  4. Nav screen menu isn't fully displayed
10 Posts 6 Posters 2.2k Views 3 Watching
  • Rafał Kukla
    Rafał Kukla
    Rafał Kukla
    Hello,
    I noticed that some (not all) menus are cut off so selecting an item on the bottom is not possible:
    This is a DMD T865X tablet, 1280x800, 210dpi.
    Display settings set as followed:
    App version 4.4.0
    BWM R1300GS + DMD-T865X + MRA
    • Con Hennekens
      Isn't that list scrollable...?
      • Rafał Kukla
        Rafał Kukla
        Rafał Kukla
        Yes,
        but it never fully shows the last item(s)
        • Rafał Kukla Rafał Kukla
          Yes,
          @Rafał-Kukla Can you hide the menu bar?
          Rafał Kukla 1 Reply Last reply
            Rafał Kukla
            Rafał Kukla
            Rafał Kukla
            @Nick-Carthew
            What menu bar?
            If you mean the Android nav bar, then yes: switching from 3-button to gesture navigation helps:
            but this isn't a solution. I'm not going to use gestures while riding...
            BTW. "full screen" settings (Navigation Settings->Screen layout) is a workaround...
            however after exiting navigation track selection looks like this:
              @Nick-Carthew
              What menu bar?
              @Rafał-Kukla Hi Rafal. I use the same tablet and have the same experiance. Trying to start your trip can be a Challenge Sometimes because the navigate button is mostly covered by the menu bar at the bottem. I could start the routes last week but having big hands like mine…….. using the full screen mode can be a solution but to my findings the result is even worse because you have to shut dien MRA to get something else started, like spotify. Shutting down the device completely solves the problem for a while, I guess it has something to do with the cache.
                The “fullscreen” mode is only for navigation and not a solution.
                This is weird as it seems like the tablet does not report the navigation bar as part of the OS but simply adds it as overlay itself. Hence our app does not know about it’s existence so to say.
                Do other apps show similar spacing issues?
                Rafał Kukla Marinus van Deudekom 2 Replies Last reply
                  Rafał Kukla
                  Rafał Kukla
                  Rafał Kukla
                  Hi @Corjan-Meijerink:
                  Other apps works ok. Please note that other menus or buttons on map screens are not covered by the nav bar.
                  I created a sample app (I'm a mobile app developer btw) and insets reported by:
                   ViewCompat.setOnApplyWindowInsetsListener(binding.root) { v, windowInsets ->
                              val insets = windowInsets.getInsets(WindowInsetsCompat.Type.systemBars())
                  are correct.
                  Also:
                  windowInsetsController.hide(WindowInsetsCompat.Type.statusBars())
                  windowInsetsController.hide(WindowInsetsCompat.Type.systemBars())
                  works as expected
                    @Corjan-Meijerink I’ve had this issue before and after rebooting the tablet the problem is gone. I think it had to do with not clearing the cache and after rebooting the chache has been cleared. After riding whole week last week I finaly got round to rebooting and yes the problem is gone. What’s your expert view on this
                    • RetiredWingMan
                      I've also seen these issues. While navigating, showing the list of waypoints the last waypoint does not scroll above the Android buttons so you can't read remaining time, distance etc.
                      Rafał Kukla
                      Rafał Kukla
                      • Statement on map spinning
                        hawebo
                        hawebo
                        1.7k
                      • Electric Car Travel Mode
                      • MRA 6.0.0 (515) Night mode
