Was sind Saisonale Schliessungen? - What are seasonal closures?
I know that, it ist the Text from the dokumentation.
My route Shows a road closed for roadworks.
Is that a wrong classification by Here?
No snow in Bremen
RT -
Hi, I tried your problem with a closed road in Mönchengladbach and see the same issue.
If “sessional closure” is active you will be guided around the closed street, if deactivated you drive through the closed street.
This looks like a bug in the Here map that needs to be noticed to HERE from MRA.Active
Deactivated
@Corjan-Meijerink Can you have a look into this issue?
There is sometimes a thin line between closures due to road works and what we consider seasonal closures. I think it largely depends on a) how a roadwork is communicated by the responsible government and b) how that information is interpreted by HERE. I am under the impression that some longer closures are considered seasonal, while most short closures are considered to be traffic info. I am not sure there is a very strict protocol for it.
@Con-Hennekens I find the way the "Disable Seasonal Closures" works now quite useful
If I am planning a trip several months ahead I do not need my route calculation to take account of every current road closure
Many of these closures will have been removed by the time I come to ride the route
The "Disable Seasonal Closures" allows me to ignore these closures & plan the route I will most likely ride in several weeksAn example - I am heading to france & spain in a few weeks & on the return journey, today the A26 near St Omer has road closures
Using the "Disable Seanoal Closures" allows me to plan the route more accuratley
If the "Disable Seasonal Closures" is modified to ignore road works then to me it would make sense to also add a switch to enable "Ignore Road Work Closures"
@Brian-McG, indeed!
@Brian-McG said in Was sind Saisonale Schliessungen? - What are seasonal closures?:
Since I have already experienced several blockages in the Here map (but the blockage had already been lifted), but the map material had not yet been updated, I agree with this 100%.
