you also lose the waypoint description.
            Being able to copy/paste a previously created waypoint with all the naming conventions would be the most logical and quickest solution, at least that's my opinion.
            • RainerTundefined Offline
              RainerT
              What about this:
              Create a folder for your actual journey
              Create a route (named root+journey)in this folder that contains two waypoints, start and finish (somewhere near to start, perhaps gas-station)
              When planning your next route, duplicate the root-route, rename it and plan your next day with it.
              Repeat that for the next days.
              If you add POIs to the root-route, they are available in alls routes.
              RT
                Corrado Miniati 0
                Hi Rainer, thanks for the feedback.
                If I've interpreted your suggestion correctly, creating a folder with two waypoints (start and finish) would be useful if you always start and finish from the same places, but if your starting and finishing points are always different on a road trip, it would probably take longer than copying the GPS coordinates.
                I still think copying a waypoint is the quickest and most practical solution.
                • RainerTundefined RainerT
                  What about this:
                  RT
                  @Rainer-Treichel
                  @Corrado-Miniati-0
                  RT, yes that's exactly how I do it:
                  1.) Basic route with hotel, route has two WP, the hotel and nearest gas station near hotel
                  2.) More routes / daily routes are in the same folder
                  Advantage:
                  You can always cancel on the way and quickly choose the basic route to come back quickly, e.g. in case of rain
                  You can create a new route at any time, from the base route as a copy and then plan further.
                  Big advantage, you insert all routes into the basic route, then you select the appropriate route according to the overview according to the mood and weather or plan a new one with the copy of the basic route.
                  Is flexible and has proven itself just like that.
                  ———— DE ———
                  RT, ja genau so mache ich es auch:
                  1.) Basis Route mit Hotel, Route hat zwei WP, das Hotel und nächste Tankstelle nahe Hotel
                  2.) Weitere Routen / Tages Routen liegen in dem gleichen Ordner
                  Vorteil:
                  Mann kann unterwegs immer abbrechen und wählt schnell die Basis Route um schnell, z.B. bei Regen zurück zu kommen
                  Man kann jeder Zeit eine neue Route erstellen, aus der Basis Route als Copy und dann weiter planen.
                  Großer Vorteil, man blendet alle Routen in die Basis Route mit ein dann wählt man nach Lust und Wetter die passende Route nach der Übersicht aus oder plant eine neue mit der Copy der Basis Route.
                  Ist flexibel und hat sich genau so bewährt.
                    Corrado Miniati 0
                    Hi Hubert, thanks for the feedback.
                    It's probably my fault, but I'm having trouble with this method. As other users have already said, it would be great to be able to copy the waypoint.
                    RainerTundefined
                    RainerT
                    Corrado Miniati 0
                      Massimo Cardoneundefined
                      Massimo Cardone
                      6.3k
                    • Veekeersinfo en omleiden
                      marko 11 0undefined
                      marko 11 0
                      38.7k
                    • CPMC B6/B7
                      Leike Lodiersundefined
                    • Library sync error
