  4. Assign a via point/waypoint number
40 Posts 16 Posters 19.0k Views 6 Watching
  • Corrado Miniati
    wrote on last edited by Corrado Miniati
    #30
    I discovered that MRA doesn't display POIs from csv file if they're imported as lat-lon instead of lon-lat.
    My Google Maps displays them as lat-lon, and in Excel I have to reverse the parameters. Why?
    However, there is an alternative method, but it would be appreciated if MRA allowed renaming the waypoint positions.
    BMcG BertM 2 Replies Last reply
    • Corrado Miniati Corrado Miniati
      wrote on last edited by BMcG
      #31
      @Corrado-Miniati-0 the easy way to understand the format is to create a map / route in MRA with some POI's
      then save the route as a CSV
      you can then inspect the csv & replicate the format
      when you create your own custom CSV to import your points, import it via the Library tab
      you will need to zoom into >=10km to see the imported POI's
      yes the lon-lat v lat-lon is an oddity of MRA, I dont know why, maybe it is a dutch thing 😊
      the points will be displayed just not in the part of the world you are expecting to find them πŸ˜‚
      • Corrado Miniati
        Thanks, maybe Corjan could check if the lat-lon vs lon-lat theme is a bug
          It definitely is not a bug πŸ™‚
          Do I find it logical for a user perspective? No.
          Will I change it? No. Mainly because everyone using this is now used to that.
          I do know the origin of these things.
          Lat / lon is preferred by humans but I don’t know why. Lon / lat is however mathematically the correct order πŸ™‚ Longitude representing the horizontal (x) axis and Latitude the vertical (y) axis.
          Guzzist 1 Reply Last reply
            #34
            @Corjan-Meijerink said in Assign a via point/waypoint number:
            ...Lon / Lat is however mathematically the correct order πŸ™‚ Longitude representing the horizontal (x) axis and Latitude the vertical (y) axis.
            uhh, I believe it's not 100% correct explained.
            • The geographical length, also called longitude (international abbreviation long or LON), describes the position east or west of a defined (arbitrarily defined) north-south line, the zero meridian. It's following the vertical earth axis.
            • The geographical latitude, also called geodetic lat or (international abbreviation Lat. or LAT), describes the position north or south of a defined line round the earth, parallel to the Earth's horizontal equator.
            But the rest, Corjan - you may know better than me πŸ˜‰
            • Edwin_M
              Edwin_M
              Edwin_M
              Also if you search for an address and what to add that to the route is will always be added at the end. So then you need to drag to the correct position.
              I agree that a shorter way to edit the position of the point in the route would be a good functionality
              • Corrado Miniati
                In my case, but I think for many if not all users, it would be a very significant update.
                  @Corrado-Miniati-0 said in Assign a via point/waypoint number:
                  If you look at an exported KML file the lat/lon is reversed when exported, so the display in Google is different as the exported file.
                  • Corrado Miniati
                    @Bert, thanks for the explanation.
                    Unfortunately, the current inconvenience remains.
                    BertM 1 Reply Last reply
                      yes, I agree.
                      • Michele Skipper
                        Michele Skipper
                        Michele Skipper
                        Vi posso assicurare, soprattutto se fai percorsi molto lunghi, che poter rinumerare il wp sarebbe una cosa che renderebbe la programmazione piΓΉ semplice tantissime volte, Γ¨ evidente che se ti domandi il perchΓ© non ti Γ¨ mai capitato di doverlo fare, ma ame invece capita sempre ad ogni costruzione di un percorso, quindi mi aggiungo alla lista di coloro che vorrebbero questa cosa nel nuovo planner
                        JP d
                        JP d
                        Edwin_M
                        Edwin_M
                        Kirsten De Weerd
                        Kirsten De Weerd
                        Michele Skipper
                        Michele Skipper
                          Nick Elsom 0
                          Nick Elsom 0
                        • 0 van 15 klaar
                          Mark Vroomen
                          Mark Vroomen
                          Bart van de Griendt
                          Bart van de Griendt
                        • Routelijn transparantie
                          Mark Vroomen
                          Mark Vroomen
