  4. Petrol stations
Petrol stations
27 Posts 9 Posters 17.2k Views 5 Watching
  • Spili
    Spili
    Spili
    How to find a Petrol Station ALONG my route?
    All I can find is closest one - but not on my way.
    Could be perfect if there was a "indicator" showing distance to next petrol station ALONG a route.
    • Spili
      Spili
      Spili
      Perfect solution has Sygic. Shows 2 petrol stations along a route.
      You know you should tank a bike now or on next station.
      • Spili
        Spili
        Spili
        Even 3 next stations 🙂
        Perfect solution.
        • richard 3v
          richard 3v
          richard 3v
          Then use Sygic and not MRA.
          Problem solved!
          Spili 1 Reply Last reply
          -2
          • Spili Spili
            Perfect solution.
            @Spili Open your route on the Website (Routlab)
            Open route details, open POIs, select Gasstation.
            Zoom in to find Gasstations along your route.
            You can create a Poi for the Gasstation or a Waypoint with a symbol of a gasstation.
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Motorola Edge 40 "offline"
            Sena SLR 3
            Sena 50 R
            Spili Bouke Ent 2 Replies Last reply
            • Spili Spili
              @Spili, the gas station tile in the MRA app actually DOES show gas stations along or very CLOSE to your route.
              If you don't see it, it might be that there is none along or close to your route for many kilometers, OR that you do not have that option enabled in the app settings. It's in the functional settings menu.
              • richard 3v richard 3v
                Problem solved!
                Spili
                Spili
                Spili
                @richard-3v Thanks for great advice. I want to MRA be better. Do not waste your time for such a post.
                richard 3v 1 Reply Last reply
                  Spili
                  Spili
                  Spili
                  @Peter-Zehentreiter This is not solution DURING driving.
                  • Spili Spili
                    richard 3v
                    richard 3v
                    richard 3v
                    @Spili said in Petrol stations:
                    OK then, use MRA using the Next app, not using AA or CP. Then you will see the icon as @Con-Hennekens refers to and your roblem is solved.
                    Or have I wasted my time again??
                    • Bouke Ent
                      until now it is not supported in AA/CP. only in MRA Next app direct on phone or tablet you will see a petrol station notivication. this is ask before but then the answer was limitation on AA/CP. but good question if it works on sygic and not on MRA Next on AA/CP.
                      i hope the developmentteam can put it on the request list.
                      • MotoCon
                        @Spili, I am sorry, in my earlier comment I left out that you are using an AA/CP device, obviously noticable in your screenshots... I believe the tile I mentioned is indeed not visible on AA/CP devices, because of restrictions bij Google and Apple. There is a limit to the available information on such devices, to keep them from being a distraction. MRA choose other info and buttons to be visible. Maybe something can be changed about that in the future.
                          @Peter-Zehentreiter said in Petrol stations:
                          in case of a A2B or on the fly in the app offline this is difficult to do.
                          • Nick Carthew
                            If you have a list of Fuel stations in your POI library, select the profile icon and the fuel POIs will be visible in all of your routes when planning and when you are navigating.
                            Spili Guzzist 2 Replies Last reply
                              Spili
                              Spili
                              Spili
                              @richard-3v Unfortunately again 🙂
                              There is reason I posted it in AA/CP section 🙂 Not in MRA/Next section 🙂
                              • Bouke Ent Bouke Ent
                                Spili
                                Spili
                                Spili
                                @Bouke-Ent
                                There are restriction on AA/CP side?
                                I do not think so because my screenshots are from Sygic running on Android Auto.
                                Maybe MRA has any limitations we do not know?
                                Bouke Ent MotoCon 2 Replies Last reply
                                • Spili Spili
                                  richard 3v
                                  richard 3v
                                  richard 3v
                                  wrote on last edited by richard 3v
                                  😀 Fair comment ! 😀 👍
                                    Spili
                                    Spili
                                    Spili
                                    @Nick-Carthew Yes. I know I can plan my fueling.
                                    But it is not a solution I need.
                                    All I need is a icon or two with incoming petrol stations.
                                    Then I know I must tank now or I can go and tank on next station.
                                    • Spili Spili
                                      @Spili My suggestion does not involve planning, it just shows fuel stations while you are navigating. You decide you need fuel and you ride to the nearest.
                                      • Spili Spili
                                        @Bouke-Ent
                                        @Bouke-Ent
                                        i also have no idea but that was said last time there was this subject. i had same doubt and for me i was one of more reasons to dump AA/CP for now and use phone or tablet.
                                        • Spili Spili
                                          @Bouke-Ent
                                          Yes there are restrictions, I don't think so, I know so.
                                          What reason do you think MRA would have to cripple the AA/CP interface like that?
                                          Your screenshot from Sygic clearly shows it has much less clutter by buttons and info tiles on it's screen. They clearly choose different things to show than MRA did, but they cope with the same limitations.
                                          Bouke Ent 1 Reply Last reply
                                          Spili
                                          Spili
                                          richard 3v
                                          richard 3v
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                          • Map Layers
                                            Don Stauffer
                                            Don Stauffer
                                            Andy Smith 5
                                            Andy Smith 5
