  3. [App] Announcements
  4. New update! (4.4.1)
New update! (4.4.1)
15 Posts 6 Posters 369 Views 2 Watching
  • Thomas Neumeyerundefined Thomas Neumeyer
    Hello Corjan, nice to improve further. Did you also had a chance to have a look to the laggy behavior of some Android phones? I had to switch back to 4.3.9 as 4.4.0 has been hardly usable.
    Thomas
    Adrian Avramundefined Offline
    wrote last edited by Adrian Avram
    @Thomas-Neumeyer also curious about the same thing ... To be honest it doesn't even matter. I started creating routes using the OSM map in the web planner and exporting to Osmand+ !
    Just did a trip from Romania to Montenegro and back and works perfectly !
    Adrian
    Samsung S24 Ultra and iPhone 13 with Android Auto / CarPlay
    • CD130undefined CD130 referenced this topic
      @Adrian-Avram @Thomas-Neumeyer We updated some engines that hopefully resolve the issue - curious to hear your feedback.
      • Thomas Neumeyerundefined Offline
        Thomas Neumeyer
        Will test it once available. Thomas
          @Corjan-Meijerink no more lagging after update, all menus are snappy when opening. I will drive from work to home in 1 hour and test also the navigation.
          Thanks !
          Adrian
            Thanks !
            @Adrian-Avram great! Happy to read that 🙂
            Sometimes issues are caused by external factors and then also solved by updating them again!
            Sorry for the inconvenience you experienced!
              @Corjan-Meijerink said in New update! (4.4.1):
              Don't worry about it !
              I just drove a 80km route with 2 stops, everything is working just fine !
              Resuming navigation every time without any issue, and most importantly no more lagging !!!
              Hope it also works for all the other users with this issue.
              Great job !
              Adrian
                Thomas Neumeyer
                Hello, no joy here. In portrait mode it is laggy when the next street name is moving because of its length in the "instruction" window. When in landscape and the street name is stationary it is not laggy. Regards Thomas
                • Peter Zehentreiterundefined Offline
                  No more access to the forum ( Android App)
                  With the new update I can no longer access the forum properly.
                  Previously I could see all unread entries at the bottom left, but this option is now only visible in the background but unfortunately cannot be selected.
                  BMW R 1250 GS
                  BMW Connected Ride Cradle
                  SPC Universal mount
                  Motorola Edge 40
                  Sena SLR 3
                  Sena 50 R
                    That would seem to indicate that you don't have a data connection.
                    Peter Zehentreiterundefined 2 Replies Last reply
                      wrote last edited by Peter Zehentreiter
                      @RetiredWingMan The data connection is 100% o.k.
                      Both WiFi and data connection via the network operator!
                      I can access the forum, I can see the individual sections and can also access them.
                      But please take a close look at the screenshot.
                      At the bottom left you can see a number in light blue which shows all unread messages in the forum but not selectable.
                      The profile picture at the bottom right is also not selectable.
                      BMW R 1250 GS
                      SPC Universal mount
                      Motorola Edge 40
                      Sena SLR 3
                      Sena 50 R
                        @RetiredWingMan
                        I have found the error.
                        If you have activated the navigation via the 3 buttons in the gesture control in Android, the error occurs.
                        If you switch to gesture control, you can access the unread messages again.
                        Would be great if that little issue could be solved
                        BMW R 1250 GS
                        SPC Universal mount
                        Motorola Edge 40
                        Sena SLR 3
                        Sena 50 R
                          @Peter-Zehentreiter, not really a solution, but a suggestion... 😉
                          Go to the forum main page, click your profile avatar, choose settings.
                          On that page you can set the default landing page when you enter the forum.
                          I have set this to "unread", since basically that is all I look at 😉
                          From now on the forum will always open directly to that page.
                            Hi Con,
                            thanks for your hint.
                            It does help with the problem I mentioned (unread messages), but if I then want to go back to previous messages for example, then I have the problem again that the 3-button gesture overlays the forum fields.
                            BMW R 1250 GS
                            SPC Universal mount
                            Motorola Edge 40
                            Sena SLR 3
                            Sena 50 R
                            RetiredWingManundefined
                            Thomas Neumeyer
                            • New update! (4.4.1)
                            • MyRoute app is consuming loads of phone battery in background
                              Bart De Medtsundefined
                            • ios 15.8.4 no longer compatible with My Route 4.4.1 ?
                            • Finishvlag en andere icoontjes
                              Nomko Nomdenundefined
                              Nomko Nomden
                            • Placement of waypoints
                              1.2k
                            • Can't switch to miles in GB
                            • MRA Gpx Routes to a BMW Connected Ride Unit.
                            • Scenic overlay
