  4. How do I find routes from RouteExperts
15 Posts 6 Posters 3.7k Views 3 Watching
  • Franz oundefined Offline
    Franz o
    Hi
    I saw in Facebook routes from RouteExpert Jordi honrubia. I try to find this routes in MRA, but I am not able to filter this
    but I cant tick RX Routen anzeigen
    many thanks for your help
    rgds franz
    • Jörgenundefined Offline
      You need to zoom in much more.
        • Cleoundefined Offline
          Cleo
          The route expert function is a lot better but still laks to get a tour compleet from a expert. Je still can not search on a route or a specific expert.
          I tried to get this route complete from number 1 till 9 and that took a lot of time and show RX routes don't.
          1 Schwarzwaldroute from Tessenderlo to Lauterbad over Verviers.
          Why not group tours so you get a complete tour.
          It's now way to complicated
          • Cleoundefined Cleo
            @Cleo Scroll down in the RouteXpert library and you can search for Collections of routes.
              Cleo
              This doesn't work. If for example Guy Heyns - Adv. RouteXpert has made routes and want to browse through his collection, via the map it is not convenient on his account i doesn't find the collection. I want specific one collection and not a bunch of them. If want, for example, find yhe Routes Grand Alpes you have to try to find this on the map hoping the the maker use Menton or Thonon-les-Bains as starting point. You can't search on a route topic, only on a city or place. MRA mis a hope new customers with the difficult acces to there route library. In Routeyou it's peace of cake.
                @Cleo
                Select Guy in the RouteXpert list, and zoom out and then in
                  Cleo
                  wrote on last edited by Cleo
                  Hans you have still to hoover to find begin and end. Why is it so difficult to make from parts of a route a collection. So you can see in one view all the route of the collections. From this route i have to hoover every startpoint to find the total amount of parts of a coolection. https://www.myrouteapp.com/en/motor-en-auto-routes/at/Tirol/4015739/3-From-Hochgurgl-in-Austria-to-Trafoi-in-South-Tirol-Italy
                  Then you find out the startpoint and the endpoint of a collection.
                  If i build a trip strecht over multiple days i make for every day a route but the complete trip is a collection of routes. I make then a route for the complete trip.
                  Thats the way it should work in the library
                    It is not difficult, if you use the right entrance.
                      Or use find routes nearby and select the options
                        Or do you want to see all the routes in the RX library?
                        You still have to hoover to see the trackline.
                          Cleo
                          I don't think you understand what i mean. I'm not a rookie with MRA but there are still things what can be better and i address this.
                          Everything you show i now already. You don't look from the eye of (noob)user. Start from the viewpoint your are a new user and you want to drive Route des Grand alpes or route Napoleon, the search function don't support to find this routes.
                          Try it again.
                          There a trips in the library these are spread over multiple days, for example a 9 day trip. If you want to find all routes of these 9 days you have to hoover a lot in the map even if you select a Xpert.
                          A 9 day trip is a collection of 9 days of routes. Why there is no option to find the collection of this 9 day and have to hoover to find every single day.
                          If all these day trips start with a number you can link them but there are route with out numbers and then you have to look very wel on the map voor the start an d stop of every single day. If the collection of 9 was accessible via the account of the xpert then you see with a blink of an eye all days trips in 1 collection.
                          MRA don't use collections voor multiple day trips
                            I understand what you mean, but that's just not how it's designed or built.
                            When I search for routes in the library, I first go to the region I want to ride and then check each route to see if I can use it. If I want to use it, I open it in a new tab so my library selection remains.
                            Once I've found enough routes I want to use, I'll (possibly) modify them to my preferences, such as start and end points, etc.
                            PS, MRA does use collections for multi-day trips; take a look here: https://www.myrouteapp.com/info/collection
                              Cleo
                              I now use google. I use, for example, route des grand alpes site:myrouteapp.com
                                Travellexxieundefined Offline
                                And here it is 😝
                                https://www.myrouteapp.com/route/open/5768789
                                Cleoundefined
                                Cleo
                                Franz oundefined
                                Franz o
                                  Massimo Cardoneundefined
                                  Massimo Cardone
                                  6.3k
                                • Veekeersinfo en omleiden
                                  marko 11 0undefined
                                  marko 11 0
                                  38.7k
                                  13.0k
                                • CPMC B6/B7
                                  Leike Lodiersundefined
