How do I find routes from RouteExperts
You need to zoom in much more.
The route expert function is a lot better but still laks to get a tour compleet from a expert. Je still can not search on a route or a specific expert.
I tried to get this route complete from number 1 till 9 and that took a lot of time and show RX routes don't.
1 Schwarzwaldroute from Tessenderlo to Lauterbad over Verviers.
Why not group tours so you get a complete tour.
It's now way to complicated -
It's now way to complicated@Cleo Scroll down in the RouteXpert library and you can search for Collections of routes.
This doesn't work. If for example Guy Heyns - Adv. RouteXpert has made routes and want to browse through his collection, via the map it is not convenient on his account i doesn't find the collection. I want specific one collection and not a bunch of them. If want, for example, find yhe Routes Grand Alpes you have to try to find this on the map hoping the the maker use Menton or Thonon-les-Bains as starting point. You can't search on a route topic, only on a city or place. MRA mis a hope new customers with the difficult acces to there route library. In Routeyou it's peace of cake.
@Cleo
Select Guy in the RouteXpert list, and zoom out and then in
Hans you have still to hoover to find begin and end. Why is it so difficult to make from parts of a route a collection. So you can see in one view all the route of the collections. From this route i have to hoover every startpoint to find the total amount of parts of a coolection. https://www.myrouteapp.com/en/motor-en-auto-routes/at/Tirol/4015739/3-From-Hochgurgl-in-Austria-to-Trafoi-in-South-Tirol-Italy
Then you find out the startpoint and the endpoint of a collection.
If i build a trip strecht over multiple days i make for every day a route but the complete trip is a collection of routes. I make then a route for the complete trip.
Thats the way it should work in the library -
It is not difficult, if you use the right entrance.
Or use find routes nearby and select the options
Or do you want to see all the routes in the RX library?
You still have to hoover to see the trackline.
I don't think you understand what i mean. I'm not a rookie with MRA but there are still things what can be better and i address this.
Everything you show i now already. You don't look from the eye of (noob)user. Start from the viewpoint your are a new user and you want to drive Route des Grand alpes or route Napoleon, the search function don't support to find this routes.Try it again.
There a trips in the library these are spread over multiple days, for example a 9 day trip. If you want to find all routes of these 9 days you have to hoover a lot in the map even if you select a Xpert.
A 9 day trip is a collection of 9 days of routes. Why there is no option to find the collection of this 9 day and have to hoover to find every single day.
If all these day trips start with a number you can link them but there are route with out numbers and then you have to look very wel on the map voor the start an d stop of every single day. If the collection of 9 was accessible via the account of the xpert then you see with a blink of an eye all days trips in 1 collection.MRA don't use collections voor multiple day trips
I understand what you mean, but that's just not how it's designed or built.
When I search for routes in the library, I first go to the region I want to ride and then check each route to see if I can use it. If I want to use it, I open it in a new tab so my library selection remains.Once I've found enough routes I want to use, I'll (possibly) modify them to my preferences, such as start and end points, etc.
PS, MRA does use collections for multi-day trips; take a look here: https://www.myrouteapp.com/info/collection
And here it is
