  4. Petrol stations
Petrol stations
27 Posts 9 Posters 6.4k Views 5 Watching
  • Spiliundefined Offline
    Spili
    How to find a Petrol Station ALONG my route?
    All I can find is closest one - but not on my way.
    Could be perfect if there was a "indicator" showing distance to next petrol station ALONG a route.
      Spili
      Perfect solution has Sygic. Shows 2 petrol stations along a route.
      You know you should tank a bike now or on next station.
        Spili
        Even 3 next stations 🙂
        Perfect solution.
        • richard 3vundefined Offline
          richard 3v
          Then use Sygic and not MRA.
          Problem solved!
          Spiliundefined 1 Reply Last reply
          -2
          • Spiliundefined Spili
            Perfect solution.
            @Spili Open your route on the Website (Routlab)
            Open route details, open POIs, select Gasstation.
            Zoom in to find Gasstations along your route.
            You can create a Poi for the Gasstation or a Waypoint with a symbol of a gasstation.
            BMW R 1250 GS
            BMW Connected Ride Cradle
            Wunderlich USB Ladebox mit Quadlock
            Pixel 9 "online"
            SPC Universal mount
            Motorola Edge 40 "offline"
            Sena SLR 3
            Sena 50 R
            Spiliundefined Bouke Entundefined 2 Replies Last reply
              @Spili, the gas station tile in the MRA app actually DOES show gas stations along or very CLOSE to your route.
              If you don't see it, it might be that there is none along or close to your route for many kilometers, OR that you do not have that option enabled in the app settings. It's in the functional settings menu.
              • richard 3vundefined richard 3v
                Problem solved!
                Spili
                @richard-3v Thanks for great advice. I want to MRA be better. Do not waste your time for such a post.
                richard 3vundefined 1 Reply Last reply
                  Spili
                  @Peter-Zehentreiter This is not solution DURING driving.
                    richard 3v
                    @Spili said in Petrol stations:
                    OK then, use MRA using the Next app, not using AA or CP. Then you will see the icon as @Con-Hennekens refers to and your roblem is solved.
                    Or have I wasted my time again??
                    • Bouke Entundefined Offline
                      until now it is not supported in AA/CP. only in MRA Next app direct on phone or tablet you will see a petrol station notivication. this is ask before but then the answer was limitation on AA/CP. but good question if it works on sygic and not on MRA Next on AA/CP.
                      i hope the developmentteam can put it on the request list.
                        @Spili, I am sorry, in my earlier comment I left out that you are using an AA/CP device, obviously noticable in your screenshots... I believe the tile I mentioned is indeed not visible on AA/CP devices, because of restrictions bij Google and Apple. There is a limit to the available information on such devices, to keep them from being a distraction. MRA choose other info and buttons to be visible. Maybe something can be changed about that in the future.
                          @Peter-Zehentreiter said in Petrol stations:
                          in case of a A2B or on the fly in the app offline this is difficult to do.
                            If you have a list of Fuel stations in your POI library, select the profile icon and the fuel POIs will be visible in all of your routes when planning and when you are navigating.
                            Spiliundefined Guzzistundefined 2 Replies Last reply
                              Spili
                              @richard-3v Unfortunately again 🙂
                              There is reason I posted it in AA/CP section 🙂 Not in MRA/Next section 🙂
                                Spili
                                @Bouke-Ent
                                There are restriction on AA/CP side?
                                I do not think so because my screenshots are from Sygic running on Android Auto.
                                Maybe MRA has any limitations we do not know?
                                Bouke Entundefined Con Hennekensundefined 2 Replies Last reply
                                  richard 3v
                                  wrote on last edited by richard 3v
                                  😀 Fair comment ! 😀 👍
                                    Spili
                                    @Nick-Carthew Yes. I know I can plan my fueling.
                                    But it is not a solution I need.
                                    All I need is a icon or two with incoming petrol stations.
                                    Then I know I must tank now or I can go and tank on next station.
                                      @Spili My suggestion does not involve planning, it just shows fuel stations while you are navigating. You decide you need fuel and you ride to the nearest.
                                        @Bouke-Ent
                                        @Bouke-Ent
                                        i also have no idea but that was said last time there was this subject. i had same doubt and for me i was one of more reasons to dump AA/CP for now and use phone or tablet.
                                          @Bouke-Ent
                                          Yes there are restrictions, I don't think so, I know so.
                                          What reason do you think MRA would have to cripple the AA/CP interface like that?
                                          Your screenshot from Sygic clearly shows it has much less clutter by buttons and info tiles on it's screen. They clearly choose different things to show than MRA did, but they cope with the same limitations.
                                          Adrian Avramundefined
                                          richard 3vundefined
                                          richard 3v
                                          Spiliundefined
                                          Spili
                                          Bouke Entundefined
                                          • The magic tree Points an skip Waypoints during navigation
                                          • Broken road (in map only)
                                          • Problem with Apple CarPlay iOS 26.1
                                          • Audio cuttet via Bluetooth
                                            Haugundefined
                                            Haug
                                            1.4k
                                          • Zoom + / zoom - from external keyboard not working anymore with release 5.0.1 ?
                                            Andre Trudeauundefined
                                            Andre Trudeau
                                          • Routing Settings only partially visible.
                                          • Opzoek naar mooie offroadroutes in Umbrie in Italie.
                                            CD130undefined
                                          • Unable to confirm or dismiss "Resume Navigation?" with remote
